a8isa1 Posted February 8, 2021 Share Posted February 8, 2021 Unable to build Fujinet-Flasher I had been using manual flashing with esptool.py using the following command line which had been provided to me: python esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 bootloader.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin With firmware for 2/4/2021 I thought I had a success but discovered the new "COPY" feature was not available. I confirmed from the web interface that an update to the firmware had been completed. Looking at the command I realized the spiffs.bin wasn't being updated. I tried to add it. not knowing where it belonged I tried adding to the end. Had insufficient twice. One time this didn't happen but neither was the COPY function available. After a few more attempts something seriously went wrong. After flashing the 3 LEDs blinked for 1 second then my #FujiNet went dark. I tried the update as done above. Still dark.I I tried to restore the original firmware with which my #FujiNet had been supplied. Restore was from a backup which I had made first thing. Still dark I feel as though I have wiped SPIFFS and just don't know where it belong but perhaps I have done worse. Is my error recoverable from here. I mean my location? Did I brick my #FujiNet? -SteveS Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 8, 2021 Share Posted February 8, 2021 11 minutes ago, a8isa1 said: Unable to build Fujinet-Flasher I had been using manual flashing with esptool.py using the following command line which had been provided to me: python esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 bootloader.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin With firmware for 2/4/2021 I thought I had a success but discovered the new "COPY" feature was not available. I confirmed from the web interface that an update to the firmware had been completed. Looking at the command I realized the spiffs.bin wasn't being updated. I tried to add it. not knowing where it belonged I tried adding to the end. Had insufficient twice. One time this didn't happen but neither was the COPY function available. After a few more attempts something seriously went wrong. After flashing the 3 LEDs blinked for 1 second then my #FujiNet went dark. I tried the update as done above. Still dark.I I tried to restore the original firmware with which my #FujiNet had been supplied. Restore was from a backup which I had made first thing. Still dark I feel as though I have wiped SPIFFS and just don't know where it belong but perhaps I have done worse. Is my error recoverable from here. I mean my location? Did I brick my #FujiNet? -SteveS Not possible to brick it. I am guessing the copy feature didn't make it into the build. Simply running the fujinet flasher and letting it download should be sufficient. -Thom Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted February 8, 2021 Author Share Posted February 8, 2021 I don't have the ability to run the Fujinet-Flasher. Laptop is crippled so I'm running live with RAM file system and I don't have the necessary resources. This is also why I am using ESPTOOL.PY. Where does SPIFFS.BIN belong? What offset? -SteveS Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 8, 2021 Share Posted February 8, 2021 The current partitions file we use is: # Name, Type, SubType, Offset, Size, Flags nvs, data, nvs, 0x9000, 0x5000, otadata, data, ota, 0xe000, 0x2000, app0, app, ota_0, 0x10000, 6M, app1, app, ota_1, ,6M, spiffs, data, spiffs, ,2M, that is, add the offset of the previous segment + size to get the offset of the next. -Thom Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 8, 2021 Share Posted February 8, 2021 9 minutes ago, a8isa1 said: I don't have the ability to run the Fujinet-Flasher. Laptop is crippled so I'm running live with RAM file system and I don't have the necessary resources. This is also why I am using ESPTOOL.PY. Where does SPIFFS.BIN belong? What offset? -SteveS python3 esptool.py --chip esp32 --port "/PATH/TO/YOUR/SERIAL/PORT" --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 bootloader.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin 0xc10000 spiffs.bin 1 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted February 8, 2021 Author Share Posted February 8, 2021 1 hour ago, mozzwald said: python3 esptool.py --chip esp32 --port "/PATH/TO/YOUR/SERIAL/PORT" --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 bootloader.bin 0x8000 partitions.bin 0xe000 boot_app0.bin 0x10000 firmware.bin 0xc10000 spiffs.bin Back in business! Thanks! Never would have tracked down that offset for SPIFFS on my own. Regards, -SteveS 2 Quote Link to comment Share on other sites More sharing options...
