k-Pack Posted January 15, 2021 Share Posted January 15, 2021 This is from the Diamond 3.0 GOS user manual on page 8. "Command Line Files with a COM extender are considered to be Command Line files. When executing such files you will be asked to enter various parameters. This allows various options to be passed from the DeskTop to another program. If you do not need any parameters to be entered then simply press RETURN and the program will be executed as if it were a normal APP. The command line used by Diamond is not the same as the one used by SpartaDOS, however Diamond's command line is SpartaDOS compatible when SpartaDOS is active." I don't know of any reason why the command line can not be used with the FujiNet commands but it will be some time before I can experiment. If anyone has had any experience with the Diamond command line and FujiNet COMs please consider sharing them with me/us. Quote Link to comment Share on other sites More sharing options...
