+Eyvind Bernhardsen Posted March 17, 2021 Author Share Posted March 17, 2021 There are screw holes for the D-sub connectors as long as you get connectors without board locks, my vague plan was to use them. As I said above, though, I haven't given much thought to the case yet; suggestions are welcome ? Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted March 21, 2021 Author Share Posted March 21, 2021 On 3/17/2021 at 5:52 AM, Bobo Cujo said: I don't think it's a bad idea to have the ICSP header - imagine flashing different versions of the firmware if someone wants a different button layout... Good point. I've uploaded a new version of my PR with three different PCB variants: the original ICSP version, the smaller version from my previous update, and a minified one with solder cup edge connectors like @manterola's (that one was tricky to design). Still waiting to receive my first lot from OSH Park. Here's the new PCB: 2 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted April 25, 2021 Author Share Posted April 25, 2021 The postal service finally delivered my PCBs! Now to learn 3D printing so I have something better than electrical tape to wrap the adapter in. I made one with header pins for programming, but skipped them on this one. The DE9 connector felt a bit wobbly so I secured it with a couple of machine screws. 3 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted April 25, 2021 Author Share Posted April 25, 2021 Here's the BOM, with part numbers from Digikey. In addition you'll need the female end of a fully-connected joystick cable for the pigtail. The pin headers are optional, needed only if you want to enable C64 mode and/or program the PIC in-circuit. The nine-pin header easily snaps apart, just make sure you end up with a three-pin and a six-pin header. Sega adapter BOM.csv 1 Quote Link to comment Share on other sites More sharing options...
Mathy Posted April 25, 2021 Share Posted April 25, 2021 Hello Eyvind 5 hours ago, Eyvind Bernhardsen said: In addition you'll need the female end of a fully-connected joystick cable for the pigtail. Would a joystick extension cord work if a (female?) DB9 connector was soldered in? Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted April 25, 2021 Author Share Posted April 25, 2021 1 hour ago, Mathy said: Would a joystick extension cord work if a (female?) DB9 connector was soldered in? As long as the extension cord is fully connected I see no reason why it shouldn't. Here's the closest female correspondent to the male connector I could find that's in stock at Digikey: https://www.digikey.no/product-detail/no/te-connectivity-amp-connectors/5745131-1/A33980-ND/1123756. Others may work, the important thing is that it's a .318" mount. 1 Quote Link to comment Share on other sites More sharing options...
manterola Posted April 26, 2021 Share Posted April 26, 2021 (edited) I was working in a PCB version with both options: the edged D-Sub 9 connector or soldered pigtail + holes for plastic tie (for strain relief). It is not ready yet. And I am not sure it really adds to what you have done. Edited April 26, 2021 by manterola 3 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted April 26, 2021 Author Share Posted April 26, 2021 48 minutes ago, manterola said: I was working in a PCB version with both options: the edged D-Sub 9 connector or soldered pigtail + holes for plastic tie (for strain relief). It is not ready yet. And I am not sure it really adds to what you have done. That’s interesting! How did you come up with the idea for the strain relief slots? I think the capacitor could be moved under the PIC (which would need to be socketed) and the pins for the pigtail could be squeezed closer together, if you wanted to make it even more compact. Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted August 21, 2021 Author Share Posted August 21, 2021 This project has been on hold after long, possibly COVID related, shipping delays on pretty much everything I've ordered in the past year, but the last bits finally arrived and I'm ready to announce the next generation SEGA Megadrive controller adapter: The big changes are that it's smaller, and instead of a D-sub connector or a soldered-in pigtail it uses a detachable ribbon cable to connect to the computer. There's still a jumper to switch to C64 mode, for people so inclined. Boards can be ordered from OSH Park, and there is a BOM with DigiKey part numbers in the GitHub project. Unfortunately the microcontroller seems to be out of stock at the moment. This is still a DIY project, so you'll have to order parts, assemble them, and program the microcontroller yourself. It's open hardware: the source code is MIT licensed and the schematics are CC-BY-4.0. I don't think I can make the board any smaller without switching to surface mount parts so the next step will be to make a 3D-printed case. Please don't hold your breath. 5 Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 21, 2021 Share Posted August 21, 2021 Ordered the requisite 3 boards from OSHPark, This will be great with the 8bitdo sega retro receiver. Thanks! Mouser have the PIC in stock https://www.mouser.com/ProductDetail/579-PIC16F1847-I-P 1 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted August 28, 2021 Author Share Posted August 28, 2021 Minor breakthrough: I figured out that the reason I couldn't read the X, Y, Z, and MODE buttons was timing related, and managed to fix the problem. I have some ideas for using the extra buttons. In the meantime here's a preliminary build where X, Y, and Z simply shadow the A, B, and C buttons. segaprog.atr Note that I still only have 8bitdo adapters to test with (an order of Sega controller knockoffs from China was one of the deliveries that never arrived), and since this was a timing problem, different controllers might not work. Please report back if it doesn't work for you. 1 Quote Link to comment Share on other sites More sharing options...
