tschak909 Posted January 20, 2021 Share Posted January 20, 2021 Part of #FujiNet's integration, relies on needing to make calls to the #FujiNet itself to access the network (and potentially WiFi MODEM). Because RunCPM provides its own BIOS and BDOS in C, and this is being compiled into the firmware, it's possible to add new commands that talk to the ESP32 firmware. To start, I've implemented BDOS command 176, which gets the current FujiNet network config, and places it in the buffer provided by registers DE to specify the target address in Z80 space, consistent with many other BDOS calls. It looks like this: The implementation in the firmware is here: https://github.com/FujiNetWIFI/fujinet-platformio/blob/master/lib/runcpm/abstraction_fujinet.h#L507 You can see, it literally: * Sets up a data structure for the network config * Fills it * Transfers it into Z80 memory at the address specified by the function parameter addr. Once this is implemented, hooking into the BDOS is as simple as adding a case statement in bdos() here: https://github.com/FujiNetWIFI/fujinet-platformio/blob/master/lib/runcpm/cpm.h#L809 Once there, it can be called from inside CP/M as a BDOS call, e.g. in C I call it like this: struct { char ssid[32]; char hostname[64]; unsigned char localIP[4]; unsigned char gateway[4]; unsigned char netmask[4]; unsigned char dnsIP[4]; unsigned char macAddress[6]; unsigned char bssid[6]; char fn_version[15]; } cfg; bdos(176,&cfg); // call BDOS, on return, network config is in cfg struct. printf("My IP Address is: %u.%u.%u.%u\n",localIP[0],localIP[1],localIP[2],localIP[3]); This will be extended to support all of the BDOS functions needed to implement the current crop of fnc-tools for CP/M. 2 Quote Link to comment Share on other sites More sharing options...
