+RXB Posted July 10, 2021 Share Posted July 10, 2021 11 minutes ago, Vorticon said: The problem with ON GOSUB is that the variable can only have discreet sequential integer values starting at 1, which would be very restrictive. I much prefer the flexibility of IF/THEN at the expense of elegance. Hmm we do have a command to deal with this INT(floating point number) Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted July 10, 2021 Share Posted July 10, 2021 52 minutes ago, Vorticon said: The problem with ON GOSUB is that the variable can only have discreet sequential integer values starting at 1, which would be very restrictive. I much prefer the flexibility of IF/THEN at the expense of elegance. Don't have a computer in front of me, but I would imagine that ON GOSUB rounds the value up or down as needed. Not the same as INT which always rounds it down. Easy enough to check this. 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted July 10, 2021 Author Share Posted July 10, 2021 49 minutes ago, Vorticon said: ON 1-(a=1)-2*(a=2)-3*(a=3 or a=4) GOSUB CASEELSE, CASE001, CASE002, CASE003 I also tend to the IF-THEN, but above line does not require the numbers to be sequential integers, this would also work with strings or key-codes, as the (Var=Value) terms are -1 when true, with the multiplicator giving the ON value. ON 1-(a=65)-2*(a=88)-3*(a=32 or a=13) GOSUB CASEELSE, CASE001, CASE002, CASE003 Would work just as well. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 10, 2021 Share Posted July 10, 2021 46 minutes ago, senior_falcon said: Don't have a computer in front of me, but I would imagine that ON GOSUB rounds the value up or down as needed. Not the same as INT which always rounds it down. Easy enough to check this. This. Program: 10 RANDOMIZE 20 A=RND*10 30 ON A+1 GOSUB 100,110,120,130,140,150,160,170,180,190,200 40 GOTO 20 100 PRINT "0";A :: RETURN 110 PRINT "1";A :: RETURN 120 PRINT "2";A :: RETURN 130 PRINT "3";A :: RETURN 140 PRINT "4";A :: RETURN 150 PRINT "5";A :: RETURN 160 PRINT "6";A :: RETURN 170 PRINT "7";A :: RETURN 180 PRINT "8";A :: RETURN 190 PRINT "9";A :: RETURN 200 PRINT "10";A :: RETURN Sample output (notice rounding is always the nearest integer, not restricted to just up or down): 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 10, 2021 Share Posted July 10, 2021 1 hour ago, SteveB said: I also tend to the IF-THEN, but above line does not require the numbers to be sequential integers, this would also work with strings or key-codes, as the (Var=Value) terms are -1 when true, with the multiplicator giving the ON value. ON 1-(a=65)-2*(a=88)-3*(a=32 or a=13) GOSUB CASEELSE, CASE001, CASE002, CASE003 Would work just as well. Ah I see. Yes that would work. Clever. I guess then it's up to you to decide how you want to proceed. I'll be a very happy camper either way as long as I have a CASE statement! ? 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 10, 2021 Share Posted July 10, 2021 2 hours ago, RXB said: Hmm we do have a command to deal with this INT(floating point number) What if the starting value of the selection variable is not 1? Also what if I want to compare specific float values and not integers? 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 12, 2021 Share Posted July 12, 2021 I just noted that the TAB key does not work in the editor. I think it's important to have that functionality for ease of formatting. Quote Link to comment Share on other sites More sharing options...
