Action! DEFINE string
How does one use DEFINE to set a string value?  Such as:
DEFINE SSREADY = "TEST"
PROC Main()
  PrintF("SSREADY=[%S]%E", SSREADY)
RETURN
This will not compile correctly as TEST is SSREADY is replaced by TEST without quotes.
Double quoting results in syntax error, but it is how you embed a double quote in a string.  I've tried these as well which won't work either:
DEFINE SSREADY=""TEST""
DEFINE SSREADY='"TEST"'
Is this just not possible with Action!?
Fun way to use DEFINE in Action!
DEFINE PLUS = "+"
DEFINE I = "+"
DEFINE TRZY = "3"
DEFINE DZIESCI = "* 10"
DEFINE PISZ = "PRINTF(""%U%E"", "
DEFINE NA = ")"
DEFINE EKRAN = ""
PROC MAIN()
  PISZ TRZY DZIESCI I TRZY PLUS TRZY NA EKRAN
  PISZ TRZY PLUS TRZY I TRZY NA EKRAN
RETURN
Most common way:
DEFINE RIGHT = "1"
DEFINE LEFT = "-1"
DEFINE UP = "-40"
DEFINE DOWN = "40"
DEFINE XY="+40*"
    IF STICK0=7 AND PLAYERPOS(RIGHT)=NOTHING
      THEN PLAYERPOS ==+ RIGHT FI
    IF STICK0=11 AND PLAYERPOS(LEFT)=NOTHING
      THEN PLAYERPOS ==+ LEFT FI
    IF STICK0=13 AND PLAYERPOS(DOWN)=NOTHING
      THEN PLAYERPOS ==+ DOWN FI
    IF STICK0=14 AND PLAYERPOS(UP)=NOTHING
      THEN PLAYERPOS ==+ UP FI
Edited by zbyti
common way
DEFINE PLUS = "+"
DEFINE I = "+"
DEFINE TRZY = "3"
DEFINE NA = ")"
DEFINE EKRAN = ""
PROC MAIN()
RETURN
I am pretty sure, this way madness lies :)
  • Haha 1
I understand what its intent is and what it does.  I dont understand how or if it works with string values.  I have no issues with numberic values.  I think maybe I misconveyed what I'm trying to do.  From the complex example in the reply, the double quoted double quotes dont achieve the desired result.
From my code, I want to achieve:
PROC Main()
RETURN
into Net result:
  PrintF("SSREADY=[%S]%E", "TEST")
I found the solution.  Since DEFINE needs double quotes surrounding the value, the double quotes I want around the string need the second set of double quotes, which means there are 3 double quotes around the text.  To add to the confusion, there must be a space between the 1st and 2nd/3rd (pair), same on the end.
This works:
DEFINE SSREADY = " ""TEST"" "
PROC Main()
RETURN
translates to result:
  PrintF("SSREADY=[%S]%E",  "TEST" )
and produces output:
SSREADY=[TEST]
If you cram all the quotes together it doesn't work right.
This works:
PROC Main()
RETURN
SSREADY=[TEST]
I consider it a bug not future. But hey, it's Action! if it works then works :D
Yeah, it's not clear why that works. Here are the relevant parts from the cartridge:
; <def dcl> ..:= DEFINE <def list>
; <def list> ..:= <def list> , <def> | <def>
; <def> ..:= <id> = <str const>
dcl200  jsr     mkent                ; DEFINE - create name
        ldy     #0
        lda     #defid         ; store data type
        sta     (props),y
        jsr     getnxt
        cmp     #eqlid         ; always have to have
        bne     dclerr         ; an assign for define
        lda     nxttkn
        cmp     #quote
        bne     dclerr
        ldy     #0
        lda     (symtab),y
        clc
        adc     #2              ; real size + EOL
        jsr     stincr         ; save string from overwrite
        jsr     getnxt          ; string itself
        jsr     getnxt          ; dummy string
        jsr     getnxt
        cmp     #comma         ; look for more
dcl210  bne     dcl140         ; whoops, go back some
        beq     dcl200
dclerr  ldy     #dcler
        jmp     splerr
So the cart is trying to pull three tokens following the "=", which I don't quite understand. The first getnxt will be to pull the first quote forward to enable the string getter to build the string token:
;       LexStr()
lexstr  lda     token
        cmp     #quote
        beq     pback           ; zap local st
        lda     #0
        sta     arg9
lxs010 jsr      nxtchr
        inc     arg9
        beq     lxs030          ; string too long
        cmp     #'"
        beq     lxs040
lxs020 ldy      arg9
        sta     (symtab),y
        lda     chan
        bpl     lxs010          ; if not EOF
lxs030 ldy      #strer
        jmp     splerr
lxs040 jsr      nxtchr
        cmp     #'"
        beq     lxs020          ; " in string
                                ; end of string
        ldy     arg9
        lda     #eol
        sta     (symtab),y
        dey
        tya
        ldy     #0
        sta     (symtab),y      ; save size
        lda     symtab
        ldx     symtab+1
        ldy     choff          ; PUT THE 2 QUOTES BACK
        dey
        jmp     ldig2
You can see it is watching for embedded quotes, which appear to be back to back. I guess the space breaks the two quote sequence, allowing the final quote to close the string. I think the three quotes together would have given you an embedded pair of quotes in the final string which probably would break the expander. Good find though.
