tschak909 Posted December 11, 2020 Share Posted December 11, 2020 it occurs to me that it should be possible to modify this game for fujinet: http://www.atarimania.com/game-atari-400-800-xl-xe-capture-the-flag_888.html There is a file version in the homesoft collection that could be used as a starting point. Basically it would need four things: (0) a screen to connect to host or listen on port 6502. (1) send the maze data from player 1 to player 2 (no translation or anything needed, just SIO WRITE the buffer, the other side just SIO READs it into the same place.) (2) only send joystick changes (3) automatically select 2 player, and have player 1 select invader or defender. If I'm right, the result should be highly playable. Thoughts? -Thom 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 3, 2021 Author Share Posted January 3, 2021 Have started the attempt, and it is in github: https://github.com/FujiNetWIFI/fujinet-apps/tree/master/Capture_the_Flag So far, I can jump out to my own code before the game starts, and establish a network connection, but things go south very quickly when I try to insert _ANYTHING_ into the game code, particularly in spots like this: L5677 cpy #$1F beq L5683 jsr L599C sta L0083 jmp L56C3 L5683 lda STICK0 and STICK1 and #$0F sta L0083 lda STRIG0 and STRIG1 jmp L56A0 L5696 lda STICK0,X and #$0F sta L0083 lda STRIG0,X L56A0 bne L56C3 ldx L0083 lda L56B3,X cmp #$FF beq L56B0 sta L00E8 jmp L5732 L56B0 jmp L5745 L56B3 .byte $FF,$FF,$FF,$FF,$FF If I try to insert ANYTHING anywhere in here, the whole game refuses to run, and goes into a loop where it's color cycling PCOLR4. grrrr. I am NOT experienced in disassembling games and marking data sections, so am pretty sure I'm still being bitten here... -Thom Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 3, 2021 Share Posted January 3, 2021 I converted this to the 5200 so have a disassembly you can use, but midnight here so will get in touch tomorrow. Quote Link to comment Share on other sites More sharing options...
tsom Posted January 4, 2021 Share Posted January 4, 2021 A quick look at the code on GitHub, it’s including a file “ctf.inc” but it’s not in the repo... Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 4, 2021 Author Share Posted January 4, 2021 14 minutes ago, tsom said: A quick look at the code on GitHub, it’s including a file “ctf.inc” but it’s not in the repo... fixed. it is just an equates file. -Thom 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 4, 2021 Share Posted January 4, 2021 Wild guess #1: Your code runs inside the VBI where you should not do SIO calls. Wild guess #2: You are fighting against the nasty checksum code which checks integrity of the code. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 4, 2021 Author Share Posted January 4, 2021 18 minutes ago, DjayBee said: Wild guess #1: Your code runs inside the VBI where you should not do SIO calls. Wild guess #2: You are fighting against the nasty checksum code which checks integrity of the code. I found the VBI (I see the call to VBV), definitely not doing anything in there There's checksum code?! aigh. -Thom Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 4, 2021 Share Posted January 4, 2021 Data sections aren't marked as I mentioned before, so lookup tables, jump tables, etc, which disassembled as random code are assembling with all the wrong values when other equates change (when new code is added, etc). The disassembly needs careful scrutiny and editing before one can start adding new bits. You should start with something that can at least run when assembled to a different start address. 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 4, 2021 Share Posted January 4, 2021 (edited) I wrote my last message OTOH. The checksum code is only part of the loader and gone by the time the XEX is started. Until you make the source relocatable this should work: org $400 ; or some other unused area L4x01 ; do more stuff ; take care A contains STRIG0 and STRIG1 rts L5683 lda STICK0 and STICK1 and #$0F sta L0083 lda STRIG0 jsr L4x01 jmp L56A0 Edited January 4, 2021 by DjayBee Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted January 4, 2021 Share Posted January 4, 2021 9 hours ago, tschak909 said: I found the VBI (I see the call to VBV), definitely not doing anything in there There's checksum code?! aigh. There is a checksum code, indeed, just a pretty well hidden one. I forgot unfortunately the details. If I recall, it was part of the VBI which checked for a flag, upon which it decoded a function which performed the checksum. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 4, 2021 Share Posted January 4, 2021 Are you sure? I only found the not well hidden, but very nasty one in the loader. It creates a 16-bit checksum and does eight rounds on every byte of the whole program. Thus this one is also much too heavy for a VBI. Please test if this XEX runs as expected: Capture the Flag-NOP.xex I replaced two accesses to zero page originally using 3-byte commands (16-bit addresses) with real 2-byte zero page commands, each followed by a NOP. The code length stays the same but the checksum for sure is now different. At first glance it works fine. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 4, 2021 Author Share Posted January 4, 2021 1 hour ago, DjayBee said: Are you sure? I only found the not well hidden, but very nasty one in the loader. It creates a 16-bit checksum and does eight rounds on every byte of the whole program. Thus this one is also much too heavy for a VBI. Please test if this XEX runs as expected: Capture the Flag-NOP.xex 8.71 kB · 0 downloads I replaced two accesses to zero page originally using 3-byte commands (16-bit addresses) with real 2-byte zero page commands, each followed by a NOP. The code length stays the same but the checksum for sure is now different. At first glance it works fine. Yup, seems to be fine. heh, count on me to step on a land mine. -Thom Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 4, 2021 Share Posted January 4, 2021 Then my JSR-approach from post #9 should be feasible for the time being. Quote Link to comment Share on other sites More sharing options...
