Problems loading Basic file over N: TNFS
tsom
I suppose it could just be the N-Handler still not quite ready, I was able to do this, but I'm having a problem loading a Basic file from my local TNFS server. My FujiNet device is up to date.
I'm issuing the command:
LOAD "N:TNFS://tnfs.local/READTIME.BAS
It chugs for a little bit and returns with no errors. But the file isn't loaded. Here is the output from the debugger:
(Here is the first attempt, where I forgot to put the URL in lower case - upper case doesn't resolve the IP address - separate problem - returns an ERROR 138)
Using '/dev/cu.usbserial-141430' as serial port.
Showing logs:
[17:24:31]
[17:24:31]CF: 71 4f 00 c4
[17:24:31]4 0sioNewrk::sio_roce: 0x04, 0x00
[17:24:31]topss 0x4f 'O'eork:en(
[17:24:31]sioNtw:sio_op)
[17:24:31]K!
[17:24:31]ACDeling exis ateTim
[17:24:31]ettingrer
[17:24:31]<-IOred 256 ye
Serial port closed!
[17:24:31]ACK!
[17:24:31]sioNetwork::parseURL(N:TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:24:31]sioNetwork::parseURL transformed to (N:TNFS://TNFS.LOCAL/SHOWTIME.BAS, TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:24:31]Parse and instantiate protocol: N:TNFS://TNFS.LOCAL/SHOWTIME.BAS
[17:24:31]NetworkProtocol::ctor()
[17:24:31]NetworkProtocolTNFS::ctor
[17:24:31]sioNetwork::open_protocol() - Protocol TNFS opened.
[17:24:31]Resolving hostname "TNFS.LOCAL"
[17:24:31]Name failed to resolve
[17:24:31]Failed to send packet - retrying
[17:24:32]Resolving hostname "TNFS.LOCAL"
[17:24:32]Name failed to resolve
[17:24:32]Failed to send packet - retrying
[17:24:33]Resolving hostname "TNFS.LOCAL"
[17:24:33]Name failed to resolve
[17:24:33]Failed to send packet - retrying
[17:24:34]Resolving hostname "TNFS.LOCAL"
[17:24:34]Name failed to resolve
[17:24:34]Failed to send packet - retrying
[17:24:35]Resolving hostname "TNFS.LOCAL"
[17:24:35]Name failed to resolve
[17:24:35]Failed to send packet - retrying
[17:24:36]Retry attempts failed
[17:24:36]NetworkProtocolTNFS::mount(TNFS.LOCAL,/SHOWTIME.BAS) - -1
[17:24:36]Protocol unable to make connection. Error: 138
[17:24:36]NetworkProtocolTNFS::dtor
[17:24:36]NetworkProtocol::dtor()
[17:24:36]ERROR!
[17:24:36]
[17:24:36]CF: 71 4f 04 00 c4
[17:24:36]sioNetwork::sio_process 0x4f 'O': 0x04, 0x00
[17:24:36]sioNetwork::sio_open()
[17:24:36]
[17:24:36]ACK!
[17:24:36]<-SIO read 256 bytes
[17:24:36]ACK!
[17:24:36]sioNetwork::parseURL(N:TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:24:36]sioNetwork::parseURL transformed to (N:TNFS://TNFS.LOCAL/SHOWTIME.BAS, TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:24:36]Parse and instantiate protocol: N:TNFS://TNFS.LOCAL/SHOWTIME.BAS
[17:24:36]NetworkProtocol::ctor()
[17:24:36]NetworkProtocolTNFS::ctor
[17:24:36]sioNetwork::open_protocol() - Protocol TNFS opened.