manterola Posted August 29, 2021 Share Posted August 29, 2021 I hope @Mr Robot can come up with a case for it... Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 29, 2021 Share Posted August 29, 2021 My mouser order has arrived. I’m still waiting for Oshpark. I have some really crap genesis knockoff controllers here. @Eyvind Bernhardsen pm me your address I’ll send you one to play with. 1 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted August 29, 2021 Author Share Posted August 29, 2021 Here's a build that has autofire for A, B, and C on X, Y, and Z, the simplest use I could think of. segaprog.atr The fire rate is around 12 Hz. I don't think it's possible to go above 12.5 Hz for buttons 2 and 3 (on PAL systems, 15 on NTSC) because charging the pot capacitors takes time and they are only drained once every frame, so the adapter needs to hold the button state for at least two frames to make sure the computer will notice. Could do a faster rate for button 1 or use the buttons for something else entirely, and the MODE button can be used to switch modes if necessary. Ideas welcome! Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted August 13, 2022 Author Share Posted August 13, 2022 On 8/29/2021 at 6:14 AM, Mr Robot said: My mouser order has arrived. I’m still waiting for Oshpark. I have some really crap genesis knockoff controllers here. @Eyvind Bernhardsen pm me your address I’ll send you one to play with. @Mr Robot did send me a knockoff controller, which sadly did not work with the initial six-button support. With the help of my shiny new logic probe I've finally been able to work out why! It turns out that microseconds count, especially when talking to dumb electronics. Here's release v0.4, with more compatible six-button support and a slightly speeded-up autofire: segaprog.atr 2 Quote Link to comment Share on other sites More sharing options...
Mr.Holub Posted August 20, 2022 Share Posted August 20, 2022 I've made an enclosure for compact version of the PCB. It is published here: https://www.thingiverse.com/thing:5471806 1 Quote Link to comment Share on other sites More sharing options...
Mr.Holub Posted September 4, 2022 Share Posted September 4, 2022 I've used programmer T866II Plus for programming PIC 16F1847. As PIC 16F1847 is not in the list of supported devices, I had to do the following trick: Select PIC16F1827 @DIP18 (different version of this line with less RAM). Disable option "Check ID" in order to force flashing. Adapter works perfectly, it just makes me wondering whether this particular MCU is so uncommon that it was missing in the list... 1 1 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted September 4, 2022 Author Share Posted September 4, 2022 Thanks for the info! The 1827 might even be an alternative microcontroller for this project, but since the price is pretty much the same I’m not sure it’s worth the effort to try. I went with the 1847 because I’d already programmed a few with the Joy2PIC, so I knew that would work. Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted September 4, 2022 Author Share Posted September 4, 2022 Oh, here's a small update I've been meaning to post. It's possible to stack adapters using 12 and 15 mm PCB spacers: 12mm spacers go on top of the DE-9 connector, 15mm spacers either side of the IDC connector. I know @Mr.Holub's case won't fit this version, but maybe it could be stretched a bit? Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted September 17, 2022 Author Share Posted September 17, 2022 Another update, this time to the firmware. After looking at the SNACK SNES controller adapter, I wondered if it would be possible to emulate its enhanced mode to be able to address all of the buttons (sort of) independently. It turned out to be tricky to do because of the way my adapter is wired: SNACK uses the pots for joystick X and Y axes, and getting the timing right to charge the pot capacitors to the right range with no resistors took some trial and error. The A, B, X, and Y buttons are used for B, A, Y, and X to avoid mirroring the button layout (this might be familiar to you if you've ever switched between Nintendo and Xbox controllers). The Z and C buttons are the left and right shoulder button, respectively, and MODE is SELECT. Only the shoulder buttons are completely independent of other buttons. A and B are independent of each other, but X, Y, SELECT, and START will override them, and only one of those buttons is registered at a time. This is how SNACK is able to read all of the buttons. Left/right/up/down might be temperature dependent, may depend on your exact model of Atari and the length of your joystick cable, and I'm not sure if the timing works on NTSC, but here's a test version anyway. Holding down MODE switches between normal and SNACK mode. segaprog-0.5-test1.atr 2 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted September 18, 2022 Author Share Posted September 18, 2022 Minor change: I decided to use the same buttons as SNACK to switch between normal and SNACK mode. MODE+START+right shoulder switches to SNACK mode, MODE+START+left shoulder goes back to normal mode. segaprog-0.5-test2.atr 1 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted September 19, 2022 Author Share Posted September 19, 2022 And a bug fix: the A-is-Up feature isn't available in SNACK mode but the START key toggle for it was still active, which prevents holding the START key down for more than half a second. Deactivated the toggle in SNACK mode. segaprog-0.5-test3.atr Quote Link to comment Share on other sites More sharing options...
Mr.Holub Posted September 20, 2022 Share Posted September 20, 2022 On 9/4/2022 at 5:24 PM, Eyvind Bernhardsen said: Oh, here's a small update I've been meaning to post. It's possible to stack adapters using 12 and 15 mm PCB spacers: 12mm spacers go on top of the DE-9 connector, 15mm spacers either side of the IDC connector. I know @Mr.Holub's case won't fit this version, but maybe it could be stretched a bit? Well not sure if I would be able to do this in correct tresholds (I don't have these spaces), however it should be easy to remix my model to put 2 boxes together without need of spacers. 1 Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted January 30 Author Share Posted January 30 I've now tested the SNACK support enough, by playing Attack of the PETSCII Robots, to make a proper release announcement: version 0.6 of the adapter firmware is available on the GitHub page. The button mapping is different when using an Xbox or PlayStation controller connected to an 8BitDo Retro Receiver, so I've added an extra SNACK mode to support those controllers. To switch to SNACK enhanced mode on a Mega Drive controller, press Mode+Start+C; on an Xbox or PlayStation controller, Mode+Start+left trigger. Mode+Start+Z (right trigger on Xbox/PlayStation controllers) switches back to Joy2B+ mode. 1 Quote Link to comment Share on other sites More sharing options...
