Keatah Posted January 15, 2021 Share Posted January 15, 2021 A small question. If the stella.pro file is no longer used, and its data is now placed in the stella.sqlite3 file.. how is the data handled when you change some settings for any game and then "default" them back to default? Does the entry stay in the database or is it removed? I would hope its removed so as not to clutter up the file with entries that will never be used again. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 15, 2021 Share Posted January 15, 2021 They get removed, just like they were removed in the stella.pro file too. 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted January 15, 2021 Share Posted January 15, 2021 (edited) Not sure the "delete from database" thing is working right then. This information remains after clicking [Defaults].. "Cart.MD5": "16cb43492987d2f32b423817cdaaf7c4", "Cart.Manufacturer": "Atari, Larry Kaplan - Sears", "Cart.ModelNo": "CX2602 - 99802, 6-99802, 49-75102", "Cart.Name": "Air-Sea Battle (1977) (Atari)", "Cart.Note": "AKA Target Fun (Anti-Aircraft)", "Cart.Rarity": "Uncommon", "Display.PPBlend": 81, "Display.Phosphor": "YES" ..but it does behave correctly. [Defaults] returns the game to default settings. Sorry if I'm being anal about it! Edited January 15, 2021 by Keatah Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 15, 2021 Share Posted January 15, 2021 I cannot confirm this. In my DB the entry is gone after changing back to defaults. Quote Link to comment Share on other sites More sharing options...
Keatah Posted January 15, 2021 Share Posted January 15, 2021 I just looked at the raw file in notepad. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 15, 2021 Share Posted January 15, 2021 Ok, that might explain it. The DB decides on its own when unused entries should be trimmed. If you want to see what is really stored, please use a tool like DB Browser for SQLite. 1 Quote Link to comment Share on other sites More sharing options...
Itchy Scratchy Posted January 15, 2021 Share Posted January 15, 2021 (edited) What would really be nice is if Stella started emulating the 7800 as well as have a modern looking interface. I would settle for just for the 7800. Excellent work BTW. Have been using Stella since near the beginning. Edited January 15, 2021 by Itchy Scratchy Quote Link to comment Share on other sites More sharing options...
Keatah Posted January 16, 2021 Share Posted January 16, 2021 Modern interfaces look like crap. 3 Quote Link to comment Share on other sites More sharing options...
+stephena Posted January 24, 2021 Author Share Posted January 24, 2021 Stella 6.5.1 has been released, addressing a few long-standing issues in the R77 port: Fixed paddle button bug for jittering controllers. Improve switching between joysticks and paddles on Retron77 port. Improve memory usage on Retron77 port. An interesting story. We (actually, @DirtyHairy) finally found the bug with the R77 port where the paddle button wasn't being registered. It turns out that the paddle readout hardware on the R77 is very poor, and coupled with a bad set of paddles, Stella was detecting the input being in error and then discarding it. So it took a bad set of paddles to figure out what was going on! And of course the other members of the team tested with relatively good paddles, so we could never narrow the problem down. You are now also able to change paddles and joysticks on the R77, and each will continue working. Previously, after using paddles, joystick movement was locked out, and a reboot was required. Anyway, continue to report bugs here, or by creating an issue on Github at https://github.com/stella-emu/stella/issues. Stella can be download at https://stella-emu.github.io/downloads.html, and donations are welcome at https://stella-emu.github.io/donations.html. 8 3 Quote Link to comment Share on other sites More sharing options...
+stephena Posted January 26, 2021 Author Share Posted January 26, 2021 Looks like we'll be having a 6.5.2 soon ... Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted January 26, 2021 Share Posted January 26, 2021 (edited) If 6.5.2 isn't about driving controllers, then I can't get driving controllers to work (tested with Indy 500) with 2600-daptor II or D9. Button works, steering works ironically on the selection menu but not in-game, confirmed both ports are set to Driving. Another minor UI bug: Setting V-Size adjust to -1 (negative one), exiting and then re-entering Video & Audio Settings results in the V-Size value not being printed in the UI (functionality is still fine). EDIT: Apologies, this was tested on R77. Edited January 26, 2021 by Rodney Hester Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 26, 2021 Share Posted January 26, 2021 Have you tried resetting the input? Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted January 26, 2021 Share Posted January 26, 2021 2 minutes ago, Thomas Jentzsch said: Have you tried resetting the input? I haven't...how do I do that? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 26, 2021 Share Posted January 26, 2021 Open the settings, switch to advanced settings and open the settings again. Then go into "Input..." and press `Defaults`. Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted January 26, 2021 Share Posted January 26, 2021 No change when resetting input. I started off with a clean install for this, just adding games and using defaults, if that helps. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 26, 2021 Share Posted January 26, 2021 Thanks for the feedback, we will look into this. Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted January 26, 2021 Share Posted January 26, 2021 (edited) I captured the below log if it helps. Currently the stock joystick is plugged into the front-left port and the 2600-daptor II (and a driving controller) into the first USB OTG port (with a keyboard in the third port, if it matters): Creating the OSystem ... Stella 6.5.1 Features: Sound Joystick PNG ZIP Build 6699, using SDL 2.0.9 [arm32] Base directory: '~/mnt/stella/' State directory: '~/mnt/stella/state/' NVRam directory: '~/mnt/stella/nvram/' Persistence: '~/mnt/stella/stella.sqlite3' Cheat file: '~/mnt/stella/stella.cht' Palette file: '~/mnt/stella/stella.pal' Video system: mali Renderer: opengles2 Max texture: 4096x4096 Flags: +vsync, +accel Added joystick 0: 'i2c_controller' with: 4 axes, 8 buttons, 0 hats Added joystick 1: 'i2c_controller #2' with: 4 axes, 8 buttons, 0 hats Added joystick 2: '2600-daptor II (emulates left joystick port)' with: 3 axes, 12 buttons, 0 hats Sound enabled: Volume: 100% Device: Default Channels: 2 (Mono) Preset: Custom Fragment size: 512 bytes Sample rate: 48000 Hz Resampling: Quality 2, Lanczos (a = 2) Headroom: 2.5 frames Buffer size: 3.0 frames Game console created: ROM file: ~/mnt/games/driving/Indy 500.2K Cart Name: Indy 500 (1977) (Atari) Cart MD5: c5301f549d0722049bb0add6b10d1e09 Controller 0: Driving in left port Controller 1: Driving in right port Display Format: NTSC* Bankswitch Type: 2K (2K) Edited January 26, 2021 by Rodney Hester Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted January 27, 2021 Share Posted January 27, 2021 Thanks, but the problem is in our code. Its been there undetected for 4 releases. Looks like the DC is hardly ever used. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 29, 2021 Share Posted January 29, 2021 I am running a PlusCart as my hardware host on my '2600 units. I am seeing strange behaviour on the positioning of digits on hardware vs. Stella 6.5.1, as shown in the images. The test binary was pulled from an AA thread. On Stella, centered, evenly spaced digits. On PAL JR and NTSC JR I see the identical difference to Stella; digits positioned to the right, and poorly spaced. Also, the visuals are quite different This would appear to me to be a Stella bug since I'm seeing the same on two '2600 units, but I suppose it could also be PlusCart? @Al_Nafuur @Thomas Jentzsch Hardware screenshot... Aside from the digit location and inter-digit spacing, the "stars" are very different, too. Each machine is slightly different to Stella. Glitch2.bas.bin Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 29, 2021 Share Posted January 29, 2021 (edited) 15 minutes ago, Andrew Davie said: This would appear to me to be a Stella bug since I'm seeing the same on two '2600 units, but I suppose it could also be PlusCart? Same behaviour on my UnoCart, so this points towards a Stella bug..? Or I just lucked onto two different machines (PAL, NTSC) which happen to be odd... Edit: changed the cart type to UnoCart! Edited January 29, 2021 by Andrew Davie Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 29, 2021 Share Posted January 29, 2021 7 minutes ago, Andrew Davie said: I am running a PlusCart as my hardware host on my '2600 units. I am seeing strange behaviour on the positioning of digits on hardware vs. Stella 6.5.1, as shown in the images. The test binary was pulled from an AA thread. On Stella, centered, evenly spaced digits. On PAL JR and NTSC JR I see the identical difference to Stella; digits positioned to the right, and poorly spaced. Also, the visuals are quite different This would appear to me to be a Stella bug since I'm seeing the same on two '2600 units, but I suppose it could also be PlusCart? @Al_Nafuur @Thomas Jentzsch Hardware screenshot... Aside from the digit location and inter-digit spacing, the "stars" are very different, too. Each machine is slightly different to Stella. Glitch2.bas.bin 4 kB · 1 download The colours are different on my PAL 2600jr but the digit spacing and position looks the same.. btw. you can put test ROMs like this into a folder (like "Andrew Davie Test ROMs") and share that folder with other PlusCart users, so your tester on PlusCart don't have to download from AA and upload to the PlusStore themself and will always test the newest version. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 29, 2021 Share Posted January 29, 2021 2 minutes ago, Al_Nafuur said: The colours are different on my PAL 2600jr but the digit spacing and position looks the same.. btw. you can put test ROMs like this into a folder (like "Andrew Davie Test ROMs") and share that folder with other PlusCart users, so your tester on PlusCart don't have to download from AA and upload to the PlusStore themself and will always test the newest version. Will do. But maybe we should have a global "Test ROMs" directory for this purpose? Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 29, 2021 Share Posted January 29, 2021 I think two things are going on here: 1. The starfield effect has a substructure that is not easily explained by the interaction of the sprite counters. This is emulated on a heuristic basis by Stelle for the missiles and ball (the different lengths of the dots on subsequent lines), but not for the players. I believe there is an issue for this somewhere 2. From looking at the debugger, it seems that the HMOVE logic is still in "starfield mode" when RESP0 / REPS1 are strobed, and HMOVE is only strobed after that. The result depends on the revision of the TIA chip and also the temperature of the chip. PAL and NTSC makes no difference --- both are Jr. chips which is the decisive point. It would be nice to have a data point on an older console. 2 Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted January 29, 2021 Share Posted January 29, 2021 For reference: https://github.com/stella-emu/stella/issues/246 That one has a lot of screenshots and images of the differences between various TIA revisions for missiles in "starfield mode" and explains the issue. https://github.com/stella-emu/stella/issues/19 This is the original starfield issue. It is still open as the details of the player substructure are not emulated yet. 1 Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 29, 2021 Share Posted January 29, 2021 Just now, Andrew Davie said: Will do. But maybe we should have a global "Test ROMs" directory for this purpose? This would imply that every PlusStore user can upload to this public "Test ROM" folder? The registration at the PlusStore is open to everyone and currently there are about 100 PlusStore User, but not all of them have a PlusCart connected to their account. Not all of them can use the share function, because I don't want people to use the PlusStore as sharing platform for every kind of stuff. Quote Link to comment Share on other sites More sharing options...