[17:24:36]Resolving hostname "TNFS.LOCAL"
[17:24:36]Name failed to resolve
[17:24:36]Failed to send packet - retrying
[17:24:37]Resolving hostname "TNFS.LOCAL"
[17:24:37]Name failed to resolve
[17:24:37]Failed to send packet - retrying
[17:24:38]Resolving hostname "TNFS.LOCAL"
[17:24:38]Name failed to resolve
[17:24:38]Failed to send packet - retrying
[17:24:39]Resolving hostname "TNFS.LOCAL"
[17:24:39]Name failed to resolve
[17:24:39]Failed to send packet - retrying
[17:24:40]Resolving hostname "TNFS.LOCAL"
[17:24:41]Name failed to resolve
[17:24:41]Failed to send packet - retrying
[17:24:42]Retry attempts failed
[17:24:42]NetworkProtocolTNFS::mount(TNFS.LOCAL,/SHOWTIME.BAS) - -1
[17:24:42]Protocol unable to make connection. Error: 138
[17:24:42]NetworkProtocolTNFS::dtor
[17:24:42]NetworkProtocol::dtor()
[17:24:42]ERROR!
[17:24:42]
[17:24:42]CF: 71 53 00 00 c4
[17:24:42]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[17:24:42]ACK!
[17:24:42]sioNetwork::sio_status_local(0)
[17:24:42]->SIO write 4 bytes
[17:24:42]COMPLETE!
[17:24:42]
[17:24:42]ACK!
[17:24:42]COMPLETE!
[17:24:42]
[17:24:42]CF: 71 43 00 00 b4
[17:24:42]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[17:24:42]sioNetwork::sio_close()
[17:24:42]ACK!
[17:24:42]COMPLETE!
Then using the lowercase of the URL:
Showing logs:
[17:26:12]
[17:26:12]CF: 71 00
[17:26:12]4f 04 c4sioNetrk::sx4f'O': 0x,
[17:26:12]oNetwork:sioe(
[17:26:12]wosio_proces 0 04 0x00si:o_pn)
[17:26:12]ACK!
[17:26:12]<S5s
[17:26:12]<S5s
Serial port closed!
[17:26:12]ACK!
[17:26:12]sioNetwork::parseURL(N:TNFS://tnfs.local/SHOWTIME.BAS)
[17:26:12]sioNetwork::parseURL transformed to (N:TNFS://tnfs.local/SHOWTIME.BAS, TNFS://tnfs.local/SHOWTIME.BAS)
[17:26:12]Parse and instantiate protocol: N:TNFS://tnfs.local/SHOWTIME.BAS
[17:26:12]NetworkProtocol::ctor()
[17:26:12]NetworkProtocolTNFS::ctor
[17:26:12]sioNetwork::open_protocol() - Protocol TNFS opened.
[17:26:12]Resolving hostname "tnfs.local"
[17:26:12]Resolved to address 192.168.7.94
[17:26:13]NetworkProtocolTNFS::mount(tnfs.local,/SHOWTIME.BAS) - 0
[17:26:13]NetworkProtocolFS::resolve(/SHOWTIME.BAS,/,SHOWTIME.BAS)
[17:26:13]Resolving hostname "tnfs.local"
[17:26:13]Resolved to address 192.168.7.94
[17:26:13]NetworkProtocolTNFS::stat(F: 1186, M: 33261, D: 113, L: 1) - 0
[17:26:13]Resolved to TNFS://tnfs.local/SHOWTIME.BAS
[17:26:13]TNFS open file: "/SHOWTIME.BAS" (0x0001, 0x0000)
[17:26:13]File opened, handle ID: 0, size: 1186, pos: 0
[17:26:13]NetworkProtocolTNFS::open_file_handle(mode: 1 perms 0) - 0
[17:26:13]COMPLETE!
[17:26:13]NetworkProtocolFS::read_file(512)
[17:26:13]NetworkProtocolTNFS::read_file_handle(B: 512, A: 512, T: 0)
[17:26:13]NetworkProtocol::read(512)
[17:26:13]
[17:26:13]CF: 71 53 00 00 c4
[17:26:13]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[17:26:13]ACK!
[17:26:13]sioNetwork::sio_status_channel(0)
[17:26:13]PROTOCOL
[17:26:13]sio_status_channel() - BW: 512 E: 1
[17:26:13]->SIO write 4 bytes
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]CF: 71 52 7f 00 43
[17:26:13]sioNetwork::sio_process 0x52 'R': 0x7f, 0x00
[17:26:13]sioNetwork::sio_read( 127 bytes)
[17:26:13]ACK!
