PaultheRoman Posted March 11, 2021 Share Posted March 11, 2021 Hey, guys, I'm trying to follow the instructions on Andrew Davie's "Atari 2600 Programming for Newbies", in chapter 9 where he starts teaching how to use DASM. Thing is, I'm having troubles trying to get it to work. Can anyone please help? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 11, 2021 Share Posted March 11, 2021 (edited) Nothing immediately obvious. The ".\" is not needed for Windows, but that's not the problem. I see you're using PowerShell, which apparently does need the ./ Probably 20 years since I've actively used Windows. Is "cmd" command line still available? Have you tried that? Do you have the file "kernel.asm" in that directory? Might be useful to post that for us to check assembly too. Edited March 11, 2021 by Andrew Davie Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 11, 2021 Share Posted March 11, 2021 See this issue [nevermind me here, with the answer] 1 Quote Link to comment Share on other sites More sharing options...
PaultheRoman Posted March 11, 2021 Author Share Posted March 11, 2021 (edited) 9 hours ago, Andrew Davie said: Nothing immediately obvious. The ".\" is not needed for Windows, but that's not the problem. I see you're using PowerShell, which apparently does need the ./ Probably 20 years since I've actively used Windows. Is "cmd" command line still available? Have you tried that? Do you have the file "kernel.asm" in that directory? Might be useful to post that for us to check assembly too. So, thing was that I didn't know whether I needed to set a path in my computer to the dasm.exe executable. Apparently, as long as I'm in the folder when calling it, or I'm entering the the folder it's in through ..\..\dasm_assembler\dasm-2.20.14-win-x64\dasm.exe , it seems to work. Question now though, is that I don't know if I'm writing the command correctly: PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe kernel.asm -l kernel.txt -f3 -v5 -o kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe kernel.asm -l kernel.txt -f3 -v5 -okernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe kernel.asm -l kernel.txt -f3 -v5 -o kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe ..\..\projects\demo.asm -l kernel.txt -f3 -v5 -o kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe ..\..\projects\ -l demo.asm -f3 -v5 -o kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe ..\..\projects\ -l ..\..\projects\demo.asm -f3 -v5 -o ..\..\projects\kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe ..\..\projects\ -l ..\..\projects\demo.asm -f3 -v5 ..\..\projects\kernel.bin -o Switch requires file name. PS C:\Users\pablo\Google Drive\ATARI_2600\dasm_assembler\dasm-2.20.14-win-x64> .\dasm.exe ..\..\projects\ -l ..\..\projects\demo.asm -f3 -v5 -o ..\..\projects\kernel.bin -o Switch requires file name. As for what's in the folder I have my file in: PS C:\Users\pablo\Google Drive\ATARI_2600\projects> ls Directory: C:\Users\pablo\Google Drive\ATARI_2600\projects Mode LastWriteTime Length Name ---- ------------- ------ ---- -a---- 3/10/2021 8:45 PM 1829 demo.asm And as for what's inside the file, it's not what's in Andrew's book. I took this code from 8bitworkshop IDE [vcs] - examples/vsync.a , as I just currently want to get something assembling before anything else. I've always have had problems with command line assemblers and compilers. They seem really hard to understand and use. The code in that link is: processor 6502 include "vcs.h" include "macro.h" org $f000 ; Now we're going to drive the TV signal properly. ; Assuming NTSC standards, we need the following: ; - 3 scanlines of VSYNC ; - 37 blank lines ; - 192 visible scanlines ; - 30 blank lines ; We'll use the VSYNC register to generate the VSYNC signal, ; and the VBLANK register to force a blank screen above ; and below the visible frame (it'll look letterboxed