Need a .o to .lnx format converter
UHATEIT
Sorry for hashing this out this may be an easy solution for someone who knows this already. I recently got a bennvenn elcheapo as cart and it will only read .lnx format but some of the games found on Atari Gamer come up in .lyx or .o and will not load or work.
Is there a simple drop in program out there that you can drop them in and have the conversion spit out a .lnx format? I've used the one on Atari Gamer for .lnx to .lyx for the Agacart but now need one the other direction for .lyx and .o to .lnx if that's out there!
to convert a .lnx to a .lyx I think you can simply cut away the first 64 bytes of the rom.
If you can code it should be easy to make a simple program or script that does it.
Or you can use a program like Hexedit: load the rom file, select with the mouse the first 64 bytes (first 4 rows of 16 bytes), hit the Canc key and save the file.