[17:26:13]NetworkProtocolFS::read_file(127)
[17:26:13]NetworkProtocol::read(127)
[17:26:13]->SIO write 127 bytes
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]sio_status_channel() - BW: 385 E: 1
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]sio_status_channel() - BW: 258 E: 1
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]sio_status_channel() - BW: 131 E: 1
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]sio_status_channel() - BW: 4 E: 1
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]CF: 71 52 04 00 c7
[17:26:13]sioNetwork::sio_process 0x52 'R': 0x04, 0x00
[17:26:13]sioNetwork::sio_read( 4 bytes)
[17:26:13]ACK!
[17:26:13]NetworkProtocolFS::read_file(4)
[17:26:13]NetworkProtocol::read(4)
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]PROTOCOL
[17:26:13]COMPLETE!
[17:26:13]
[17:26:13]ACK!
[17:26:13]COMPLETE!
[17:26:14]
[17:26:14]CF: 71 53 00 00 c4
[17:26:14]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[17:26:14]ACK!
[17:26:14]sioNetwork::sio_status_channel(0)
[17:26:14]PROTOCOL
[17:26:14]sio_status_channel() - BW: 258 E: 1
[17:26:14]->SIO write 4 bytes
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]CF: 71 52 7f 00 43
[17:26:14]sioNetwork::sio_process 0x52 'R': 0x7f, 0x00
[17:26:14]sioNetwork::sio_read( 127 bytes)
[17:26:14]ACK!
[17:26:14]NetworkProtocolFS::read_file(127)
[17:26:14]NetworkProtocol::read(127)
[17:26:14]->SIO write 127 bytes
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]ACK!
[17:26:14]PROTOCOL
[17:26:14]sio_status_channel() - BW: 131 E: 1
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]ACK!
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]ACK!
[17:26:14]PROTOCOL
[17:26:14]sio_status_channel() - BW: 4 E: 1
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]CF: 71 52 04 00 c7
[17:26:14]sioNetwork::sio_process 0x52 'R': 0x04, 0x00
[17:26:14]sioNetwork::sio_read( 4 bytes)
[17:26:14]ACK!
[17:26:14]NetworkProtocolFS::read_file(4)
[17:26:14]NetworkProtocol::read(4)
[17:26:14]COMPLETE!
[17:26:14]NetworkProtocolFS::read_file(162)
[17:26:14]Resolving hostname "tnfs.local"
[17:26:14]Resolved to address 192.168.7.94
[17:26:14]NetworkProtocolTNFS::read_file_handle(B: 162, A: 162, T: 0)
[17:26:14]NetworkProtocol::read(162)
[17:26:14]
[17:26:14]ACK!
[17:26:14]PROTOCOL
[17:26:14]sio_status_channel() - BW: 162 E: 136
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]ACK!
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]ACK!
[17:26:14]PROTOCOL
[17:26:14]sio_status_channel() - BW: 35 E: 136
[17:26:14]COMPLETE!
[17:26:14]
[17:26:14]CF: 71 43 00 00 b4
[17:26:14]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[17:26:14]sioNetwork::sio_close()
[17:26:14]ACK!
[17:26:14]NetworkProtocolTNFS::close_file_handle(0) - 0
[17:26:14]NetworkProtocolTNFS::umount()
[17:26:14]COMPLETE!
[17:26:14]NetworkProtocolTNFS::dtor
[17:26:14]NetworkProtocol::dtor()
No errors, but the file doesn't load. The file does exist.
