Issue using FujiNet to update SIDE3
tsom
This happened the last time I tried updating my Side3 cart. I have the s3loader.xex file on my local tnfs server (Raspberry Pi). I mount the xex into drive slot 1, reboot, then start the update process. It gets partway through then stops updating (with a constant "buzz" sound coming from the monitor speaker). This is part of the syslog from the TNFS server showing where it was going fine, then just started to fail:
Dec 21 17:13:59 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=8f | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:13:59 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=90 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:13:59 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=91 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:00 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=92 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:00 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=93 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:01 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=94 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:04 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=95 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:04 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=96 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=97 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=98 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=99 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9a | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: EOF
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9b | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9c | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9d | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9e | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=9f | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a0 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a1 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:05 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a2 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:06 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a3 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:06 raspberrypi tnfsd[10873]: EOF
Dec 21 17:14:06 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a4 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:06 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a5 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:06 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a6 | REQUEST cmd=0x21 TNFS_READ
Dec 21 17:14:06 raspberrypi tnfsd[10873]: 192.168.7.95 s=4567 c=21 q=a7 | REQUEST cmd=0x21 TNFS_READ
The last time it happened, I rebooted, and ran the updater again and it seemed to go fine. I'm going to try again, but make sure I have the debug window open.
The second time it completed, but seemed to have problems part way through. This is part of the debug log:
[17:20:37]disk sio_process()
[17:20:37]ACK!
[17:20:37]XEX READ (539)
[17:20:37]requesting 253 bytes from XEX
[17:20:37]received 253 bytes
[17:20:37]->SIO write 256 bytes
[17:20:37]COMPLETE!
[17:20:37]
[17:20:37]CF: 31 52 1c 02 a1
[17:20:37]ACK!
[17:20:37]XEX READ (540)
[17:20:37]COMPLETE!
[17:20:37]
[17:20:37]CF: 31 52 1d 02 a2
[17:20:37]ACK!
[17:20:37]XEX READ (541)
[17:20:39]Timeout after 2000 milliseconds. Retrying
[17:20:40]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:20:42]Timeout after 2000 milliseconds. Retrying
[17:20:43]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:20:45]Timeout after 2000 milliseconds. Retrying
[17:20:46]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:20:46]received 253 bytes
[17:20:46]->SIO write 256 bytes
[17:20:46]COMPLETE!
[17:20:54]
[17:20:54]CF: 31 52 1d 02 a2
[17:20:54]disk sio_process()
[17:20:54]ACK!
[17:20:54]XEX READ (541)
[17:20:54]seeking to offset 43516 in XEX
[17:20:54]tnfs_lseek currpos=43776, pos=43008, typ=0
[17:20:54]_tnfs_cache_seek current=43776, destination=43008, cache_start=43520, cache_end=44032
[17:20:54]_tnfs_cache_seek outside cached region
[17:20:56]Timeout after 2000 milliseconds. Retrying
[17:20:57]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:20:59]Timeout after 2000 milliseconds. Retrying
[17:21:00]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:21:00]tnfs_lseek success, new pos=43008, response pos=168
[17:21:00]CALCULATED AND RESPONSE POS DON'T MATCH!
[17:21:07]Timeout after 2000 milliseconds. Retrying
[17:21:08]TNFS OUT OF ORDER SEQUENCE! RETRYING
[17:21:08]tnfs_lseek currpos=43136, pos=43008, typ=0
[17:21:08]_tnfs_cache_seek current=43136, destination=43008, cache_start=43008, cache_end=43520
[17:21:08]_tnfs_cache_seek within cached region
[17:21:08]tnfs_lseek currpos=43008, pos=43516, typ=0
[17:21:08]_tnfs_cache_seek current=43008, destination=43516, cache_start=43008, cache_end=43520
[17:21:08]requesting 253 bytes from XEX
[17:21:08]received 253 bytes
[17:21:08]->SIO write 256 bytes
[17:21:08]COMPLETE!
[17:21:08]
[17:21:08]CF: 31 52 1d 02 a2
[17:21:08]disk sio_process()
[17:21:08]ACK!
[17:21:08]XEX READ (541)
[17:21:08]seeking to offset 43516 in XEX
[17:21:08]tnfs_lseek currpos=43772, pos=43008, typ=0
[17:21:08]_tnfs_cache_seek current=43772, destination=43008, cache_start=43520, cache_end=44032
[17:21:08]_tnfs_cache_seek outside cached region
[17:21:08]tnfs_lseek success, new pos=43008, response pos=43008
[17:21:08]COMPLETE!
[17:21:08]
[17:21:08]CF: 31 52 1e 02 a3
[17:21:08]ACK!
[17:21:08]XEX READ (542)
[17:21:08]COMPLETE!
[17:21:08]
[17:21:08]CF: 31 52 1f 02 a4
[17:21:08]ACK!
[17:21:08]XEX READ (543)
[17:21:08]COMPLETE!
[17:21:08]
[17:21:08]CF: 31 52 20 02 a5
[17:21:08]ACK!
[17:21:08]XEX READ (544)
[17:21:08]COMPLETE!
[17:21:08]
[17:21:08]CF: 31 52 21 02 a6
[17:21:08]ACK!
[17:21:08]XEX READ (545)
[17:21:08]COMPLETE!
[17:21:09]
[17:21:09]CF: 31 52 22 02 a7
[17:21:09]disk sio_process()
[17:21:09]ACK!
[17:21:09]XEX READ (546)
[17:21:09]requesting 253 bytes from XEX
[17:21:09]received 253 bytes
[17:21:09]->SIO write 256 bytes
[17:21:09]COMPLETE!
1 hour ago, DrVenkman said:
I have not tried to duplicate this issue, but why not update your SIDE3 from SIDE3 itself? Isn’t that how Jon suggests you do it?
Because it's easier to transfer the SIDE3 updater .xex to my TNFS server, then pull the sd card out of the SIDE3, get my laptop with SD Card reader, copy to sd card, then do the update....
All it's doing is reading the data from the file, I assume, so not sure why the FujiNet is having so many timeout issues.
Yeah I’m not sure where the issue is. If I reboot and rerun the updated it will usually run just fine. I do see some slowness connecting to the rPi in general sometimes.. just selecting it from the host slot sometimes it will come right up, others it will take a bit of time. My wifi access point (an eero-the base station connected to the cable modem), the RPi and the FujiNet are all within about 5’ of each other.
  • 1 year later...
On 12/25/2020 at 1:07 PM, DrVenkman said:
I’m going to go out on a limb and suggest you have a problem with your RPi server, your LAN or your Atari. I just moments ago updated my SIDE3 from my FujiNet. My local server is running on a Raspberry Pi Zero W.
How did you get the FujiNet to boot with the Side cart installed. My boot sequence causes the Side to always load before the FujiNet so can’t get to the flash app?
