Reverse bit-generation in C at compile-time
Andrew Davie
This was fun. I was too lazy to write a simple tool to generate a table of 256 bit-reversed values (i.e,. 00000010b --> 01000000b) to put in some C code.
So I figured a way to use #defines in the C code to do it for me. I end up with a 256 byte table, as expected, but did none of the work to get it.
Well, figuring the defines, but that seemed quicker than generating a tool to do it :P
// COMPILE-TIME REVERSE BITS IN BYTE
#define RVS(a) ( \
      ((((a) >> 0) & 1) << 7) \
    | ((((a) >> 1) & 1) << 6) \
    | ((((a) >> 2) & 1) << 5) \
    | ((((a) >> 3) & 1) << 4) \
    | ((((a) >> 4) & 1) << 3) \
    | ((((a) >> 5) & 1) << 2) \
    | ((((a) >> 6) & 1) << 1) \
    | ((((a) >> 7) & 1) << 0) \
#define P0(a) RVS(a)
#define P1(a) P0(a), P0(a+1)
#define P2(a) P1(a), P1(a+2)
#define P3(a) P2(a), P2(a+4)
#define P4(a) P3(a), P3(a+8)
#define P5(a) P4(a), P4(a+16)
#define P6(a) P5(a), P5(a+32)
#define P7(a) P6(a), P6(a+64)
#define P8(a) P7(a), P7(a+128)
// Want to call RVS(n) for 0-255 values. The weird #defines above aloow a single-call
// It's effectively a recursive power-of-two call of the base RVS macro
unsigned int BitRev[] = {
    P8(0),
The BitRev table gets the 256 bit-reversed bytes.
It does it by calling the "macro" P8, which expects P7 to do the table for it, in two halves (0-127) and (128-255).
P7 expects P6 to do the work of each of those halves -- giving P6 two halves to work on.... those being 64 bytes long...
all the way down to P0, whose job is to bit-reverse a single byte.
The reverse macro (#define) does the actual bit-reversal as a bit of bit-manipulation which the compiler will resolve down to a byte at compile time.
I know it's whacky, but it's fun-whacky, and does give an interesting way to use #defines "recursively" -- although more chained than recursive.
Just thought it worth sharing.
  • Like 5
Interesting, though I wouldn't call that lazy code being as that seems a bit more work than writing a simple 'for' loop to do the job.
ADDENDUM
I just looked thru my projects and I wrote a tool to generate a file containing a table of reversed values for use in Paint The City.  (25 lines)
It's actually a one-liner in python... I just really wanted to do it in the code... ;)
[print(',{:08b}b0'.format(i)[::-1]) for i in range(256)]
I guess the challenge now is... can anyone write a shorter version - any language?
Edited by Andrew Davie
replaced with a more elegant line
ARMv6 (and above) assembly:
RBIT R0, R1
LSR R0, R0, #24
Two instructions, 8 bytes. Beat that!
RBIT R0, R1
LSR R0, R0, #24
Nice, but not the challenge... You *have* to output the data so it can be cut/paste into source code.
That's the whole point. And iterate over 256 bytes.
In other words, output a 256-byte comma-separated human-readable ASCII block.
There's no need. It solves the general problem you presented in a way that improves both execution time and code size over either a table method or a code method.
With Perl, from command line:
perl -E 'say unpack "b8", chr for 0..255'
With Raku:
raku -e 'sprintf("%08b",$_).comb.reverse.join.say for 0..^2⁸'
Edited by explorer
Raku version, command line