FWIW, here's the output that's in /var/log/syslog:
Apr  3 17:21:28 tnfs tnfsd[342]: 192.168.7.125 s=e146 c=01 q=04 | REQUEST cmd=0x01 TNFS_UMOUNT
Apr  3 17:21:28 tnfs tnfsd[342]: 192.168.7.125 s=e146 c=01 q=04 | Unmounting
Apr  3 17:21:28 tnfs tnfsd[342]: Freeing session ID index 9
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=00 c=00 q=00 | REQUEST cmd=0x00 TNFS_MOUNT
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=00 c=00 q=00 | TNFS_MOUNT
Apr  3 17:26:14 tnfs tnfsd[342]: Looking for existing sessions with IP 192.168.7.125
Apr  3 17:26:14 tnfs tnfsd[342]: Allocating new session for 0x00
Apr  3 17:26:14 tnfs tnfsd[342]: Allocated new session for 0x7c
Apr  3 17:26:14 tnfs tnfsd[342]: validate_dir: Path='/tnfs/'
Apr  3 17:26:14 tnfs tnfsd[342]: validate_dir: Directory OK
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=7c c=00 q=00 | Mounted / OK, SID=7c
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=7c c=24 q=01 | REQUEST cmd=0x24 TNFS_STAT
Apr  3 17:26:14 tnfs tnfsd[342]: stat: bufsz=14 buf=/SHOWTIME.BAS
Apr  3 17:26:14 tnfs tnfsd[342]: stat: path=/tnfs/SHOWTIME.BAS
Apr  3 17:26:14 tnfs tnfsd[342]: stat: OK
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=7c c=24 q=02 | REQUEST cmd=0x24 TNFS_STAT
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=7c c=29 q=03 | REQUEST cmd=0x29 TNFS_OPEN
Apr  3 17:26:14 tnfs tnfsd[342]: filename: /SHOWTIME.BAS
Apr  3 17:26:14 tnfs tnfsd[342]: flags: 1
Apr  3 17:26:14 tnfs tnfsd[342]: mode: 0
Apr  3 17:26:14 tnfs tnfsd[342]: open: fd=8
Apr  3 17:26:14 tnfs tnfsd[342]: 192.168.7.125 s=7c c=21 q=04 | REQUEST cmd=0x21 TNFS_READ
Apr  3 17:26:15 tnfs tnfsd[342]: 192.168.7.125 s=7c c=21 q=05 | REQUEST cmd=0x21 TNFS_READ
Apr  3 17:26:15 tnfs tnfsd[342]: 192.168.7.125 s=7c c=21 q=06 | REQUEST cmd=0x21 TNFS_READ
Apr  3 17:26:15 tnfs tnfsd[342]: 192.168.7.125 s=7c c=21 q=07 | REQUEST cmd=0x21 TNFS_READ
Apr  3 17:26:15 tnfs tnfsd[342]: EOF
Apr  3 17:26:16 tnfs tnfsd[342]: 192.168.7.125 s=7c c=01 q=08 | REQUEST cmd=0x01 TNFS_UMOUNT
Apr  3 17:26:16 tnfs tnfsd[342]: 192.168.7.125 s=7c c=01 q=08 | Unmounting
Apr  3 17:26:16 tnfs tnfsd[342]: Freeing session ID index 9
I attempted to save a small "hello world" program (10 PRINT "HELLO WORLD"). The file was created on the server, but it's empty:
Showing logs:
[17:30:11]
[17:30:11]CF: 71 8 00 c8
[17:30:11]sioNetwor::siopcess4fO': x,
[17:30:11]4f 0k_ro 0x '0080x00sioNetwork::sio_open(
[17:30:11])
[17:30:11]CK!
[17:30:11]eigextng atmer
[17:30:11]ADeltn isireTi
[17:30:11]rd 25 bes
[17:30:12]<-SIO ea6ytCK!
[17:30:12]twprse/tnfs.local/LL.BAS)
[17:30:12]AsioNeork::aURL(N:TNFS:/HEOsioNewrp t (N:TFS:/s.laH, TNFS:f.clHLL.
[17:30:12]nrl: :TNFS/nf.lclLO.AS
[17:30:12]tok::arseURL transformedoN/tnfocl/ELLO.BAS//tnsloa/EOBAS)Parse and instatiate potocoN:/tsoa/HELBNetrrt:tr)
[17:30:12]okrtcoTF:co
[17:30:12]wokPoocol:co(NetwrPoolNS:trsioNetwr:oe_rcl  rtclTF pnd
[17:30:12]ok:pnpotoo()-Pooo NSoee.Resovn snm "n.cl
Serial port closed!
