tschak909 Posted December 10, 2020 Share Posted December 10, 2020 #Atari8bit #FujiNet Bill Kendrick wrote a set of routines to convert JPEG to mono GTIA server-side. Here are two videos displaying these images from #basic The first uses standard get/put, which works one byte at a time. The second, bypasses #BASIC's paltry GET routine and asks CIO to grab all the bytes. The original image is also posted. WIN_20201210_10_39_59_Pro.mp4 WIN_20201210_10_07_48_Pro.mp4 2 Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted December 11, 2020 Share Posted December 11, 2020 I just tried both programs in Atari Basic. The second gives error 136. The first just a black screen. I booted from the n-handler disk from irattaonline. FujiNet is running the latest firmware. The disk’s DumbTerm basic program worked. Are you two using something that hasn’t been released yet? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 11, 2020 Author Share Posted December 11, 2020 The n-handler.atr has bugs in it. Use reversi.atr or lightcycles.atr in the /Games/ folder. This is a rewritten handler that hasn't been made relocatable, yet. -Thom Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted December 11, 2020 Share Posted December 11, 2020 (edited) Thanks. That got it to work. By the way, the new handler appears to cause a conflict which stops FastBasic from loading. Edited December 11, 2020 by gs80065xe Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 11, 2020 Author Share Posted December 11, 2020 (edited) 12 minutes ago, gs80065xe said: Thanks. That got it to work. By the way, the new handler appears to cause a conflict which stops FastBasic from loading. What part of "not relocatable" escaped you? Since the handler is not relocatable, it will not adjust to different memory footprints afforded by different DOS and language environments. I am putting off making the code relocatable UNTIL it is functionally complete, as making the code relocatable makes it much more difficult to modify. -Thom Edited December 11, 2020 by tschak909 2 Quote Link to comment Share on other sites More sharing options...
gs80065xe Posted December 11, 2020 Share Posted December 11, 2020 Sorry. Didn't take time to research what you meant by relocatable. Just wanted to test the program. Quote Link to comment Share on other sites More sharing options...
