New Release: Realms of Antiquity The Shattered Crown
adamantyr
On 9/8/2023 at 1:57 PM, arcadeshopper said:
you will need to either
get a sidecar sams and sidecar tipi to attach to it
disable the 32k in your 32k/tipi combo and attach a sidecar sams after it providing enough power for both on the external power connector of tipi
"   "                        "    "                                           expansion box with sams peb card
So I will need this TIPI:
https://www.arcadeshopper.com/wp/store/#!/TIPI-SIDECAR-Raspberry-PI-interface-board-*44pin-interface-port-required*/p/103690282/category=115338525
And this SAMAS:
https://www.arcadeshopper.com/wp/store/#!/Sidecar-SAMS-with-44pin-header-for-TIPI/p/176285041/category=22255086
On 9/10/2023 at 6:17 PM, arcadeshopper said:
yes
or just the sams and use the tipi you have and disable it's 32k
Sorry but I get lost there. The SAMS in the shop has a header but I'm looking my Tipi and that board has no header. I have the one that uses the Pi Zero.
the 32k/tipi has a card edge on the side, that sams memory plugs into..
pretty sure i go over it in the video here:
clearly showing the card edge.. and you plug in the sidecar sams into that.. and i repeat .. you have to disable the 32k on your combo board to use sams as it also provides 32k and there can only be 1 32k device in a ti system
OK! Now I get it. Thanks a lot. I will wait for the FGROM99 and probably next month will put an order for one SAMS in the shop.
SUSCRIBED to the channel by the way. Great info!
