spspspsp Posted March 22, 2021 Share Posted March 22, 2021 I've been trying to deal with a similar issue--ESP-01 boards seem to be a crapshoot. I have a bunch that are very picky about what FWs they will flash to. I have ordered some ESP-01S boards to see how much of an improvement those bring. 1 Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 22, 2021 Share Posted March 22, 2021 26 minutes ago, spspspsp said: I've been trying to deal with a similar issue--ESP-01 boards seem to be a crapshoot. I have a bunch that are very picky about what FWs they will flash to. I have ordered some ESP-01S boards to see how much of an improvement those bring. my batch of ESP-01 are "stuck" on firmware v1.0.0 but they appear to be working perfectly, with no issues. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted March 22, 2021 Author Share Posted March 22, 2021 2 minutes ago, Andrew Davie said: my batch of ESP-01 are "stuck" on firmware v1.0.0 but they appear to be working perfectly, with no issues. v1.0.0 ? Did you tried to update them (e.g. v1.7.4 or v1.6.2)? Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 22, 2021 Share Posted March 22, 2021 1 minute ago, Al_Nafuur said: v1.0.0 ? Did you tried to update them (e.g. v1.7.4 or v1.6.2)? Yes. All attempts (via PlusCart menu) have failed. I have tried many times. But, as noted, the units work *perfectly* Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted March 22, 2021 Author Share Posted March 22, 2021 10 minutes ago, Andrew Davie said: Yes. All attempts (via PlusCart menu) have failed. I have tried many times. But, as noted, the units work *perfectly* No, I meant via FTDI and the espressif (or better the nodemcu ) flash tool. Link to comment Share on other sites More sharing options...
spspspsp Posted March 22, 2021 Share Posted March 22, 2021 My ESP-01 units all have AT FW 1.1.0. They work for the most part, except I get random connection drops, and I have to reboot the PlusCart to re-establish it. Having tried to eliminate everything else, I suspect that either the AT revision or ESP module hardware revision is responsible. The WiFi firmware update option doesn't have an effect on my ESP-01 modules either, but I can see one of Espressif's servers being called. Since switching to the ESP-01S worked for Fierodoug, I'm hoping the same will work for me. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted March 22, 2021 Author Share Posted March 22, 2021 (edited) 17 minutes ago, Andrew Davie said: Yes. All attempts (via PlusCart menu) have failed. I have tried many times. 3 minutes ago, spspspsp said: My ESP-01 units all have AT FW 1.1.0. They work for the most part, except I get random connection drops, and I have to reboot the PlusCart to re-establish it. Having tried to eliminate everything else, I suspect that either the AT revision or ESP module hardware revision is responsible. The WiFi firmware update option doesn't have an effect on my ESP-01 modules either, but I can see one of Espressif's servers being called. Since switching to the ESP-01S worked for Fierodoug, I'm hoping the same will work for me. The PlusCart menu only tries to initiate the FOTA update function of the ESP8266, this was only introduced with version v1.3.x or v1.4.x Edited March 22, 2021 by Al_Nafuur Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 22, 2021 Share Posted March 22, 2021 2 minutes ago, Al_Nafuur said: No, I meant via FTDI and the espressif (or better the nodemcu ) flash tool. Never tried. Have no idea how to do it! Link to comment Share on other sites More sharing options...
spspspsp Posted March 22, 2021 Share Posted March 22, 2021 1 minute ago, Al_Nafuur said: The PlusCart menu only tries to initiate the FOTA update function of the ESP8266, this was only introduced with version v1.3.x or v1.4.x That is good to know. I can get v1.3.0.2 to install. I'll see if that works. Link to comment Share on other sites More sharing options...
spspspsp Posted March 22, 2021 Share Posted March 22, 2021 No, I was mistaken. I can downgrade to SDK v1.3.0 and AT v0.40.0.0 easily. Just gonna wait for the ESP-01S. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted March 22, 2021 Author Share Posted March 22, 2021 I recommend to flash this firmware version: https://www.espressif.com/sites/default/files/ap/ESP8266_NonOS_AT_Bin_V1.7.4.zip with the nodemcu flasher: https://github.com/nodemcu/nodemcu-flasher before soldering the ESP. "Config" settings are: "Advanced" settings: 1 Link to comment Share on other sites More sharing options...
spspspsp Posted March 22, 2021 Share Posted March 22, 2021 I actually got my flashing issue sorted--I found a firmware that supported OTA updates, and now I'm on AT v1.7.4.0 thanks to the WiFi FW update feature. Seems OK in some short tests, but I'll need to play with it more. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted March 22, 2021 Author Share Posted March 22, 2021 3 hours ago, spspspsp said: I actually got my flashing issue sorted--I found a firmware that supported OTA updates, and now I'm on AT v1.7.4.0 thanks to the WiFi FW update feature. Which version was it? Link to comment Share on other sites More sharing options...
Capellão Posted September 25, 2022 Share Posted September 25, 2022 If you are going to use the serial usb adapter ch340g, you will need to connect the gpio to the gnd to enable the esp8266 flash function. 1 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 25, 2022 Author Share Posted September 25, 2022 9 hours ago, Capellão said: If you are going to use the serial usb adapter ch340g, you will need to connect the gpio to the gnd to enable the esp8266 flash function. If you add a latching switch you can switch between flashing and communicating/testing the device: 1 Link to comment Share on other sites More sharing options...
Capellão Posted September 26, 2022 Share Posted September 26, 2022 12 hours ago, Al_Nafuur said: If you add a latching switch you can switch between flashing and communicating/testing the device: 1 Link to comment Share on other sites More sharing options...
Capellão Posted September 26, 2022 Share Posted September 26, 2022 On 3/22/2021 at 12:11 PM, Al_Nafuur said: I recommend to flash this firmware version: https://www.espressif.com/sites/default/files/ap/ESP8266_NonOS_AT_Bin_V1.7.4.zip with the nodemcu flasher: https://github.com/nodemcu/nodemcu-flasher before soldering the ESP. "Config" settings are: "Advanced" settings: some parts after updating the firmware version, no longer display their version. To fix this problem, I changed the "SPI MODE" setting to "DOUT", and it worked. Link to comment Share on other sites More sharing options...