+RXB Posted July 12, 2021 Share Posted July 12, 2021 5 hours ago, Vorticon said: I just noted that the TAB key does not work in the editor. I think it's important to have that functionality for ease of formatting. I can add a TAB key to RXB Editor so how many spaces should it jump forward or should it look for something like "::" ? Spoiler *********************************************************** CTRLS CEQ 147,@RKEY CTRL S BR CTRLD No, check more DST @VARW,@ARG5 Force cursor to start * ARG5 = current position BR RBACK Now process like FCTN S CTRLD CEQ 132,@RKEY CTRL D BR CTRLE No, check more DST @VARA,@ARG5 Force cursor to end CALL SPACES Look for space BR RFORW Process like FCTN D CTRLE CEQ 133,@RKEY CTRL E BR CTRLX No, check more DSUB 32,@ARG5 Up one line DCH @ARG5,@VARW Check range BR READZ1 Ok, go on DADD 32,@ARG5 No, redo BR READZ1 And continue CTRLX CEQ 152,@RKEY CTRL X BR CTRL Resume where left off DADD 32,@ARG5 Next line DCHE @ARG5,@VARA Check range BS READZ1 Ok, continue DSUB 32,@ARG5 No, redo BR READZ1 Now, go on CTRL CHE >20,@RKEY Control character!!!! BS G6BD0 BR G6ADC SPACES CEQ >80,V*ARG5 SPACE? BR SPACE2 DDEC @ARG5 BR SPACES SPACE2 CEQ >7F,V*ARG5 CURSOR? BS SPACE3 RTN SPACE3 DSUB 4,@ARG5 BR SPACES BR G6A86 *********************************************************** I think the best thing would be tab maybe 24 characters at time so next line in Editor each tab. XB EXAMPLE: 100 ! This is a test line at line 100 and just to show an example. When you hit tab the screen would like this: 100 ! This is a test line at @line 100 and just to sh ow an example. The @ is where the Cursor would move to. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted July 12, 2021 Share Posted July 12, 2021 58 minutes ago, RXB said: I can add a TAB key to RXB Editor so how many spaces should it jump forward or should it look for something like "::" ? Reveal hidden contents *********************************************************** CTRLS CEQ 147,@RKEY CTRL S BR CTRLD No, check more DST @VARW,@ARG5 Force cursor to start * ARG5 = current position BR RBACK Now process like FCTN S CTRLD CEQ 132,@RKEY CTRL D BR CTRLE No, check more DST @VARA,@ARG5 Force cursor to end CALL SPACES Look for space BR RFORW Process like FCTN D CTRLE CEQ 133,@RKEY CTRL E BR CTRLX No, check more DSUB 32,@ARG5 Up one line DCH @ARG5,@VARW Check range BR READZ1 Ok, go on DADD 32,@ARG5 No, redo BR READZ1 And continue CTRLX CEQ 152,@RKEY CTRL X BR CTRL Resume where left off DADD 32,@ARG5 Next line DCHE @ARG5,@VARA Check range BS READZ1 Ok, continue DSUB 32,@ARG5 No, redo BR READZ1 Now, go on CTRL CHE >20,@RKEY Control character!!!! BS G6BD0 BR G6ADC SPACES CEQ >80,V*ARG5 SPACE? BR SPACE2 DDEC @ARG5 BR SPACES SPACE2 CEQ >7F,V*ARG5 CURSOR? BS SPACE3 RTN SPACE3 DSUB 4,@ARG5 BR SPACES BR G6A86 *********************************************************** I think the best thing would be tab maybe 24 characters at time so next line in Editor each tab. XB EXAMPLE: 100 ! This is a test line at line 100 and just to show an example. When you hit tab the screen would like this: 100 ! This is a test line at @line 100 and just to sh ow an example. The @ is where the Cursor would move to. I have trouble seeing how much functionality this would add. Both RXB and XB 2.8 G.E.M. can use Ctrl up and Ctrl down to go up or down one line in the editor. That would be a tab of 28 characters. I suppose going to the statement separator "::" could be of use. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted July 12, 2021 Share Posted July 12, 2021 2 hours ago, senior_falcon said: I have trouble seeing how much functionality this would add. Both RXB and XB 2.8 G.E.M. can use Ctrl up and Ctrl down to go up or down one line in the editor. That would be a tab of 28 characters. I suppose going to the statement separator "::" could be of use. Hmm that line can be 4 screen lines long. That is a lot to get to what you want to edit using the left arrow. Besides now that I have moved so much GPL from GROM to ROM I can add all kinds of features to XB no one else has added. I think the FIND? command using the FCTN TAB key would be great to find :: or say something like SPRITE or a Variable name. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted July 13, 2021 Share Posted July 13, 2021 3 hours ago, RXB said: Hmm that line can be 4 screen lines long. That is a lot to get to what you want to edit using the left arrow. Yes, using the left and right arrows can be a very tedious way of getting navigating a long line. I suspect that's why the author of RXB made it so Ctrl Up and Ctrl Down work the way they do. 1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 13, 2021 Share Posted July 13, 2021 You guys are so funny. I'm pretty certain the request for TAB support was focused on the main topic of this thread. TiCodEd. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted July 13, 2021 Share Posted July 13, 2021 23 minutes ago, jedimatt42 said: You guys are so funny. I'm pretty certain the request for TAB support was focused on the main topic of this thread. TiCodEd. Boy, do I feel silly! Quote Link to comment Share on other sites More sharing options...
