Pfheights error
Captain Spazer
I am not sure what I am doing wrong but when I try using pfheights 2600basic.exe stops working.
The error message says:
Quote
Warning: Unable to open '2600basic_variable_redefs.h'
C:\2600 Projects\Karate\default.bas.asm (1226): error: Syntax Error ''.
Unrecoverable error(s) in pass, aborting assembly!
Complete.
Errors were encountered during assembly.
In the code I got
 set romsize 8k
 set kernel_options player1colors playercolors pfcolors pfheights background
main
   pfheights:
end
   pfcolors:
   $f5
   $f5
   $f5
   $26
   $1A
   $1A
   $1A
   $1A
   $26
   $00
   $00
   $00
end
drawscreen
 goto main
Is the error as simple as I don't got enough space left in bank1? I have 186 bytes left in bank1 and 1251 bytes left in bank2.
Another debug trick is to look at the generated assembly file. Even if you don't know assembly, you can open it up and look at the line number it gives. Usually above the line of assembly you will see the bB code that it converted into assembly, and can sometimes figure out what is wrong with that line to have generated the assembly error.  In your case, that would be line 1226 in default.bas.asm.
  • Thanks 2
