+hloberg Posted February 22, 2021 Share Posted February 22, 2021 There is a lot of good stuff out there for the Geneve it's just not very organized. So I'm making a pair of .hd files and documentation but i have a few questions that might help me with. Geneve Forth - I'm not really into Forth but doesn't it use it's own disk structure? How does that work on a .hd file? MS Multiplan 80 - How does that work? It requires the use of the cartridge but there are no carts in Geneve. Is it GPL TI99 emulation only in 80 column? Is there no native way to run it. By the way, is there a spreadsheet for the Geneve native? C99 - I think i got all the C99 stuff organized. But I'm not sure I have the latest version. The version I have is 4.1. Speaking of versions, what are the latest versions of MDOS & GPL. Is GenAsm, Tasm, C99, ABASIC & Forth all the programming languages that work on the Geneve native? The 9640news disk are in .ark form. unfortunately a lot of them seem to be corrupted. Anyone got all the disk that are all readable? I'll post all this on my project blog when I'm complete. Till then, thanks. 2 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 22, 2021 Share Posted February 22, 2021 This is certainly a good idea. It should eventually be put on WHTech under Geneve.new (maybe we should rename that folder at some time and call the previous one Geneve.old). 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 22, 2021 Author Share Posted February 22, 2021 15 minutes ago, mizapf said: This is certainly a good idea. It should eventually be put on WHTech under Geneve.new (maybe we should rename that folder at some time and call the previous one Geneve.old). I was going to bundle it into 1 big zip. think I should split it up instead. Also, I'm just putting in stuff that I got to work and has documentation. That's going to leave out a bunch of stuff that either I couldn't get to work or has no documentation. Maybe call the directory GENEVE ORGANIZED or something like that? 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 22, 2021 Share Posted February 22, 2021 35 minutes ago, hloberg said: There is a lot of good stuff out there for the Geneve it's just not very organized. So I'm making a pair of .hd files and documentation but i have a few questions that might help me with. Geneve Forth - I'm not really into Forth but doesn't it use it's own disk structure? How does that work on a .hd file? MS Multiplan 80 - How does that work? It requires the use of the cartridge but there are no carts in Geneve. Is it GPL TI99 emulation only in 80 column? Is there no native way to run it. By the way, is there a spreadsheet for the Geneve native? C99 - I think i got all the C99 stuff organized. But I'm not sure I have the latest version. The version I have is 4.1. Speaking of versions, what are the latest versions of MDOS & GPL. Is GenAsm, Tasm, C99, ABASIC & Forth all the programming languages that work on the Geneve native? The 9640news disk are in .ark form. unfortunately a lot of them seem to be corrupted. Anyone got all the disk that are all readable? I'll post all this on my project blog when I'm complete. Till then, thanks. Mike McCann had MDOS Forth. I do not believe there was any other Forth program for the MDOS side of things. It did not use a disk structure like the original TI forth, rather you had the loader and a filename as I recall that you selected at load time. It would as I recall access the records in the file as a sector. One of the nicer features of the MDOS XOP’s. Multiplan 80..... Myarc released an update to some files that replaced existing TI files. You used a GramKracker dump of the module that was loaded from the GPL interpreter screen. It provided 80 column capability for Multiplan. It might work on the F18, but I have not seen anyone comment to know if it was a very Geneve specific update, or an update for 80 columns. There are no native 80 column spreadsheets. I wish I had the source code to Peter Muy’s “Crash” Stockmarket program as it had so many features it may have been able to be turned into a spreadsheet program. From what I last gathered from Peter, the code was lost. GenProg (ASM, LINK, MAKE, LIBR, and XOP docs), TASM, c99, Forth are all native to MDOS. I’ve noticed some sites seem to have bad copies of my 9640News disk magazines. When I get time, I will put out another complete package of the files. Beery 3 1 Quote Link to comment Share on other sites More sharing options...