JamesH Posted July 13, 2021 Share Posted July 13, 2021 As an FYI, program works fine in WINE, on Ubuntu, too ? 1 Quote Link to comment Share on other sites More sharing options...
wierd_w Posted July 13, 2021 Share Posted July 13, 2021 (edited) SELECT CASE likewise is unconcerned about variable type or content. It can be a string, an integer, a double, a single, a long...An array index...--- whatev. For this reason I would say the GOSUB surrogate, while clever, is not really a substitute for SELECT CASE. Especially since CASE allows the use of the "OTHER" case, which is "All things not specified". Sure, you could do something similar with "VARIABLE >=[integer]", with all the lower values being your branch targets--- but then how do you deal with the edge case of the integer not being proper (such as a 0)? Depending on how you are using that CASE surrogate, it could be messy. OK, this is annoying. I click on a thread I KNOW FOR A FACT THAT I HAVE READ, and it sends me to a page that is older than dirt, I am sleepy, dont pay attention, and then reply to it and look like a chump. (makes angry old man sounds) Edited July 13, 2021 by wierd_w 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 13, 2021 Share Posted July 13, 2021 15 hours ago, RXB said: I can add a TAB key to RXB Editor so how many spaces should it jump forward or should it look for something like "::" ? Reveal hidden contents *********************************************************** CTRLS CEQ 147,@RKEY CTRL S BR CTRLD No, check more DST @VARW,@ARG5 Force cursor to start * ARG5 = current position BR RBACK Now process like FCTN S CTRLD CEQ 132,@RKEY CTRL D BR CTRLE No, check more DST @VARA,@ARG5 Force cursor to end CALL SPACES Look for space BR RFORW Process like FCTN D CTRLE CEQ 133,@RKEY CTRL E BR CTRLX No, check more DSUB 32,@ARG5 Up one line DCH @ARG5,@VARW Check range BR READZ1 Ok, go on DADD 32,@ARG5 No, redo BR READZ1 And continue CTRLX CEQ 152,@RKEY CTRL X BR CTRL Resume where left off DADD 32,@ARG5 Next line DCHE @ARG5,@VARA Check range BS READZ1 Ok, continue DSUB 32,@ARG5 No, redo BR READZ1 Now, go on CTRL CHE >20,@RKEY Control character!!!! BS G6BD0 BR G6ADC SPACES CEQ >80,V*ARG5 SPACE? BR SPACE2 DDEC @ARG5 BR SPACES SPACE2 CEQ >7F,V*ARG5 CURSOR? BS SPACE3 RTN SPACE3 DSUB 4,@ARG5 BR SPACES BR G6A86 *********************************************************** I think the best thing would be tab maybe 24 characters at time so next line in Editor each tab. XB EXAMPLE: 100 ! This is a test line at line 100 and just to show an example. When you hit tab the screen would like this: 100 ! This is a test line at @line 100 and just to sh ow an example. The @ is where the Cursor would move to. I was thinking more along the lines of text indentation in TICODED. But the idea of tabbing within the RXB editor is also interesting and I would lean towards tabbing to the next "::" which would simplify the editing of long multi-statement lines. I have also found that using the CTRL-arrow keys to freely move around a line in the XB GEM editor was very useful, the closest we could get to a full-screen editor in XB, something to perhaps also consider in RXB. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted July 13, 2021 Share Posted July 13, 2021 7 hours ago, Vorticon said: I was thinking more along the lines of text indentation in TICODED. But the idea of tabbing within the RXB editor is also interesting and I would lean towards tabbing to the next "::" which would simplify the editing of long multi-statement lines. I have also found that using the CTRL-arrow keys to freely move around a line in the XB GEM editor was very useful, the closest we could get to a full-screen editor in XB, something to perhaps also consider in RXB. Well Senior Falcon is correct RXB already had CONTOL ARROWS for first of line, end of line and up and down lines. But I am going to add FIND into XB Editor Mode so like RES or NUM or COPY just type in FIND linenumber,string EXAMPLE: FIND 2070,RK=LF Would start at line number 2070 and look for "RK=LF" in program and show line number with "RK=LF" in that line number. Error output would be No Program Present, Bad Value, Bad Line Number or Line Not Found in case no match found. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted July 13, 2021 Share Posted July 13, 2021 What would you use as Tab key on a TI-99/4A? 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted July 13, 2021 Author Share Posted July 13, 2021 On 7/12/2021 at 2:40 PM, Vorticon said: I just noted that the TAB key does not work in the editor. I think it's important to have that functionality for ease of formatting. What is not working for you? On an empty page TAB indents 3 characters, otherwise it tries to align with the indention of the line above. This is a function of the Lazarus SynEdit component and not changed by me. Does it behave differently on your system? Steve TiCodEd Tab Key.mp4 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 13, 2021 Share Posted July 13, 2021 1 hour ago, Asmusr said: What would you use as Tab key on a TI-99/4A? FCTN-7? It's the standard tab key for the E/A editor and most other editors. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 13, 2021 Share Posted July 13, 2021 43 minutes ago, SteveB said: What is not working for you? On an empty page TAB indents 3 characters, otherwise it tries to align with the indention of the line above. This is a function of the Lazarus SynEdit component and not changed by me. Does it behave differently on your system? Steve TiCodEd Tab Key.mp4 93.87 kB · 1 download OK so I was entering code into the XB tab instead of the SXB one. Duh... Everything works fine. Sorry about the false alarm. 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted July 13, 2021 Share Posted July 13, 2021 9 minutes ago, Vorticon said: FCTN-7? It's the standard tab key for the E/A editor and most other editors. Thanks, I have never tried that. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 13, 2021 Share Posted July 13, 2021 Also used in SNP, fctn7, tab. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted July 14, 2021 Share Posted July 14, 2021 That's also the mapping I used on my PS/2 keyboard and Classic99 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted July 14, 2021 Author Share Posted July 14, 2021 I just released version 1.2 of TiCodEd. The biggest change is the new "Variable" tab. As I was writing a larger SXB program I found it difficult to remember all the tiny variable names I was using to preserve precious RAM. With this new feature you can use long, meaningful variable names in SXB and get the substituted for memory saving short names in XB when writing the tokenized file (on the XB tab the long name is still used). This tab also features a cross-reference for you to see in which XB line a variable is used. I also fixed some bugs and made some usability enhancements, i.e. the window size and position is now remembered. You can download the new version as always at http://lizardware.de/ with Lazarus Source for Windows 64 and 32 bit. Enjoy Steve 2 Quote Link to comment Share on other sites More sharing options...
