+Karl G Posted August 23, 2021 Share Posted August 23, 2021 2 hours ago, Thomas Jentzsch said: Not necessary. The link is already there. See Todo List. Ahh - I had missed that. It may not be an obvious place to look for someone who wishes to report a bug, however. Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted August 24, 2021 Share Posted August 24, 2021 On 7/6/2021 at 10:34 PM, Rodney Hester said: I've found a rather fascinating but harmless bug that only seems to affect the R77 build. The "items found" count on the main games path is one less than the number of games actually present/listed. It's not that any are 'missing', if you hand count them, it's always 1 higher than the count displayed in the upper right. This doesn't happen on the Windows build, at least. I confirmed there is indeed a fixed subtraction of 1 from the count for the top-level and subdirectories in stella/src/gui/LauncherDialog.cxx: 434 buf << (myList->getList().size() - 1) << (myShortCount ? " found" : " items found"); whereas it should only be subtracted from subdirectories on the Retron 77. The following inelegant version of the affected function solves it for R77, it's unknown to me whether the same situation exists on Unix/MacOS: void LauncherDialog::updateUI() { int countOffset = 1; #if defined(RETRON77) countOffset = (currentDir().hasParent() ? 1 : 0); #endif // Only hilite the 'up' button if there's a parent directory if(myPrevDirButton) myPrevDirButton->setEnabled(myList->currentDir().hasParent()); // Show current directory myDir->setText(myList->currentDir().getShortPath()); // Indicate how many files were found ostringstream buf; buf << (myList->getList().size() - countOffset) << (myShortCount ? " found" : " items found"); myRomCount->setLabel(buf.str()); // Update ROM info UI item loadRomInfo(); } A corrected release build of 6.5.3 in SD card form is attached if anyone's interested in my pedantry. sdcard.img 2 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 25, 2021 Share Posted August 25, 2021 Thanks, I have added your fix to Stella. Quote Link to comment Share on other sites More sharing options...
Rodney Hester Posted August 26, 2021 Share Posted August 26, 2021 23 hours ago, Thomas Jentzsch said: Thanks, I have added your fix to Stella. Thank you, confirmed as working with full build of 6.6 pre on R77. Quote Link to comment Share on other sites More sharing options...
Obadiah64 Posted October 16, 2021 Share Posted October 16, 2021 I have a question about moving "Snapshots" from default location. When ever I do that, Stella seems unable to retrieve the image or display it in the "Snapshot" panel. It will store the image in the new location, but will not display it in the main screen of the UI. If I move it back to default, everything works fine. I know it is probably something simple I am over looking, but for right now it has me stumped. Quote Link to comment Share on other sites More sharing options...
Obadiah64 Posted October 16, 2021 Share Posted October 16, 2021 Ok never mind. As usual, as soon as I make a post I figure it out. Thanks any ways. Quote Link to comment Share on other sites More sharing options...
