+Vorticon Posted December 13, 2020 Share Posted December 13, 2020 Hi. My original 1M SAMS card from 1995 is acting up. Here's the result of the memory check. Any suggestions where the fault might lie? 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/ Share on other sites More sharing options...
GDMike Posted December 13, 2020 Share Posted December 13, 2020 (edited) You can dl my SNP program and run it. And it will init all UPPER banks with blanks, and you can page through each page looking for garbage. Also, Turboforth will allow setbank. And you can do a similar thing. I guess, I don't know what that error means except maybe it's doing a CRC at init time, which doesn't necessarily mean that the 32 k in lower banks is bad, but maybe an UPPER memory detection? Maybe someone can chime in about this error. But wow, it lasted this long?!!! Great!! This program is a Fixed 80 program name is SNP. Maybe the caps and voltage regulator need swap out. SNP Edited December 13, 2020 by GDMike 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698511 Share on other sites More sharing options...
+Ksarul Posted December 13, 2020 Share Posted December 13, 2020 I'd clean the edge contacts before you try anything else, some of them look pretty grungy. . . 2 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698514 Share on other sites More sharing options...
+TheBF Posted December 13, 2020 Share Posted December 13, 2020 I have had it happen that removing and re-installing socketed chips solves a problem. There are a lots of opportunity for that problem on that board. 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698525 Share on other sites More sharing options...
+FALCOR4 Posted December 13, 2020 Share Posted December 13, 2020 1 hour ago, TheBF said: I have had it happen that removing and re-installing socketed chips solves a problem. There are a lots of opportunity for that problem on that board. Definitely try that first. I had a similar problem that cleaning solved. I ended up cleaning the pins of the ICs, using contact cleaner on the pins and sockets, then swiping a thin film of dielectric grease on the pins before reinserting them. The card has been rock solid since. Hopefully something like that will work for you. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698552 Share on other sites More sharing options...
+FarmerPotato Posted December 13, 2020 Share Posted December 13, 2020 @InsaneMultitaskermade a comment that he replaces single wipe sockets with double wipe. I think most low profile open sockets are not single wipe. I never knew about this before. are your sockets machine pin holes or the springy contact kind? I read elsewhere that corrosion in the pins bends the contacts so new chips don’t make good contact. Folks recommend machine pin sockets. I hate those because it is hard to get a 32 DIP into one without bending a pin. I am going to pay more attention to the socket contacts in future. 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698674 Share on other sites More sharing options...
+InsaneMultitasker Posted December 13, 2020 Share Posted December 13, 2020 21 minutes ago, FarmerPotato said: I think most low profile open sockets are not single wipe. I never knew about this before. Here's a site I saved along the way that may be of interest. The first few pictures of the sockets represent what I have found along the way in many of the cards I repaired - whether logic, ram, or EPROM - and often times the low height coupled with age tends to lead to sporadic connections with the chips. Not all of them are problematic though certainly a good thing to keep in the rework/troubleshooting arsenal. (the comment about new chips flaring outward is something that caught my attention back then as well) http://arcadecontrols.com/BBBB/ic.html 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698690 Share on other sites More sharing options...
+TheBF Posted December 13, 2020 Share Posted December 13, 2020 I can't say if this is 100% true. A tech I worked with once told me that H/P had discovered fungi that can grow on metal, even gold. Over time the fungi can actually get between contacts. We had 3 early vintage colour cameras by RCA that were forever going bad sometimes in the middle of a live show! The quick fix was to remove a card and re-insert it. He suggested using a cleaner with contact oil like Nutrol. We did all the cards by wiping them with a cloth and nutrol. Those problems never recurred. My theory is the contact oil prevented re-growth if it was in fact this fungus. The cameras were almost 20 yrs old at the time. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698694 Share on other sites More sharing options...
GDMike Posted December 13, 2020 Share Posted December 13, 2020 Encase the whole thing in cement! Damn fungi, take that! 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698703 Share on other sites More sharing options...