Nick99 Posted February 22, 2021 Share Posted February 22, 2021 @hloberg thanks for taking on this task! ?? 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 22, 2021 Author Share Posted February 22, 2021 (edited) 2 hours ago, BeeryMiller said: Mike McCann had MDOS Forth. ...... Multiplan 80..... Myarc released an update to some files that replaced .... I’ve noticed some sites seem to have bad copies of my 9640News ... Beery thanks Beery. I'm going to play around with the forth but i might end up posting the forth package and letting someone who knows something about forth check it out. I kinda wanted to steer away from GPL, even though it's a great package, I just felt people look at the Geneve just a faster TI99 and missing a lot of the great native capabilities. But if that's the only way to get a spreadsheet, something I consider a necessity, I'll set it up that way. After all I do have 99XB running on it. I tried putting together a working 9640News from various sources that was complete but it soon got to be a big mess. So thanks, I consider that diskzine(?) a necessary as it is so chocked full of useful stuff. Oh by the way, there wasn't a corresponding newsletter was there? Edited February 22, 2021 by hloberg Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 22, 2021 Share Posted February 22, 2021 There are probably multiple versions of programs - Directory Manager comes to mind - so as the cleanup progresses, we can all help to to identify cases where there was a newer program. @FarmerPotato's google doc is a good source for program info. One challenge that I've had lately is finding the associated documentation and release notes. Seems that I and many others use the program and tuck away the docs and readme files that a new or returning user would find valuable. I've have some archived software updates/releases from 1994-95 on MFM hard drive backups and will start copying/setting those aside when I come across them. 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 22, 2021 Author Share Posted February 22, 2021 OK, here's the 1st post for checking out. I 'think' I got all the latest-n-greatest. the MILL game in DRIVE2.PROJ.AB is a work in progress. It's still missing the above mentioned MS-multiplan, Forth, 9460News. Docs a mix of .pdf & .txt. Like I said, I only put in the things I have tested that works and has docs. Oh, I also don't have the Tomytutor games. I'll add those later. use with MAME/MESS and @mizapf TIimage tool. If you have working & docs something I missed you think I might add, post here. I'll see about adding it. Also if I don't have the latest versions or docs, post here too. it's a big file. geneve.zip 1 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 (edited) just found games can run by EXEC GAME if they can run as EA5. cool. the bad is some of the games aren't playable due to they are now too fast. and I have been trying to find a copy of Fortran 9460 that does not have a corrupted .arc file. It looks like Fortran might work if I can find a working file! and I did download the Fortran fom Atariage resources page. Edited February 23, 2021 by hloberg Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 so far TIC & TomyTutor games I have found I want to add. I 'think' all the TIC will be there but I don't see a STDIO file. It looks like it's part of TIC??? Still working on Forth but it looks good so far. If I get a good 9460News and 9640Fortran It's golden. I'm going to issue a ARCHIVE.HD file too that will be filled with all the misc stuff when done. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 23, 2021 Share Posted February 23, 2021 By the way, here is a fixed version of TASM 3.4 (which I renamed to 3.41). I found two flaws in TASM: - Assembly aborted before pass 2; reason was an uninitialized variable which led to a wrong memory location access - COC mnemonic not recognized; reason was an error in the opcode table. I tried to contact Alan Beard who was active for a short time last October and November, but it seems he has not yet visited our forum again, and I could not reach him by E-Mail. tasm341.dsk 1 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 33 minutes ago, mizapf said: By the way, here is a fixed version of TASM 3.4 (which I renamed to 3.41). I found two flaws in TASM: - Assembly aborted before pass 2; reason was an uninitialized variable which led to a wrong memory location access - COC mnemonic not recognized; reason was an error in the opcode table. I tried to contact Alan Beard who was active for a short time last October and November, but it seems he has not yet visited our forum again, and I could not reach him by E-Mail. tasm341.dsk 360 kB · 3 downloads thanks. I'll add it. Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 looking over Funnelweb 80. it's a bit of a mess, but i might be able to use it. Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 23, 2021 Share Posted February 23, 2021 Attached is a zip file of the 15 issues of 9640News. Please review the files, and if you find an issue or file with problems, please let me know and I will check other backup disks for the good files. Beery 9640News.zip 2 3 Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 23, 2021 Share Posted February 23, 2021 BARRICADE _________ (C) January 1990 by Sherburne and Martin Documentation (c) 1990 by Beery Miller and 9640 News Equipment Required __________________ Geneve 9640 Advanced Basic 2.99a or higher MDOS V1.14f or 0.96H or higher Loading: _______ 1) Load Geneve operating system 2) Load Advanced Basic (File should be called BASIC1, v 2.99a or higher) 3) There is a loader called LOAD that loads BARRICADE 4) Documentation built into program. Additional Documentation ________________________ BARRICADE is an exciting 3-Dimensional game requiring quick thinking and strategy. A 3_Dimensional pit has 'blocks' that fall down the sides and it is job to move these random colored blocks into an organized array (by color). Once 100 blocks have fallen (or 200 if you select the long version), calculations are done to determine if you have successfully arranged sufficient blocks in order to open the gateway. If you score high enough, the game is over, if not, you are prompted to 'Try Again'. Watch out for the killer blocks that can destroy your effort in a fraction of time. Manipulate the killer blocks, and your own, through the use of the arrow keys. Enjoy!!!! Barricade.zip 2 2 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 2 hours ago, hloberg said: so far TIC & TomyTutor games I have found I want to add. I 'think' all the TIC will be there but I don't see a STDIO file. It looks like it's part of TIC??? Still working on Forth but it looks good so far. If I get a good 9460News and 9640Fortran It's golden. I'm going to issue a ARCHIVE.HD file too that will be filled with all the misc stuff when done. just figured out TIC is a cross compiler. DOH! Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 23, 2021 Author Share Posted February 23, 2021 1 hour ago, hloberg said: looking over Funnelweb 80. it's a bit of a mess, but i might be able to use it. I give up on funnelweb. Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 23, 2021 Share Posted February 23, 2021 On 2/22/2021 at 10:27 AM, hloberg said: I was going to bundle it into 1 big zip. think I should split it up instead. Also, I'm just putting in stuff that I got to work and has documentation. That's going to leave out a bunch of stuff that either I couldn't get to work or has no documentation. Maybe call the directory GENEVE ORGANIZED or something like that? Just date it. Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 24, 2021 Author Share Posted February 24, 2021 I modified GLOBAL WAR, a ABASIC game, so that it can be run from any drive. it was defaulting to HDS1.DEMO. You enter the drive.subdirectory in the beginning. Nothing else really modified beyond that. Attached in .DSK form. GW.dsk 4 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted February 24, 2021 Author Share Posted February 24, 2021 (edited) since Beery is coming out with a 9640news website I'll make this the last post. It's got a few added things to the drives. If you want the docs download the previous post as the docs didn't change. here you go. EDIT: 1st file was corrupt. redownload this on. DISKS.zip Edited February 24, 2021 by hloberg 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 25, 2021 Share Posted February 25, 2021 i looked here http://ftp.whtech.com/Geneve.new/ and im not seeing a MDOS manual .PDF file? can someone please help the blind.. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted February 25, 2021 Share Posted February 25, 2021 2 hours ago, hloberg said: since Beery is coming out with a 9640news website I'll make this the last post. I'm enjoying seeing what you are coming up with so I hope you continue in some form or fashion 1 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted February 25, 2021 Share Posted February 25, 2021 (edited) 14 minutes ago, GDMike said: i looked here http://ftp.whtech.com/Geneve.new/ and im not seeing a MDOS manual .PDF file? can someone please help the blind.. It's on the new website BeeryMiller put up, that should be okay. https://www.9640news.com/manuals/ Edited February 25, 2021 by RickyDean added content Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 25, 2021 Share Posted February 25, 2021 1 minute ago, RickyDean said: It's on the new website BeeryMiller put up, that should be okay. the NEW site? i dont even see it on the OLD site...what is The NEW, NEWer,est site. please..thank you Quote Link to comment Share on other sites More sharing options...
RickyDean Posted February 25, 2021 Share Posted February 25, 2021 Just now, GDMike said: the NEW site? i dont even see it on the OLD site...what is The NEW, NEWer,est site. please..thank you Please reread post 23 added site info. Quote Link to comment Share on other sites More sharing options...
