Weird Cable
Jason_Atari
Yep, Emerson is correct. That is an Apple II joystick cable. You connect the DIL to the motherboard and pull the cable through somewhere to connect an analog Apple II joystick (not compatible with Atari standard). Or maybe there are electronics involved not seen on the picture, converting digital Atari signals to analog Apple signals?
Edited by carlsson
Close, but it's it's an adapter for plugging in older Apple II controllers to an Apple //e. The controllers had the male DIL 16 connectors, so you'd connect the old controller to the female DIL socket on the cable, then you'd connect the other side of the cable to the controller port on the back of your Apple //e, which happens to be a female Dsub-9 connector.
Edited by bluejay
Thanks for all the replies :)