+FarmerPotato Posted December 14, 2020 Share Posted December 14, 2020 4 hours ago, InsaneMultitasker said: Here's a site I saved along the way that may be of interest. The first few pictures of the sockets represent what I have found along the way in many of the cards I repaired - whether logic, ram, or EPROM - and often times the low height coupled with age tends to lead to sporadic connections with the chips. Not all of them are problematic though certainly a good thing to keep in the rework/troubleshooting arsenal. (the comment about new chips flaring outward is something that caught my attention back then as well) http://arcadecontrols.com/BBBB/ic.html Ha! That was the first google hit I got using my phone. It's much better looking now that I am at my desktop. Thanks for posting that. Lot of practical experience there. The single wipes that I have are wire-wrap, some of them reused! The new ones of those are machined-pin, which I hate. There's only one example of the boxed up (double-wipe) on page 2 here: https://www.peconnectors.com/sockets-wire-wrap/ Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698904 Share on other sites More sharing options...
+Vorticon Posted December 14, 2020 Author Share Posted December 14, 2020 Welp I cleaned all the contacts with 91% IPA, re-seated all the chips after spraying Deoxit on the machined sockets, and also deoxidized the PEB slots, but unfortunately with no change. I think I have a bad chip somewhere and the trick is to figure out which one... I wish there was a SAMS testing program which pinpointed the bad chip. Any suggestions for a testing strategy would be much appreciated. I have all the likely needed testing equipment. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698991 Share on other sites More sharing options...
RickyDean Posted December 14, 2020 Share Posted December 14, 2020 I'd start with the sram chips first, then the buffer chips and work around the board. An eprom tester will generally have the ability to test the ttl and sram. The 612 mapper is a hard one to test, at least for me as none of my equipment can read it for testing. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698996 Share on other sites More sharing options...
+Ksarul Posted December 14, 2020 Share Posted December 14, 2020 Do you have an EPROM burner with integrated LS logic testing capability? If you do, just pull the ones it can test one by one and see if any show up bad. . . 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698997 Share on other sites More sharing options...
+TheBF Posted December 14, 2020 Share Posted December 14, 2020 1st thing to check is for correct power. Is the 7805 regulator making 5 volts? This can be hard to test without a card extender. You might have to solder a wire onto the output pad of the regulator chip. Insulate the end you will measure with tape to prevent accidentally shorting it. (Murphy's law) Or just replace it with a new one. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4698998 Share on other sites More sharing options...
+Vorticon Posted December 15, 2020 Author Share Posted December 15, 2020 On 12/13/2020 at 8:21 PM, Ksarul said: Do you have an EPROM burner with integrated LS logic testing capability? If you do, just pull the ones it can test one by one and see if any show up bad. . . I have a TL866CS programmer, and the 6840008 SRAM is not on the list of supported chips unfortunately. Is there an equivalent chip I could use? Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700019 Share on other sites More sharing options...
+Vorticon Posted December 15, 2020 Author Share Posted December 15, 2020 On 12/13/2020 at 8:22 PM, TheBF said: 1st thing to check is for correct power. Is the 7805 regulator making 5 volts? This can be hard to test without a card extender. You might have to solder a wire onto the output pad of the regulator chip. Insulate the end you will measure with tape to prevent accidentally shorting it. (Murphy's law) Or just replace it with a new one. I used an extender and checked the output of the 7805 and it's a steady 5V. So that's not it. That would have been too easy, wouldn't it ? 2 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700020 Share on other sites More sharing options...
+TheBF Posted December 15, 2020 Share Posted December 15, 2020 I am not sure what the software test disclosed. When it says "data not kept correctly" does that mean everything? For example are the registers retaining data? Sticking with the power question. I suppose the next thing to confirm is; is that 5V getting to all the Vcc pins of each chip? There are a couple of tantalum caps on the board. They can sometimes short although that was common years ago. Modern ones may be flawless. Solder joints can open up over time as well if they were not quite right in the first place. So touching up all the solder joints to those sockets can fix strange problems. And then of course old chips can fail. That's where replacements are that fastest way out the door. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700028 Share on other sites More sharing options...
