+9640News Posted February 11, 2021 Share Posted February 11, 2021 The files for the GPL interpreter are Gram Kracker style files with at maximum, 8K per each file for each bank of rom/ram/grom as the module was designed. 1 Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750133 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 I picked up one, the EA. Is there a repository of these? I did figure how to get one loaded. Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750144 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 (edited) 2 hours ago, mizapf said: Unless you have a TI disk controller, I'd always recommend to go for double density (/18 instead of /9). Better than 80 tracks with single density, double density means (almost) double speed. Yup..ti controller. But not so much that, but the Dr itself can't do double density, but it can do double sided. I've got a modded ti controller, with 40,80,80, I need to change the drive. But I was hoping to access tipi and not so much worry about the fl drive. Ok, next question, how do get into ROMPAGE and access my tipi drive? Edited February 11, 2021 by GDMike Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750151 Share on other sites More sharing options...
+9640News Posted February 11, 2021 Share Posted February 11, 2021 At the GPL Interpreter, press F5 for Rompage mode. If you are using GPL V6.50, it is on the screen. If you need to load the Editor/Assembler or say the Extended Basic module for whatever you want to do/access on the TIPI, do the following when GPL loads. First, at the GPL screen, type the DSK1.FILENAME of the module file you want to load. I just posted in another topic area, MODULES.ZIP that contain all the modules I have. OK, after the module is loaded, it will proceed to the next screen. So, you are not ready at this point to access in Rompage mode the TIPI. You need to press CTRL-SHIFT-SHIFT to return back to the GPL Interpreter, and press F5 to select Rompage mode. This will return you either to the TI Title Bar Screen or either a 40/80 column screen dependent if someone has some modified GPL grom files. While in Rompage mode, you can then load things from TIPI. With a TI disk controller, I am not certain you can copy things from the TIPI to a FDC controlled Gotek. You might, but not 100% sure. Beery 1 Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750175 Share on other sites More sharing options...
+mizapf Posted February 11, 2021 Share Posted February 11, 2021 9 hours ago, GDMike said: Yup..ti controller. But not so much that, but the Dr itself can't do double density, but it can do double sided. Oh, is that so? I don't know of drives that do not support double density; is that explicitly stated in the specs? The actually hardware-dependent features are 80 track (narrower tracks) and high density (different magnetic head). DD is just another encoding with smaller cells. As if you switched from Country Waltz to Metal. As for the TI controller, I'm still surprised how common it is still today. Before that topic came up some years ago, I honestly thought the TI controller was almost gone, hence, in my TIImageTool I set double density as the default. I switched to DD in the late 80es, I don't remember if I even waited for my original TI controller to fail before I got a new controller. We had quite a selection to choose from: Myarc HFDC, DDCC-1, CorComp, Atronic, BwG come to my mind. But it's probably too late to spend so many thoughts about floppies. ? 1 Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750393 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 Yeah, I'm pretty sure there's a cap on this teac hh. There is, somewhere, a spreadsheet of this drive and by serial number,model it says what it supports. I'm thinking I saw this limit on the sheet. But I'll have to DBL check, now.. Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750494 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 13 hours ago, BeeryMiller said: and press F5 to select Rompage mode. Ok. Did that, and If I hit F5 and my ea menu shows up, pressing 1 for edit will not load dsk1.edit1. but if I do not press F5 and press enter instead, my option 1 for EA loads.i tried clearing rom space, turning emulation for dsk1 off and on... Continuing to see if I can see TIpi Ty Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750505 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 (edited) Genius!! Berry, your awesome!!!! But error when trying to copy Edited February 11, 2021 by GDMike Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750507 Share on other sites More sharing options...
GDMike Posted February 11, 2021 Share Posted February 11, 2021 (edited) But I'm able to copy between tipi drives. Man, that was close. But at least I can RUN applications. Edited February 11, 2021 by GDMike Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750511 Share on other sites More sharing options...
+9640News Posted February 11, 2021 Share Posted February 11, 2021 I'm not sure on the TI-99/4A, but on the Geneve when you want to catalog and copy files, it is best to address it as device DSK0, not TIPI. At present, unless things change, for a Geneve with a TIPI, the TIPI's CRU will need to be at >1800. Just giving you a head's up as I see your TIPI CRU is at >1000 (the default when shipped). With the PFM's that are out there that allow loading MDOS onto the PFM, not the entire MDOS will fit on the smaller size PFM. Both SCSI, TIPI, and I think IDE code is loaded separately once MDOS boots if you boot from a PFM. Users without PFM's will be able to boot without issue as always. Beery Quote Link to comment https://forums.atariage.com/topic/316967-gotek-as-dsk1-question/page/2/#findComment-4750568 Share on other sites More sharing options...
