Thomas Jentzsch Posted April 15, 2021 Author Share Posted April 15, 2021 (edited) I have made the code more versatile, it should now be easier to use different sizes than 25x25. I also added a playfield display mode. To do so, the QR code data is rearranged after it has been created. QR Code Generator V0.4 (Thomas Jentzsch) (2021).bin Edited April 15, 2021 by Thomas Jentzsch 6 1 Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted October 22, 2021 Share Posted October 22, 2021 On 4/15/2021 at 10:14 AM, Thomas Jentzsch said: I have made the code more versatile, it should now be easier to use different sizes than 25x25. I also added a playfield display mode. To do so, the QR code data is rearranged after it has been created. QR Code Generator V0.4 (Thomas Jentzsch) (2021).bin 4 kB · 17 downloads Thomas does your QR code generator handle the larger 29x29 (Version 3) generation? Would be great to have the 6502 code made more general, i.e. Output the QR code to a memory location Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 22, 2021 Author Share Posted October 22, 2021 1 hour ago, RetroCoder said: Thomas does your QR code generator handle the larger 29x29 (Version 3) generation? IIRC version 3 (29x29) is the upper limit. Beyond that size, the already pretty complex QR code is getting even more complex. 1 hour ago, RetroCoder said: Would be great to have the 6502 code made more general, i.e. Output the QR code to a memory location. Not sure what that should be useful for. Also you will need extra RAM for this. Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted October 22, 2021 Share Posted October 22, 2021 43 minutes ago, Thomas Jentzsch said: IIRC version 3 (29x29) is the upper limit. Beyond that size, the already pretty complex QR code is getting even more complex. Not sure what that should be useful for. Also you will need extra RAM for this. Then the code could be used in other 6502 based systems and not only the 2600 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted October 22, 2021 Author Share Posted October 22, 2021 1 hour ago, RetroCoder said: Then the code could be used in other 6502 based systems and not only the 2600 I wouldn't mind if someone forked my and extended code for other systems. Quote Link to comment Share on other sites More sharing options...