+Vorticon Posted December 15, 2020 Author Share Posted December 15, 2020 The error message is very vague unfortunately, so it could be anything. I'm working on testing all the chips I can test, then order replacements for the rest although it might actually be cheaper to just buy one of the new SAMS cards from Jim... That said, I just hate throwing away a fixable piece of equipment, particularly since all the chips are socketed. We'll see how far I get. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700034 Share on other sites More sharing options...
GDMike Posted December 15, 2020 Share Posted December 15, 2020 Does the computer work? I mean is the base 32K useful? I didn't see where you said that it didn't or did function. Sorry if I missed that part. I just saw the test results. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700054 Share on other sites More sharing options...
+Vorticon Posted December 15, 2020 Author Share Posted December 15, 2020 22 minutes ago, GDMike said: Does the computer work? I mean is the base 32K useful? I didn't see where you said that it didn't or did function. Sorry if I missed that part. I just saw the test results. Seems to but I have to test that more extensively. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700072 Share on other sites More sharing options...
RickyDean Posted December 15, 2020 Share Posted December 15, 2020 3 hours ago, Vorticon said: I have a TL866CS programmer, and the 6840008 SRAM is not on the list of supported chips unfortunately. Is there an equivalent chip I could use? From a Google search you have 512Kx8 sram, I do not see an equivalent listed in the minipro menu, when selecting standard sram, but there may be an equivalent in one of the other listed manufacturers. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700170 Share on other sites More sharing options...
+TheBF Posted December 15, 2020 Share Posted December 15, 2020 Not sure is this is of use Vorticon. I had this in the can from some time back and I can now compile EA5 programs so here is lexicon of test commands. There is a HELP command. It needs Editor/assembler cart. I have not tested this on real iron yet. It tests the card in 64k segments. It does not try to test the bottom 64K of memory.(segment 0) If the card does not work at all then of course it will not run. If there is any specific test you would need let me know I may be able to build something for you with the tools I have. Edit Bug fixed code. Spoiler \ test sams card in 64K segments MARKER /SAMSTEST \ command to remove everything when you are done. NEEDS DUMP FROM DSK1.TOOLS NEEDS PAGED FROM DSK1.SAMSFTH NEEDS SDUMP FROM DSK1.SAMSDUMP NEEDS COMPARE FROM DSK1.COMPARE NEEDS ELAPSE FROM DSK1.ELAPSE NEEDS U.R FROM DSK1.UDOTR HEX 7FFF CONSTANT 32K FFFF CONSTANT 64K 1000 CONSTANT 4K VARIABLE FATAL : ?FATAL ( flag -- ) FATAL @ AND IF CR ." Stopped on failure" ABORT THEN ; : ?BREAK ?TERMINAL ABORT" *HALTED*" ; CREATE PBUFFER 4K ALLOT \ holds the pattern we are testing \ : ERASE 0 FILL ; \ : BLANKS BL FILL ; CODE MOVE16 ( addr1 addr2 len -- ) \ fast move 16bit cells C036 , C076 , C104 , 1306 , 0584 , 0244 , FFFE , CC31 , 0644 , 15FD , C136 , NEXT, ENDCODE : BINARY 2 BASE ! ; : SETPATTERN ( char -- ) BASE @ >R CR ." Bit Pattern = " BINARY DUP 8 U.R R> BASE ! PBUFFER 4K ROT FILL CR ; \ move pattern-buffer into entire segment : FILLSEG ( seg# -- ) SEGMENT \ set the segment 64K 0 DO PBUFFER I PAGED 4K MOVE16 4K +LOOP ; : PAGETEST ( addr -- ?) PBUFFER 4K ROT PAGED 4K COMPARE DUP ?FATAL ; : TESTSEG ( seg# -- ) CR ." Fill 