[17:30:12]Resolved to address 192.168.7.94
[17:30:12]NetworkProtocolTNFS::mount(tnfs.local,/HELLO.BAS) - 0
[17:30:12]NetworkProtocolFS::resolve(/HELLO.BAS,/,HELLO.BAS)
[17:30:12]Resolving hostname "tnfs.local"
[17:30:12]NetworkProtocolTNFS::stat(F: 1, M: 1, D: 113, L: 0) - 2
[17:30:12]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="*" path="/"
[17:30:12]Directory opened, handle ID: 0, entries: 12
[17:30:12]NetworkProtocolTNFS::open_dir_handle(/, *) - 0
[17:30:12]tnfs_readdirx resp_count=12, dirpos=0, status=1
[17:30:12]tnfs_readdirx cached 12 entries
[17:30:12]	_readdirx_fill_response: dir: Yes, size: 4096, mtime: 2021-03-07 10:56:27, ctime: 2021-03-07 10:56:27 "action"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: action, F: 4096, M: 1, D: 1, L: 0) - 0
[17:30:12]current entry "action" crunched entry "ACTION"
[17:30:12]tnfs_readdirx responding from cached entry
[17:30:12]	_readdirx_fill_response: dir: Yes, size: 4096, mtime: 2021-04-03 16:21:16, ctime: 2021-04-03 16:21:16 "Dev"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: Dev, F: 4096, M: 1, D: 1, L: 0) - 0
[17:30:12]current entry "Dev" crunched entry "DEV"
[17:30:12]	_readdirx_fill_response: dir: Yes, size: 4096, mtime: 2021-01-16 17:58:26, ctime: 2021-01-16 17:58:26 "misc-apps"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: misc-apps, F: 4096, M: 1, D: 1, L: 0) - 0
[17:30:12]current entry "misc-apps" crunched entry "MISCAPPS"
[17:30:12]	_readdirx_fill_response: dir: no, size: 133136, mtime: 2021-02-02 17:51:13, ctime: 2021-02-02 17:51:13 "action.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: action.atr, F: 133136, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "action.atr" crunched entry "ACTION.ATR"
[17:30:12]	_readdirx_fill_response: dir: no, size: 133136, mtime: 2020-11-28 11:40:25, ctime: 2021-01-16 17:56:14 "blank.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: blank.atr, F: 133136, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "blank.atr" crunched entry "BLANK.ATR"
[17:30:12]	_readdirx_fill_response: dir: no, size: 133136, mtime: 2021-01-19 17:25:39, ctime: 2021-01-19 17:25:39 "dev2.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: dev2.atr, F: 133136, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "dev2.atr" crunched entry "DEV2.ATR"
[17:30:12]	_readdirx_fill_response: dir: no, size: 9463, mtime: 2020-11-29 18:36:47, ctime: 2021-01-16 17:56:19 "ELIZA.BAS"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: ELIZA.BAS, F: 9463, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "ELIZA.BAS" crunched entry "ELIZA.BAS"
[17:30:12]	_readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-29 12:06:38, ctime: 2021-01-16 17:56:27 "n-handler.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: n-handler.atr, F: 92176, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "n-handler.atr" crunched entry "NHANDLER.ATR"
[17:30:12]	_readdirx_fill_response: dir: no, size: 92176, mtime: 2020-12-05 15:36:24, ctime: 2021-01-16 17:56:27 "oilwells.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: oilwells.atr, F: 92176, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "oilwells.atr" crunched entry "OILWELLS.ATR"
[17:30:12]	_readdirx_fill_response: dir: no, size: 67596, mtime: 2020-12-18 16:35:34, ctime: 2021-01-16 17:56:28 "s3loader.xex"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: s3loader.xex, F: 67596, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "s3loader.xex" crunched entry "S3LOADER.XEX"
