Plotchars from pointer
mksmith
Hi everyone,
I want to store some messages in alphadata, copy it into ram and then offset the starting point to display a different section of the message.  Now if I setup a pointer (either trying 1 or 2) it doesn't show the text but if I directly reference the ram location it does show.  Is this sort of thing possible??
 rem vars
 dim pointer = a.b
 rem copy to ram
 memcpy $2200 message 40
 rem set pointer (try 1)
 pointer[0] = $00 : pointer[1] = $22
 rem set pointer (try 2)
 const plo = <#message
 const phi = >#message
 pointer[0] = plo : pointer[1] = phi
 rem draw
 plotchars pointer 0 0 0 20
 plotchars $2200 0 0 5 20
 alphadata message font
 'hello567890abcdefghi'
 '01234567890abcdefghi'
end
Working example
plotchars_example.zip
6 hours ago, mksmith said:
pointer[0] = $00 : pointer[0] = $22
I assume the second part is supposed to be pointer[1] = $22 here.
At any rate, plotchars isn't setup to expect a pointer, so you can't pass a pointer to it and get a correct result. If you are copying the data into RAM anyway though, you can just have the plotchars use $2200 as the address, and instead make your own function to read from your pointer to copy data to memory, and just increment the pointer when you need to. I'll whip up a quick example momentarily if no one beats me to it. ?
Here's an example that increments the start point of your text by 1 every time you press fire. Note that in a real game, you would probably want to do the plotchars before a savescreen, then restore it every frame instead of having to replot it. Then you could just update the text by adjusting the pointer and running the TextCopy function:
 set doublewide off
 set tv ntsc
 set zoneheight 8
 set screenheight 208
 set romsize 48k
 set mcpdevcart off
 set canary off
 displaymode 160A
 rem vars
 dim pointer = a.b
 dim FireButtonHeldBit0 = c
 dim Temp = d
 dim TextMem = $2200
 rem characters
 incgraphic gfx/font.png 160A
 rem font
 characterset font
 alphachars '0123456789abcdefghijklmnopqrstuvwxyz! >`?/.,:-_()[]&AB@*"#'
 rem palette
 P0C1 = $0f
; rem set pointer
; pointer[0] = $00 : pointer[1] = $22
 rem copy to ram
 temp1 = TextCopy(pointer[0], pointer[1]) ; return value is discarded
 rem mainloop
MainLoop
 clearscreen
 if !joy0fire then FireButtonHeldBit0{0} = 0 : goto _skip_advance_pointer
 if FireButtonHeldBit0{0} then goto _skip_advance_pointer
 FireButtonHeldBit0{0} = 1
 pointer[0] = pointer[0] + 1
 if CARRY then pointer[1] = pointer[1] + 1
 rem draw
 plotchars TextMem 0 0 0 20
 drawscreen
 goto MainLoop
 function TextCopy
 for Temp = 0 to 19
 TextMem[Temp] = temp1[[Temp]]
 next
 return
; End TextCopy
end
plotchars.78b
plotchars.78b.a78
