Manuals or Howtos on DPC?DPC+
1 hour ago, rallyrabbit said:
I feel silly asking this, I assumed I could find some information on DPC (and potentially how Pitfall II is written) or DPC+... but I'm not finding any specific information on than sporadic notes... is there nothing more .... formalized?
DPC is defined in a US patent.
https://patents.google.com/patent/US4644495A/en
And for DPC+ I found these links very helpful but nothing as far as I know, nothing formal as a patent.
https://atariage.com/forums/topic/163495-harmony-dpc-programming
DPC+ with ARM
https://atariage.com/forums/blogs/entry/11712-dpc-arm-development/?tab=comments#comment-27116
DPC+ with ARM
Ask a vague question and get any answer that comes :) that's on me!
Let me rephrase.  Is there more formalized documentation on how to use the DPC/DPC+ feature set?  I've read all the concepts on the original DPC, which sounds fairly straight forward if not a bit cryptic due to how it works.  It's more a case of, as a coder, what specifics do I use to utilize this, recommended best practices, etc.  However, your links lead me over to the Harmony/Melody club on AtariAge which I didn't know existed and that has a ton of stuff for me to go through.  So shame on me for not finding that on me own!
The documentation is in the header file DPCplus.h that's available in the Harmony DPC+ programming topic, such as this section which defines the 8 Data Fetcher registers.  Refer to DPCplus.asm for code examples.
; Data Fetcher
; There are 8 Data Fetchers which are used to access data stored in the Display
; Data bank.  Before using, you must point the Data Fetcher at the data to read
; via DFxLOW and DFxHI.  After each read the Data Fetcher will update to point
; to the next byte of data to return.
; psuedo code* to point Data Fetcher 1 to the color data
;	lda #<(ColorDataPosition - HowFarDownScreen)
;	sta DF1LOW
;	lda #>(ColorDataPosition - HowFarDownScreen)
;	sta DF1HI
; then in the kernel read the Data Fetcher and update the color, takes 7 cycles
;	LDA DF1DATA
;	STA COLUP0
; * see DPCplus.asm for actual code
DF0DATA       DS 1    ; $08
DF1DATA       DS 1    ; $09
DF2DATA       DS 1    ; $0A
DF3DATA       DS 1    ; $0B
DF4DATA       DS 1    ; $0C
DF5DATA       DS 1    ; $0D
DF6DATA       DS 1    ; $0E
DF7DATA       DS 1    ; $0F
If you're planning to use pure 6507 code then DPC+ is what you should use.
If you're planning to take advantage of C code running on the ARM processor then CDFJ is the way to go. CDFJ cannot be used with pure 6507 code as most of the data streams can only be configured by the ARM.
; Data Fetcher
;	sta DF1LOW
;	sta DF1HI
;	LDA DF1DATA
;	STA COLUP0
DF0DATA       DS 1    ; $08
DF1DATA       DS 1    ; $09
DF2DATA       DS 1    ; $0A
DF3DATA       DS 1    ; $0B
DF4DATA       DS 1    ; $0C
DF5DATA       DS 1    ; $0D
DF6DATA       DS 1    ; $0E
DF7DATA       DS 1    ; $0F
Thanks sir!
I've been reading up on your stuff for the past hour so.  Simply amazing so far!!!!  I have a lot of reading to do to figure this out.
