a8isa1 Posted April 2, 2021 Share Posted April 2, 2021 Someone asked in IRC about 80 column terminal programs for 800. I could not recall if Omnicom works on the 800 or not. Apparently it doesn't, however when the program crashed I tried Flickerterm 80 which I know should work. After I load the 850 handler and start Flickerterm 80 it comes up in ASCII mode and at 1200 baud. However, the keyboard does not respond. After about 5 seconds the emulation switches to VT100 and baud rate is now at 19,200. The keyboard still will not respond and now the FujiNet activity LED is flashing brightly with about 3 pulses per second. It never stops flashing. Pressing button C resets Fujinet but the LED continues to flash. I next tried Bobterm but it halts while loading some module. I then tried AMODEM 4.2. I'm able to enter an ATDT sequence and connect but the keyboard stops responding here as well. Fujinet is not flashing. I recently updated the firmware. Fujinet works fine on my 800XL I'm providing fujinet debugging data. It begins at the point I started the 850 handler. Below are some excerpts that I thought odd. They occured with no intervention from me. The keyboard remained non responsive the whole time. set_baudrate change from 19200 to 1200 Modem streaming at 1200 baud Modem was active - resetting SIO baud set_baudrate change from 1200 to 19200 set_baudrate change from 19200 to 1200 Modem streaming at 1200 baud Modem was active - resetting SIO baud set_baudrate change from 1200 to 19200 set_baudrate change from 19200 to 19200 Modem streaming at 19200 baud Modem was active - resetting SIO baud set_baudrate change from 19200 to 19200 set_baudrate change from 19200 to 19200 Modem streaming at 19200 baud Modem was active - resetting SIO baud set_baudrate change from 19200 to 19200 Regards, SteveS atari800_fujinet_debugging.zip Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 3, 2021 Author Share Posted April 3, 2021 This turns out to be a user problem but it was one of years of bad habits in the making. I some distant past I had appended RVerter/Bobverter drivers to most of the terminal programs I had been using on the disk that I use for everything. A few years ago I started using SpartaDOS X and the newest updates/betas of ICET XE. By this time I had dropped the habit of attaching the driver to the executables. I don't need such a shortcut. SDX has batch files. Now FujNet comes along and I need the 850 driver loaded. No problem with this. Later on I decide to test FujiNet on my 800. Unfortunately, I can't use SDX or my CF card or ICET XE on my stock 800. This forces me to dig my old and small collection of terminal programs. I load the 850 driver and whichever terminal program I wish to use not realizing a driver conflict was waiting for me, Well, at least that's what I assume was happening. I don't see the Bobverter splash notice on my 800. (It does appear now when I repeat the exercise on my 800XL). I don't have debug tools on 800 and I don't have the know-how to recreate the problem in emulators. So, yeah. Just an assumption of what happened. Sorry, for the false alarm! Regards, SteveS 1 1 Quote Link to comment Share on other sites More sharing options...