[17:30:12]	_readdirx_fill_response: dir: no, size: 1186, mtime: 2021-02-02 16:52:03, ctime: 2021-02-02 16:52:03 "SHOWTIME.BAS"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: SHOWTIME.BAS, F: 1186, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "SHOWTIME.BAS" crunched entry "SHOWTIME.BAS"
[17:30:12]	_readdirx_fill_response: dir: no, size: 92176, mtime: 2021-02-02 16:52:18, ctime: 2021-02-02 16:52:18 "work.atr"
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: work.atr, F: 92176, M: 1, D: 0, L: 0) - 0
[17:30:12]current entry "work.atr" crunched entry "WORK.ATR"
[17:30:12]tnfs_readdirx returning EOF based on cached value
[17:30:12]NetworkProtocolTNFS::read_dir_entry(N: work.atr, F: 92176, M: 1, D: 0, L: 0) - 33
[17:30:12]NetworkProtocolTNFS::close_dir_handle() - 0
[17:30:12]Resolved to TNFS://tnfs.local/HELLO.BAS
[17:30:12]TNFS open file: "/HELLO.BAS" (0x0302, 0x01ff)
[17:30:12]File opened, handle ID: 0, size: 0, pos: 0
[17:30:12]NetworkProtocolTNFS::open_file_handle(mode: 770 perms 511) - 0
[17:30:12]COMPLETE!
[17:30:12]
[17:30:12]CF: 71 53 00 00 c4
[17:30:12]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[17:30:12]ACK!
[17:30:12]sioNetwork::sio_status_channel(0)
[17:30:12]PROTOCOL
[17:30:12]sio_status_channel() - BW: 0 E: 136
[17:30:12]->SIO write 4 bytes
[17:30:12]COMPLETE!
[17:30:12]
[17:30:12]CF: 71 43 00 00 b4
[17:30:12]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[17:30:12]sioNetwork::sio_close()
[17:30:12]ACK!
[17:30:12]NetworkProtocolTNFS::close_file_handle(0) - 0
[17:30:12]NetworkProtocolTNFS::umount()
[17:30:12]COMPLETE!
[17:30:12]NetworkProtocolTNFS::dtor
[17:30:12]NetworkProtocol::dtor()
* sigh * Nevermind.
I (dumbly) didn't bother updating my work disk that I was using with the latest version of the N Handler. Once I did that, I'm able to read my files.
Though it does still have the issue of not being able to resolve UPPER CASE Url's
Showing logs:
[17:51:05]
[17:51:05]71 0 c4
[17:51:05]CF:  4f 040sioNetwork::io_proces 04f ': 4 00
[17:51:05]rk::sio_op
[17:51:05]ACK!
[17:51:05]ssx'O0x0,0xsioNetwoen()
[17:51:05]<-SIO re256 bs
Serial port closed!
[17:51:05]ACK!
[17:51:05]sioNetwork::parseURL(N:TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:51:05]sioNetwork::parseURL transformed to (N:TNFS://TNFS.LOCAL/SHOWTIME.BAS, TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:51:05]Parse and instantiate protocol: N:TNFS://TNFS.LOCAL/SHOWTIME.BAS
[17:51:05]NetworkProtocol::ctor()
[17:51:05]NetworkProtocolTNFS::ctor
[17:51:05]sioNetwork::open_protocol() - Protocol TNFS opened.
[17:51:05]Resolving hostname "TNFS.LOCAL"
[17:51:05]Name failed to resolve
[17:51:05]Failed to send packet - retrying
[17:51:06]Resolving hostname "TNFS.LOCAL"
[17:51:06]Name failed to resolve
[17:51:06]Failed to send packet - retrying
[17:51:07]Resolving hostname "TNFS.LOCAL"
[17:51:07]Name failed to resolve
[17:51:07]Failed to send packet - retrying
[17:51:08]Resolving hostname "TNFS.LOCAL"
[17:51:08]Name failed to resolve
[17:51:08]Failed to send packet - retrying
[17:51:09]Resolving hostname "TNFS.LOCAL"
[17:51:09]Name failed to resolve
[17:51:09]Failed to send packet - retrying
[17:51:10]Retry attempts failed
[17:51:10]NetworkProtocolTNFS::mount(TNFS.LOCAL,/SHOWTIME.BAS) - -1
[17:51:10]Protocol unable to make connection. Error: 138
[17:51:10]NetworkProtocolTNFS::dtor
[17:51:10]NetworkProtocol::dtor()
[17:51:10]ERROR!
