Fujinet Hardware 1.4 / 1.5
On 8/29/2021 at 10:57 AM, Brentarian said:
@irich2, If you are running a TNFS server on an RPi, why not also use that RPi as an access point and keep near your Fujinet?
https://thepi.io/how-to-use-your-raspberry-pi-as-a-wireless-access-point/
Great suggestion!  I was thinking that this would wind up being my solution to use wired ethernet with FujiNet in the end.
23 hours ago, Mazzspeed said:
If you want Ethernet, run FujiNet-PC on a RPi. That's what I do and Ethernet works fine.
I have no problem using WiFi, that's just how my RPi400 was configured when I installed FujiNet-PC, so I left it that way.
I haven't heard of this.  Thank you for the suggestion!  I will look into this as another option.
Thank you @mozzwald and @mytek for your feedback about a potential wired/wireless FujiNet.  I agree that the FujiNet servers the vast majority of the Atari community very well in its current state.  The discussion did lead to some excellent suggestions to add a "wired" ability to FujiNet by either (1) using a RPi as a wireless access point (Thank You, @Brentarian!) or (2) using a SIO2PC-USB adapter with the FujiNet-PC project (Thank You @apc and @Mazzspeed!).
  • 3 weeks later...
Hi all,
maybe stupid question, sorry for that > is there someone tried to connect two Atari 800XL through Fujinet to gaming or even better transfer data or making serious work online please? Sorry > quite newbie with Fujinet ...but happy Fujinet card owner over here :)
regards,
Petr O.
6 hours ago, ok1rp said:
Hi all,
regards,
Petr O.
Games:
Midimaze and Warships are 2 other games.
This thread is about FujiNet hardware, you should probably start a new thread topic in this subforum and ask again.
  • 1 month later...
3 hours ago, ok1rp said:
Hi all,
is it possible to read the SD card inserted directly into the Fujinet card slot please? Tried to do it but I see an error in reading.
Thanks for hint.
Petr
Can you please clarify / rephrase your question? Are you not able to access/mount disk images from the SD card on FujiNet?
2 hours ago, ok1rp said:
Well, so sorry for my bad expression...
The goal is to boot SpartaDOS from SD card inserted in Fujinet > so if I am right I have problem to mount disk images from SD card on Fujinet...
Petr
Your SD card should be formatted FAT32 and contain your disk image files. In CONFIG you need a Host Slot named "SD" which, when selected will show the contents of the SD card and you can select a disk image to mount.
If you are getting an error message, please post it here. Also it would be useful to post the serial debug output by connecting Fujinet to a computer, running fujinet flasher, pressing the serial debug output button, try loading a file from SD and copy/paste that info here (in a spoiler tag preferably).
