a8isa1 Posted April 5, 2021 Share Posted April 5, 2021 I don't know if I've encountered a bug, two bugs, or I'm misunderstanding how this is supposed to work. I'm running Fujinet 1.0 hardware. It's externally powered plugged into my 800XL. FN firmware is 0.5.879c407c 2021-04-02 01:14:21. WebUI has CONFIG Boot set. I've mounted Atari DOS 2.0S ATR from ATARI-APPS.IRATA.ONLINE. It boots OK. When I press FujNet Reset I expect to see the Config disk appear as D1:. However, when I try to get a directory listing the activity light flashes brightly then goes to dimly lit for a couple of seconds. I get Error 138. If I then do a coldstart (FN is still powered) the activity light flashes once dimly then the 800XL reboots itself, over and over again. I'm providing a debug trace. It begins when I try to get that directory listing. Regards, SteveS FN_reset_capture.zip Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 5, 2021 Share Posted April 5, 2021 This has been a major point of contention, as this was supposed to be how it worked. However, it seemed to conflict with people who were using a real D1: device (as it would eventually trip the status counter). I spent two months going back and forth with @mr-atari on this. The mode we came up with finally was able to stay silent and not accidentally be triggered, while still allowing use with SpartaDOS X after you tapped the reset button. I really need somebody to look at this and see if it can be done better. -Thom Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 5, 2021 Author Share Posted April 5, 2021 (edited) 21 minutes ago, tschak909 said: This has been a major point of contention, as this was supposed to be how it worked. However, it seemed to conflict with people who were using a real D1: device (as it would eventually trip the status counter). I spent two months going back and forth with @mr-atari on this. The mode we came up with finally was able to stay silent and not accidentally be triggered, while still allowing use with SpartaDOS X after you tapped the reset button. I really need somebody to look at this and see if it can be done better. -Thom I see. Here's my 2 cents: Configured as I described. I press FN Reset. Now my ATR is no longer mounted. Config disk is not mounted either. I shut off my Atari and turn it back on. I don't get into CONFIG and I don't boot a mounted disk. I have nothing available. I can only get back to operational if I remember to pull the plug on FujiNet. I have to do this to physcially reach the power switch on Fujinet 1.0 as the cable end partially blocks access to the switch. No, I don't offer a solution. I'm just venting. SteveS p.s. Done venting. Perhaps yet another button mode that forces CONFIG disk to be mounted. [EDIT] Once FNC-TOOLS are available I can help myself of out my mess. Edited April 5, 2021 by a8isa1 Quote Link to comment Share on other sites More sharing options...
phigan Posted April 5, 2021 Share Posted April 5, 2021 (edited) *Deleted*.. I think what I said only applies to images off SD. Edited April 5, 2021 by phigan Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 5, 2021 Share Posted April 5, 2021 1 hour ago, a8isa1 said: I see. Here's my 2 cents: Configured as I described. I press FN Reset. Now my ATR is no longer mounted. Config disk is not mounted either. I shut off my Atari and turn it back on. I don't get into CONFIG and I don't boot a mounted disk. I have nothing available. I can only get back to operational if I remember to pull the plug on FujiNet. I have to do this to physcially reach the power switch on Fujinet 1.0 as the cable end partially blocks access to the switch. No, I don't offer a solution. I'm just venting. SteveS p.s. Done venting. Perhaps yet another button mode that forces CONFIG disk to be mounted. [EDIT] Once FNC-TOOLS are available I can help myself of out my mess. I always put the latest fnc-tools on atari-apps.irata.online in the root. -Thom Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted April 5, 2021 Author Share Posted April 5, 2021 (edited) 1 hour ago, tschak909 said: I always put the latest fnc-tools on atari-apps.irata.online in the root. -Thom I'm going mad! Someone please try this: Make sure FujiNet is powered externally. Make sure webui has Config Boot set. Boot Atari to CONFIG Mount from ATARI-APPS.IRATA.ONLINE/DOS/Atari DOS 2.0s.atr Press OPTION to boot Atari DOS Press FujiNet Button C *RESET* Try to get a directory listing. You should get Error 138 <------- Do NOT skip this step Try to reboot your Atari. Do an atari RESET. Turn off the machine then on. Try FN Reset more times. Just don't unplug Fujinet's power cable *YET*. For me CONFIG will never boot again. I'm stuck until I unplug FujiNet's power cable. Regards, SteveS Edited April 5, 2021 by a8isa1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 5, 2021 Share Posted April 5, 2021 14 minutes ago, a8isa1 said: I'm going mad! Someone please try this: Make sure FujiNet is powered externally. Make sure webui has Config Boot set. Boot Atari to CONFIG Mount from ATARI-APPS.IRATA.ONLINE/DOS/Atari DOS 2.0s.atr Press OPTION to boot Atari DOS Press FujiNet Button C *RESET* Try to get a directory listing. You should get Error 138 <------- Do NOT skip this step Try to reboot your Atari. Do an atari RESET. Turn off the machine then on. Try FN Reset more times. Just don't unplug Fujinet's power cable *YET*. For me CONFIG will never boot again. I'm stuck until I unplug FujiNet's power cable. Regards, SteveS Yes, as I said above, this is a known issue, I have no fix for it at present, because fixing it seems to break behavior that other people want. -Thom Quote Link to comment Share on other sites More sharing options...
mr-atari Posted April 6, 2021 Share Posted April 6, 2021 Standard 850 protocol to me. Works for me perfectly. I use this tool to change my config. FujiNet.xex 1 Quote Link to comment Share on other sites More sharing options...
