Atari XC11 (tape player) not powering
mikesk8
Hi, I have just got an XC11 tape player, which looks in a good condition. However, after connecting it to 130XE and switching power on, the light on the XC11 is not on and it does not respond to any button :( Later I have connected SIO2SD to the XC11 pass through SIO port and SIO2SD works ok (at least power is going through the XC11 SIO port).
Any tips/ideas how to check/repair it? Its a pity as this is a nice player.
Thanks, Michael
Edited by mikesk8
This may help:-
From the circuit, there's noting but a direct connection to the power LED, so as nothing else is working it
suggests there's no 5V getting to the device, as the other port has the 5V on it you need to check the circuit
tracks from the SIO cable connections, both 5V (pin 10) and Ground (pin 4)
or better yet put in a tape... press the play button on XC11, on Atari hold the start key down while turning on the Atari brrrrrp, press return key....   does the light turn on now and the tape play?
Edited by _The Doctor__
  • 2 weeks later...
I have managed to fix it: ) basically, the ground motor cable (pin 6) was broken; after fixing it the player loads the games.
Now the rewind is broken. The infamous cap on the rewind spring. Has anybody seen a better solution than just glueing it in? Maybe some spare parts from other players or 3d printing?