64K seg# " DUP . ." with" PBUFFER C@ HEX 4 .R FILLSEG 64K 0 DO CR ." Address" HEX I 5 U.R ." ... " I PAGETEST .S IF ." FAIL" ELSE ." PASS" THEN ?BREAK 4K +LOOP ; DECIMAL : SAMSTEST PAGE CR ." SAMS Card memory test" CR ." ---------------------" 16 1 DO CR CR ." *SEGMENT*" DECIMAL I 3 .R CR I TESTSEG LOOP ; ( 58 secs) HEX AA SETPATTERN : REPTEST ( SEG# -- ) BEGIN PAGE CR ." SAMS 64K Repeat Test" CR ." --------------------" CR ." *SEGMENT*" DECIMAL DUP 3 .R CR DUP TESTSEG ?BREAK AGAIN ; HEX : REGTEST 1E00 'R12 ! \ select SAMS card CRU address SAMS-OFF \ mapper off 0SBO \ turn on register memory 4000 PAD 20 MOVE \ save the registers 4000 20 FF FILL 4000 20 DUMP CR ." Should see FFFF" CR ." Restoring registers PAD 4000 20 MOVE \ restore registers 0SBZ SAMS-ON ; : HELP PAGE ." * SAMS 1Mb TESTER Help *" CR ." --------------------------" CR ." HEX ( xx) SETPATTERN" CR ." sets bit pattern used" CR CR ." ( seg#) SEGMENT sets segment" CR CR ." ( seg#) REPTEST Test seg# until BREAK" CR CR ." SAMSTEST test all segments" CR CR ." ( addr len) SDUMP dump SAMS memory" CR CR ." FATAL ON breaks on error" CR ." FATAL OFF no break on error" CR CR ." REGTEST " CR ." HELP show this screen" ; : COLD WARM PAGE ." SAMS Tester " CR ." HELP to see commands ABORT ; LOCK INCLUDE DSK1.SAVESYS ' COLD SAVESYS DSK2.SAMSTESTER See next post for corrected version. 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4700197 Share on other sites More sharing options...
+TheBF Posted December 17, 2020 Share Posted December 17, 2020 Very sorry. I added a FATAL error halt feature and of course I added a bug to go with it. When you run some of the tests they don't return properly and the command interpreter is left in limbo. This version has the bug fixed. SAMSTESTER2.VIP.zip 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4701263 Share on other sites More sharing options...
+arcadeshopper Posted December 17, 2020 Share Posted December 17, 2020 you could also try matt's tester here: https://github.com/jedimatt42/ti994a-32kmemtest it does sams and tests more extensively than the amstest4 does 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4701702 Share on other sites More sharing options...
+Vorticon Posted December 17, 2020 Author Share Posted December 17, 2020 14 hours ago, TheBF said: Very sorry. I added a FATAL error halt feature and of course I added a bug to go with it. When you run some of the tests they don't return properly and the command interpreter is left in limbo. This version has the bug fixed. SAMSTESTER2.VIP.zip 9.41 kB · 4 downloads Great program! You've got to love Forth! I am seeing some inconsistencies however: AMSR4 reports only 512K of RAM (after I reflowed the solder joints, the RAM size went from 1024 to 512 irrespective of the position of the SRAM chips), but SAMSTESTER seems to see all of the memory. The REGTEST passes. SAMSTESTER goes only to segment #15. Shouldn't there be a segment #16 to account for 1024K? It starts at segment #1, not #0. AMSR4 is locking up at random memory pages. Not so with SAMSTESTER I think the problem lies with the 612 memory mapper. I have managed to test almost all of the support chips and they pass. I think one of the SRAM modules is bad as well but I am getting inconsistent results with the testing (swapping the SRAM chips sometimes gives an error, and sometimes not). I'm just going to order replacements for the 612 and SRAMs and see if that solves the issue. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/#findComment-4701714 Share on other sites More sharing options...