[17:51:10]
[17:51:10]CF: 71 4f 04 00 c4
[17:51:10]sioNetwork::sio_process 0x4f 'O': 0x04, 0x00
[17:51:10]sioNetwork::sio_open()
[17:51:10]
[17:51:10]ACK!
[17:51:10]<-SIO read 256 bytes
[17:51:10]ACK!
[17:51:10]sioNetwork::parseURL(N:TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:51:10]sioNetwork::parseURL transformed to (N:TNFS://TNFS.LOCAL/SHOWTIME.BAS, TNFS://TNFS.LOCAL/SHOWTIME.BAS)
[17:51:10]Parse and instantiate protocol: N:TNFS://TNFS.LOCAL/SHOWTIME.BAS
[17:51:10]NetworkProtocol::ctor()
[17:51:10]NetworkProtocolTNFS::ctor
[17:51:10]sioNetwork::open_protocol() - Protocol TNFS opened.
[17:51:10]Resolving hostname "TNFS.LOCAL"
[17:51:10]Name failed to resolve
[17:51:10]Failed to send packet - retrying
[17:51:11]Resolving hostname "TNFS.LOCAL"
[17:51:11]Name failed to resolve
[17:51:11]Failed to send packet - retrying
[17:51:12]Resolving hostname "TNFS.LOCAL"
[17:51:12]Name failed to resolve
[17:51:12]Failed to send packet - retrying
[17:51:13]Resolving hostname "TNFS.LOCAL"
[17:51:13]Name failed to resolve
[17:51:13]Failed to send packet - retrying
[17:51:14]Resolving hostname "TNFS.LOCAL"
[17:51:14]Name failed to resolve
[17:51:14]Failed to send packet - retrying
[17:51:15]Retry attempts failed
[17:51:15]NetworkProtocolTNFS::mount(TNFS.LOCAL,/SHOWTIME.BAS) - -1
[17:51:15]Protocol unable to make connection. Error: 138
[17:51:15]NetworkProtocolTNFS::dtor
[17:51:15]NetworkProtocol::dtor()
[17:51:15]ERROR!
[17:51:15]
[17:51:15]CF: 71 53 00 00 c4
[17:51:15]sioNetwork::sio_process 0x53 'S': 0x00, 0x00
[17:51:15]ACK!
[17:51:15]sioNetwork::sio_status_local(0)
[17:51:15]->SIO write 4 bytes
[17:51:15]COMPLETE!
[17:51:16]
[17:51:16]CF: 71 43 00 00 b4
[17:51:16]sioNetwork::sio_process 0x43 'C': 0x00, 0x00
[17:51:16]sioNetwork::sio_close()
[17:51:16]ACK!
[17:51:16]COMPLETE!
8 hours ago, tsom said:
* sigh * Nevermind.
Showing logs:
[17:51:05]
[17:51:05]71 0 c4
[17:51:05]ACK!
Serial port closed!
[17:51:05]ACK!
[17:51:10]ERROR!
[17:51:10]
[17:51:10]
[17:51:10]ACK!
[17:51:10]ACK!
[17:51:15]ERROR!
[17:51:15]
[17:51:15]ACK!
[17:51:15]COMPLETE!
[17:51:16]
[17:51:16]ACK!
[17:51:16]COMPLETE!
Upper case URLs I can do nothing about, the DNS resolver on your router is doing something very dumb.
-Thom
-Thom
The odd thing is, upper case urls for the hosts resolve just fine, it’s just when using the N device in this situation. I’ll keep digging...
oh wow, I would never user multicast DNS for any of this stuff, I steer clear of it. It's been an issue for too many people over the years, I'd check out some Eero forums for ideas. It really can clog up a network and grind stuff to a halt depending on what all you have in use...