on ; the emulator, but not on a real TV) ; Let's define a variable to hold the starting color ; at memory address $81 BGColor equ $81 ; The CLEAN_START macro zeroes RAM and registers Start CLEAN_START NextFrame ; Enable VBLANK (disable output) lda #2 sta VBLANK ; At the beginning of the frame we set the VSYNC bit... lda #2 sta VSYNC ; And hold it on for 3 scanlines... sta WSYNC sta WSYNC sta WSYNC ; Now we turn VSYNC off. lda #0 sta VSYNC ; Now we need 37 lines of VBLANK... ldx #37 LVBlank sta WSYNC ; accessing WSYNC stops the CPU until next scanline dex ; decrement X bne LVBlank ; loop until X == 0 ; Re-enable output (disable VBLANK) lda #0 sta VBLANK ; 192 scanlines are visible ; We'll draw some rainbows ldx #192 lda BGColor ; load the background color out of RAM ScanLoop adc #1 ; add 1 to the current background color in A sta COLUBK ; set the background color sta WSYNC ; WSYNC doesn't care what value is stored dex bne ScanLoop ; Enable VBLANK again lda #2 sta VBLANK ; 30 lines of overscan to complete the frame ldx #30 LVOver sta WSYNC dex bne LVOver ; The next frame will start with current color value - 1 ; to get a downwards scrolling effect dec BGColor ; Go back and do another frame jmp NextFrame org $fffc .word Start .word Start Let me know if you need anything else, please. Really just want to assemble something so I know I am able to actually program and try things out. Edited March 11, 2021 by PaultheRoman Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted March 11, 2021 Share Posted March 11, 2021 Trying putting double quotes around the file path/names. "kernel.asm" instead of kernel.asm "..\..\projects\demo.asm" instead of ..\..\projects\demo.asm Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 11, 2021 Share Posted March 11, 2021 Also, your code assumes that "vcs.h" and "macro.h" are in the same directory (the include statements) So, make sure they are! Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 11, 2021 Share Posted March 11, 2021 2 hours ago, PaultheRoman said: Question now though, is that I don't know if I'm writing the command correctly: .\dasm.exe kernel.asm -l kernel.txt -f3 -v5 -o kernel.bin no space between the -o and the filename. Same goes for other options like -l for the listing and -s for the symbol dump. .\dasm.exe kernel.asm -lkernel.txt -f3 -v5 -okernel.bin Quote Link to comment Share on other sites More sharing options...
PaultheRoman Posted March 11, 2021 Author Share Posted March 11, 2021 (edited) Okay, so I took the advice and located the macro.h and vcs.h files into the same directory as demo.asm. I also united the -l and -o switches to their directed file/filename. It's still not working however in PowerShell though. Anything else that I need to fix? PS C:\Users\pablo\Google Drive\ATARI_2600\projects> ls Directory: C:\Users\pablo\Google Drive\ATARI_2600\projects Mode LastWriteTime Length Name ---- ------------- ------ ---- -a---- 3/10/2021 8:45 PM 1829 demo.asm -a---- 9/8/2020 3:04 AM 5955 macro.h -a---- 9/8/2020 3:04 AM 9364 vcs.h PS C:\Users\pablo\Google Drive\ATARI_2600\projects> ..\dasm_assembler\dasm-2.20.14-win-x64\dasm.exe .\demo.asm -ldemo.txt -f3 -v5 -okernel.bin DASM 2.20.14 Copyright (c) 1988-2020 by the DASM team. License GPLv2+: GNU GPL version 2 or later (see file LICENSE). DASM is free software: you are free to change and redistribute it. There is ABSOLUTELY NO WARRANTY, to the extent permitted by law. Usage: dasm sourcefile [options] -f# output format 1-3 (default 1) -oname output file name (else a.out) -lname list file name (else none generated) -Lname list file, containing all passes -sname symbol dump file name (else none generated) -v# verboseness 0-4 (default 0) -d debug mode (for developers) -Dsymbol define symbol, set to 0 -Dsymbol=expression define symbol, set to expression -Msymbol=expression define symbol using EQM (same as -D) -Idir search