+Andrew Davie Posted February 4, 2021 Share Posted February 4, 2021 I'm certain I made the UP action on the menu behave as a line-up, not a page-up. That is, when you're on the top line of a page, then UP should take you to the bottom line of the previous page. It's not functioning like that at the moment. Is this a deliberate change/revert? It makes total sense to me, so you can use left/right for paging, and up/down for line moves. I had an item on the bottom of the previous page I wanted, so I pressed UP... and I'm now having to press DOWN another 13 times to get to it. With the way I set it up before, I could just press UP and I'm on the item. Can we please change this back? Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 4, 2021 Author Share Posted February 4, 2021 Maybe it's a bug in the code because of the line spacing and a misunderstanding of how many lines/screen. Will check. Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 4, 2021 Author Share Posted February 4, 2021 OK, I know what it is. I'll push a fix soon. Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 4, 2021 Author Share Posted February 4, 2021 @Al_Nafuur fixed. Pushed. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted February 4, 2021 Share Posted February 4, 2021 3 minutes ago, Andrew Davie said: @Al_Nafuur fixed. Pushed. can you build and send me the binary (the *.bin file) with the version number set to "v1.0.1b" to upload to the PlusStore for the beta tester? I have too many changes and untracked files in my local "reunion" branch and last time I stashed them all away it was a drag to restore them all. Link to comment Share on other sites More sharing options...
