N: NOS, anyone care?
There is the start of a NOS, here:
https://github.com/FujiNetWIFI/fujinet-nhandler/tree/master/nos
The idea is to load the N: handler at $0700, there is no D:, but there would be a command processor that activates when DOS is typed for file management functions.
READY
DOS
N1:[]
Some example commands.
Prefix Set
NCD N:TNFS://ATARI-APPS.IRATA.ONLINE/Games/Homesoft/
DIR N:
Binary Load
N:HTTP://FUJINET-TESTING.IRATA.ONLINE/BURIEDBU
Copy
COPY N1:HTTP://FUJINET-TESTING.IRATA.ONLINE/BURIEDBU.COM,N2:TNFS://RASPBERRYPI/Games/BURIEDBU.COM
and so on...
Question is, would anyone honestly care? The big advantage here would be MEMLO, as almost all of the logic to implement file management functions is actually done ON the ESP32.
-Thom
sigh. you're misunderstanding what this is for.
Any game or program in a language that can easily do SIO calls can simply use the SIO layer, it's easy enough.
The N: handler is for languages like BASIC where doing SIO calls takes some effort (compared to other things), and to give network access to other programs that use CIO.
-Thom
-Thom
I'm sorry, but that's not what I got from your explanation.  I saw a proposal for a replacement for DOS/DUP centered completely around network operations.  Sigh at me if you must, but that behavior only serves to chase people away from possibly helping you.
It is a replacement for DOS/DUP, there is no D:, only N:, that's sort of the point, to show what one would look like.
As it happens, the N: handler mostly benefits either BASIC and languages where trying to directly access SIO is a pain in the butt, as well as applications that can directly deal with devicespecs, for example, I've used N: from AtariWriter, and Music Composer, programs that, were never designed for network use.
e.g. I did network I/O from __LOGO__ a few days ago...
-Thom
Edited by tschak909
So something like this would work then?  Maybe in the future, we don't need D1: anymore?
SET PATH=N:/SD/;N2:
NCD N2:TNFS://RASPBERRYPI/Games/
BURIEDBU
On my Incognito, I'm kind of getting settled in with SpartaDos, which has pretty good memlo.  Except right now I'm at my father's house, where I only have a 48K 400, so maybe, though this keyboard is such a pain I'm not doing a lot of Atari command line.
yup basically.
SET PATH=N:/SD/;N2:
BURIEDBU
Yup, basically, that's the idea.
-Thom
Q: How can you tell an Atari 400 user?
A: Their lack of fingerprints.
Edited by tschak909
it is a great idea to transfer the filesystem support to the device, in many other solutions on other computers it works great. I used a similar scheme on my WiFiPrime and in my opinion it works great. I used the "D" identifier - because I believe that by default every program (including old ones) should have access to any user-defined data source.
A very good step. FujiNet is the best hardware solution in recent years.
Edited by xxl
Thank you.
It's ironic really that the user facing problems with N: don't come from N: itself, but rather from programs placing deliberate constraints on what they think is valid input. ;)
-Thom
strongly emphasizes that the protocol is also defined when the connection is opened - that's just brilliant. Unfortunately, you may feel a lot of resistance from users who think the overloaded D driver must be DOS. fileststem is currently losing its importance  ? I really keep my fingers crossed. the network opens up new possibilities for this computer.
Since the question was, "N: NOS, anyone care?", I'd like to register a 'care' vote.
Apart from the benefits mentioned above, I like having software in a central location.  This helps to keep things on an even footing between machines, makes physical portability much easier, and cuts down on busywork keeping multiple machines in sync.
  • 9 months later...
  • 2 months later...
12 hours ago, Kyle22 said:
Bump.
Any news?
Is this about MULE being run off Fujinet? I may work on it while I am in isolation for 5 days, I have no access to my master computer, I just bought this Icore 7 laptop for $150 Canadian from a friend, it has an SSD in it not too big I think 128 GB and a 17 inch screen so I will be around quite a bit. Russ
Sweet - even more projects to start, not get working, and not finish.  I'd keep maintaining the list I started, but why bother.
I got FXEP 54 to work, and I am not doing the programming on it any more , I have handed it over to someone that is going to bring it into the 21st century, and you are right about starting projects and not finishing them, I am guilty of that way too much, so while I am I n isolation I will go over a few that I have not finished and get them done. A wedding video unfortunately takes priority. Russ
I thought it was AMIS who got it working?
Just out of curiosity, who did you hand it over to?  There might be some people who want to collaborate.
His name is Vincenzo, he is a seasoned and well known programmer , he will be doing FXEP in Action or  Pascal, bringing into the 21st century , and yes Amis got it working but I also got it working from a Stock copy of the original, all I had to do was change one line, anyways Vincenzo has asked me to freeze the code at the state it is in now, maybe Amis should get in touch with him. I will be doing other things mainly new 2022 teams for Hardball.
  • 3 weeks later...
-Thom
I’m not sure such a thing would be that useful. Only new applications would be able to use N: or those that allow free form entry of file names, as 8.3 isn’t going to cut it for TCP destinations.
I think you would need to also install a pseudo D handler that could translate local filenames, perhaps prepending a TCP destination to the filename. Something like D1:PRO>HELP.TXT becomes \irata.online\pro\help.txt
What’s NCD, network change directory?
I see it as an interesting test-bed, especially because the protocol adapter design allows for even things like filesystem adapters to be attached to move what would otherwise be in the FMS onto the ESP32, gaining more user visible memory.
NCD = yeah, basically, it allows a prefix to be prepended to an N: devicespec. It was done so that long URLs didn't have to be continually typed, and to allow programs that otherwise couldn't use N:
The protocol adapter firmware in N: has some interesting code which allows protocol adapters that descend from NetworkProtocolFS to have some form of 8.3 to long filename resolution. It computes a long filename by normalizing to legal characters, and replacing the last two characters of the 8 character name with an 8-bit hex checksum value.
https://github.com/FujiNetWIFI/fujinet-platformio/blob/master/lib/network-protocol/FS.cpp#L315
https://github.com/FujiNetWIFI/fujinet-platformio/blob/master/lib/utils/utils.cpp#L136
I genuinely tried to make N: as useful as I could.
-Thom
  • Like 4