directory for INCLUDE and INCBIN -p# maximum number of passes -P# maximum number of passes, with fewer checks -T# symbol table sorting (default 0 = alphabetical, 1 = address/value) -E# error format (default 0 = MS, 1 = Dillon, 2 = GNU) -S strict syntax checking -R remove binary output-file in case of errors -m# safety barrier to abort on recursions, max. allowed file-size in kB Report bugs on https://github.com/dasm-assembler/dasm please! Fatal assembly error: Check command-line format. PS C:\Users\pablo\Google Drive\ATARI_2600\projects> That's the bad news. The good news, is that in the Command Prompt it seemed to be that it worked: C:\Users\pablo\Google Drive\ATARI_2600\projects>..\dasm_assembler\dasm-2.20.14-win-x64\dasm.exe .\demo.asm -ldemo.txt -f3 -v5 -okernel.bin START OF PASS: 1 back to: .\demo.asm back to: .\demo.asm ---------------------------------------------------------------------- SEGMENT NAME INIT PC INIT RPC FINAL PC FINAL RPC f000 f000 RIOT [u] 0280 0280 TIA_REGISTERS_READ [u] 0000 0000 TIA_REGISTERS_WRITE [u] 0000 0000 INITIAL CODE SEGMENT 0000 ???? 0000 ???? ---------------------------------------------------------------------- 4 references to unknown symbols. 0 events requiring another assembler pass. --- Symbol List (sorted by symbol) 0.FREE_BYTES 0000 1.CLEAR_STACK f005 (R ) AUDC0 0015 AUDC1 0016 AUDF0 0017 AUDF1 0018 AUDV0 0019 AUDV1 001a BGColor 0081 (R ) COLUBK 0009 (R ) COLUP0 0006 COLUP1 0007 COLUPF 0008 CTRLPF 000a CXBLPF 0006 CXCLR 002c CXM0FB 0004 CXM0P 0000 CXM1FB 0005 CXM1P 0001 CXP0FB 0002 CXP1FB 0003 CXPPMM 0007 ENABL 001f ENAM0 001d ENAM1 001e GRP0 001b GRP1 001c HMBL 0024 HMCLR 002b HMM0 0022 HMM1 0023 HMOVE 002a HMP0 0020 HMP1 0021 INPT0 0008 INPT1 0009 INPT2 000a INPT3 000b INPT4 000c INPT5 000d INTIM 0284 LVBlank f01e (R ) LVOver f03a (R ) NextFrame f00a (R ) NO_ILLEGAL_OPCODES 0000 ???? (R ) NUSIZ0 0004 NUSIZ1 0005 PF0 000d PF1 000e PF2 000f REFP0 000b REFP1 000c RESBL 0014 RESM0 0012 RESM1 0013 RESMP0 0028 RESMP1 0029 RESP0 0010 RESP1 0011 RSYNC 0003 ScanLoop f02b (R ) Start f000 (R ) SWACNT 0281 SWBCNT 0283 SWCHA 0280 SWCHB 0282 T1024T 0297 TIA_BASE_ADDRESS 0000 (R ) TIA_BASE_READ_ADDRESS 0000 (R ) TIA_BASE_WRITE_ADDRESS 0000 (R ) TIM1T 0294 TIM64T 0296 TIM8T 0295 TIMINT 0285 VBLANK 0001 (R ) VDELBL 0027 VDELP0 0025 VDELP1 0026 VERSION_MACRO 006d VERSION_VCS 006a VSYNC 0000 (R ) WSYNC 0002 (R ) --- End of Symbol List. --- Unresolved Symbol List NO_ILLEGAL_OPCODES 0000 ???? (R ) --- 1 Unresolved Symbol Complete. (0) C:\Users\pablo\Google Drive\ATARI_2600\projects> Is this output what I'm looking for, guys? Edited March 11, 2021 by PaultheRoman Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 11, 2021 Share Posted March 11, 2021 Looks correct, you should now have a file kernel.bin in directory C:\Users\pablo\Google Drive\ATARI_2600\projects I'm not familiar with Power Shell, so don't know what its issue could be. Quote Link to comment Share on other sites More sharing options...
PaultheRoman Posted March 12, 2021 Author Share Posted March 12, 2021 Yup, I do, and it runs on the emulator! Woohoo! Thanks guys! 2 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted March 12, 2021 Share Posted March 12, 2021 Keep chipping away; it will all make sense soon. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted March 12, 2021 Share Posted March 12, 2021 23 hours ago, RevEng said: See this issue [nevermind me here, with the answer] dasm cleanmem.asm -f3 -v0 -o"cart.bin" I think the output option parm may need to be inside the quotes with the filename: dasm cleanmem.asm -f3 -v0 "-ocart.bin" Powershell processes command line options and even variables inside of quotes: dasm.exe "$script:ROM_file" "-o$script:BIN_file" "-f3" We're used to seeing just strings inside quotes with most languages but PowerShell is different. Quote Link to comment Share on other sites More sharing options...
