fimbulvetr Posted December 22, 2020 Share Posted December 22, 2020 Does anyone know where to get or, failing that, how to make a printer cable for a TRS-80 Model 100? I have the Model 100 computer and a Tandy DMP-130, but no way to get between the two. I tried to bodge a printer cable together using a centronics to male DB25 parallel printer cable, connected to a flat ribbon female DB25 to IDC 26 cable, but that didn't work. The printer goes off line and refuses to respond when I plug it into either of my Model 100s. Same thing when I tried it with my Okidata Microline dot matrix. I know both printers work, and I know the cables are good, but that combination doesn't work. Quote Link to comment Share on other sites More sharing options...
Turbo-Torch Posted December 23, 2020 Share Posted December 23, 2020 No reason it shouldn't work if it's oriented correctly. https://www.ebay.com/itm/164211732622?hash=item263bc8308e: Depending on where you're located, it could take a while to get, but Ian is the best when it comes to TRS-80. 1 Quote Link to comment Share on other sites More sharing options...
fimbulvetr Posted December 24, 2020 Author Share Posted December 24, 2020 Well, problem solved! In the end I made my own cable exactly like the one you linked on ebay, and it worked perfectly. I didn't have the patience to wait for a cable to ship from Australia, and rooting around in my junk boxes turned up enough bits to build a cable like the one pictured I think in the end it was something to do with my parallel printer cable. I use that cable to print to my Okidata dot matrix printer from my windows desktop and my Tandy WP-2 (which has a standard DB25 parallel port), but it wouldn't work with either of those and the Tandy DMP-130 printer. Interestingly, the Tandy DMP-130 works fine with a USB to centronics cable and my windows desktop. 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 25, 2020 Share Posted December 25, 2020 You have to love eBay for the photographs alone. Many times I've found some great images of "historical value". It's cool you used it as a reference to make your own. Quote Link to comment Share on other sites More sharing options...
fimbulvetr Posted December 25, 2020 Author Share Posted December 25, 2020 Yeah, I wouldn’t have know where to line up the cable on the centronics end without a photo. 1 Quote Link to comment Share on other sites More sharing options...
