Cmherndon79 Posted December 11, 2020 Share Posted December 11, 2020 (edited) Recently got a console lot in, with everything advertised as "not working". One of the items in that lot was a Sega Genesis Power Base Converter. Thought it odd this wouldn't work at all, as the Genesis has the hardware built in for SMS support. Inspected the cart connectors and cleaned them, no issues there. Installed the converter and tried Shinobi and I indeed got a black screen. I know the cart works, as that lot also came with an SMS that i fixed by replacing the 7805 voltage regulator and used that cart to burn in the system after. Tried reseating the cart multiple times, but no change in behavior. Screen is always black when powered on. Next, I removed the Shinobi cart and I tried a Sega Card, Spy vs. Spy, which I'd also just used on that SMS I repaired and it worked fine in the Power Base Converter. Removed the Sega Card and tried the cartridge a few more times, but always black screen. So, it seems to be fine with a Sega Card, but not with a cartridge. Opened it up and not a lot going on inside. No visible damage. Not much going on inside either, got a few electrolytic caps, that I haven't tried replacing yet and a Sega chip, 315-5342 that i can't find much information about. Anyone ever run across something like this? Thanks! Edit: Other information: This is a Model 1 non-TMSS Genesis the Power Base Converter was tested on. Edited December 11, 2020 by Cmherndon79 Quote Link to comment Share on other sites More sharing options...
Cmherndon79 Posted December 11, 2020 Author Share Posted December 11, 2020 Figured while I had the thing disassembled already, I'd go ahead and swap out the 2 47uF and 1uF electrolytic caps. No change however. Quote Link to comment Share on other sites More sharing options...
Cmherndon79 Posted December 12, 2020 Author Share Posted December 12, 2020 More updates: Cut one end of the diode and resistors and measured/tested those and they're in spec. Soldered those back down. Hit the SMS cart slot portion with WD40 contact cleaner, and then used a credit card wrapped in an old sheet to scrub the contacts. Followed up with 99% isopropyl and the same CC and sheet. Then installed a cartridge and removed 5 times. No change. Pulled out a few more cartridges to test. I found that Outrun, Alien 3 and Space Harrier will boot at least 1/4 of time, some nearly every time. Found the Alien Syndrome will never boot, just like Shinobi. Went back and did more extensive power testing on Spy vs. Spy on the Sega Card and I found that it also won't boot up perhaps one out of every 10 attempts. Quote Link to comment Share on other sites More sharing options...
BillyNY Posted January 30, 2021 Share Posted January 30, 2021 I recently got Shinobi and tried it in my Power Base Converter. I cleaned the contacts in the cartridge and it would boot up roughly 10% of the time. I got a replacement cartridge from the eBay seller. I had pretty much the same luck with that one too. I have 5 other Master System games and they boot up 100% of the time. Then I read in a forum that someone has the same problem with R-Type. He turns on the power with Power Base Converter in but no cartridge, then inserts cartridge straight in (try not to go in on a slant), presses Reset, and it works every time. So I tried that with Shinobi. It doesn’t work every time but it boots up a lot more often than before. I’m still trying to figure this out. I just got the replacement cartridge yesterday. Quote Link to comment Share on other sites More sharing options...
