Ditto Posted December 22, 2020 Share Posted December 22, 2020 I'm running a TNFSD server for internal network but would like to expost it. The IP is 73.164.217.232. I haven't touched any ports or directory restrictions other than it runs from the root of my Atari archive. Quote Link to comment Share on other sites More sharing options...
CXL4002 Posted December 24, 2020 Share Posted December 24, 2020 (edited) https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Setting-Up-TNFS-On-Windows-10 To make your TNFS server available on the public internet, on your router, configure “Port Forwarding” for UDP 16384 to the IP address of the Windows 10 box. If you have a domain name and it is configured to point to your external IP address, you should be good. If you do not have a domain name registered and configured, use https://whatismyipaddress.com/ to get your external IP address. To test from an external Fujinet device, enter either your domain name or external IP address into an external Fujinet and try to browse/load files from your TNFS server. Once you have your TNFS server working, lock it down. Create a new user that has read only access to the tnfsroot folder, then make that new user the user account that runs the task created above and uncheck "Run with highest privileges". Edited December 24, 2020 by CXL4002 link missing 1 Quote Link to comment Share on other sites More sharing options...
