+DrVenkman Posted March 3, 2021 Share Posted March 3, 2021 So there was a topic in the main A8 forum in the last couple days about how to print ATASCII program listings. There are several options of course, including the G: device driver from A.N.A.L.O.G. Computing (Oct 1985), and the FujiNet ATASCII printer setting. I got interested enough that I ran the program from A.N.A.L.O.G. to create the AUTORUN.SYS file that loads the G: driver and read the article that accompanied the program. The driver is sophisticated enough to have several different printing options, including limiting printed output the same margins as the standard Atari 40 column screen. BTW, the G: driver actually works with FujiNet when you set it to "Epson 80" mode. Messing around with the HTML ATASCI driver tonight for comparison, I realized that long program lines extend past the usual 80 columns available to most printers. The HTML output from the driver will open in any browser, and most browsers allow you to "print" that resulting HTML file to a PDF for later use or manipulation, or actual physical printing. However, program lines that extend past the vintage 40 column length, or the modern ~80 columns per page in landscape mode aren't wrapped. So to print a program listing requires either setting your printer to Landscape orientation or else shrinking the scale down to fit, sometimes to as low as 60% or so. It would be a nice enhancement of the HTML printer if the user could set the output margins to something besides the length of the program line. Maybe a toggle to set the page width between 40, 80 and 132 columns? Something to wrap longer lines so they can be printed without running off the edge of the paper and being truncated, or having to be shrunk down in size too small to be legible to older eyes. What does everyone think? 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted March 3, 2021 Share Posted March 3, 2021 19 minutes ago, DrVenkman said: So there was a topic in the main A8 forum in the last couple days about how to print ATASCII program listings. There are several options of course, including the G: device driver from A.N.A.L.O.G. Computing (Oct 1985), and the FujiNet ATASCII printer setting. I got interested enough that I ran the program from A.N.A.L.O.G. to create the AUTORUN.SYS file that loads the G: driver and read the article that accompanied the program. The driver is sophisticated enough to have several different printing options, including limiting printed output the same margins as the standard Atari 40 column screen. BTW, the G: driver actually works with FujiNet when you set it to "Epson 80" mode. Messing around with the HTML ATASCI driver tonight for comparison, I realized that long program lines extend past the usual 80 columns available to most printers. The HTML output from the driver will open in any browser, and most browsers allow you to "print" that resulting HTML file to a PDF for later use or manipulation, or actual physical printing. However, program lines that extend past the vintage 40 column length, or the modern ~80 columns per page in landscape mode aren't wrapped. So to print a program listing requires either setting your printer to Landscape orientation or else shrinking the scale down to fit, sometimes to as low as 60% or so. It would be a nice enhancement of the HTML printer if the user could set the output margins to something besides the length of the program line. Maybe a toggle to set the page width between 40, 80 and 132 columns? Something to wrap longer lines so they can be printed without running off the edge of the paper and being truncated, or having to be shrunk down in size too small to be legible to older eyes. What does everyone think? Somebody indeed did do a small tweak to the CSS to automatically wrap, which should fix the issue, I'll fold it in and see what everybody thinks. -Thom 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted March 3, 2021 Share Posted March 3, 2021 Made the change here. for the next build! https://github.com/FujiNetWIFI/fujinet-platformio/commit/c2a153795672ccc53e9d3cd6356f89c58aa6027b -Thom 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted March 3, 2021 Author Share Posted March 3, 2021 Thanks, Thom! When mozzwald has a new build ready, I’ll update and give it a spin. Quote Link to comment Share on other sites More sharing options...
chad5200 Posted January 28 Share Posted January 28 Hi @tschak909 The HTML ATASCI printer issue that @DrVenkman describes above still persists in the latest firmware version released this month. Would be great if it could be addressed. I am currently printing a bunch of old BASIC listings and have to print in landscape and shrink to 75% to fit them on the printed page. Much appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 28 Share Posted January 28 Noted. Thanks. Perhaps this could be done as a CSS change? Has anyone tried to load up a listing in Chrome, and use the developer tools to mess with it to make it line wrap? -Thom 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted January 28 Share Posted January 28 The fix ("white-space: pre-wrap")made it into the HTML printer but not into the ATASCII specific css file. It's fixed in master and will be in the next firmware release when that happens. 6 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted January 30 Share Posted January 30 On 1/28/2023 at 9:43 AM, chad5200 said: Would be great if it could be addressed. I am currently printing a bunch of old BASIC listings and have to print in landscape and shrink to 75% to fit them on the printed page. This is fixed in the latest firmware 2 1 Quote Link to comment Share on other sites More sharing options...
chad5200 Posted January 31 Share Posted January 31 5 hours ago, mozzwald said: This is fixed in the latest firmware Thank you! 1 Quote Link to comment Share on other sites More sharing options...
