CD Game Support
SainT
3 minutes ago, SainT said:
I suspect you have a new cart. Hit OPTION when prompted to on boot up and use the link provided.
DO NOT USE THIS IF YOU HAVE A NEWER CART, IT WILL NOT WORK PROPERLY.
Thanks, just confirmed it. I read your initial post as a double negative and assumed I had an old cart.
For fools like me - downloading the proper patch via the options link does fix it - booted up a CD game.
Thanks SainT!
4 hours ago, SainT said:
Another version to try for the older carts --
I've tested this and it's working on my downgraded dev cart, so it should be good for everyone now. But if I could have confirmation before I start shouting about it, please! :)
** Anyone who tested the previous version, please rename to firmware.ovr as it will not update the microcontroller firmware correctly without this change. Anyone installing from a regular previous firmware, just use as is **
This worked great for me. Thanks!
Edited by SainT
Ok I must be really slow but Im still not clear on what file I need to update my original JagSD - From RetroHQ I downloaded the "Firmware" file for original owners titled:
firmware-210414.zip
Inside that is a firmware.upd file.
Since I did not try the original update file, I should rename this file to:
firmware.ovr
and place in the root directory of my SD card for the JagSD
Is this correct?
https://www.retrohq.co.uk/products/jaggd/............zip
** REMOVED ** I'm happy this is working and it's only confusing matters. If you have the "Press OPTION for firmware update." while booting, THEN DO THIS.
I grabbed it before you took it down, but I haven't had a chance to test it yet, will do tonight.
Just wanted to say I got that feeling playing the Jaguar yesterday that I have not had since like 2000-2001.
Soooo many Jag CD games I haven't fired up in a long time.   I can see why it's been that long (cough cough... Hoverstrike) but a lot of fun to see them again.
Also great to play regular games, like Battlemorph.   Actually, I think Battlemorph and Gorf were the sole reason I kept a Jag CD around.
Only reason I kept mine was for VLM.
Got many games to work but still puzzled why Battlemorph won't boot. Converted perfectly from that redump set but started only once in about 15 tries ^^
Other games not working:
Dragons lair
World tour racing
Vid grid (hangs at loading screen in game)
But got varunas forces to boot ^^
Dragons lair
World tour racing
I have a few Varunas Forces and did get them to boot as well. Also have Dragon's Lair working. Still struggling with my American Hero, Robinon's Requiem, BIWN, World Tour Racing as well. The 1 Battlemorph I have has worked just fine. It's odd when some of these work for others and not for some. When Battlemorph loads it does say "No Memory Track" so before I get far into it will have to test if it generates a save file and actually saves. I believe it should tho.
13 hours ago, SainT said:
Ooh, that is interesting. I have a limit of 81 tracks for CD images currently, I'll have to increase that if it uses more. If you can (privately) provide a link to the image I'll take a look.
i did mention this previously on a twitter pm but as you didn't reply i thought you were not interested in it so i didn't peruse any further.
i will sort something out and get it to you
Just wanted to say this worked perfect for me and was able to get the couple games I tried to boot!
On 4/13/2021 at 11:43 AM, SainT said:
You need to run from the directory the CCD is in. It doesn't translate the path from the CCD to the IMG. So what I said above was right... I'm not reporting a missing IMG but just bailing. ?
WTR doesn't work anyway... ?
I'm a bit confused by this.  I can't seem to get any CCDs to work.  bin/cue and cdi work fine, but the CCDs just exit without doing anything - I've tried this on three different images with the same results.  I've tried placing the image and the executable in the same directory and specifying the full path to the CCD instead of just the relative path and vice-versa.  I was able to find bin/cues for most of the ones I had in CCD but not everything.
I had the exact same experience...
Ended up going to my CDs today and ripped them all as .CDI files to make them work, but with varying results.
Working:
American Hero (and a second Disc, no clue where I got that from but with noninteractive footage that I never saw before. Interesting)
Baldies
Caves of fear
Demolition Man
Primal Rage
Highlander (Yikes even more cumbersome than I already remembered. :-))
Hover Strike
Impulse X
Scatologic Demo Disc
Soulstar (Unencrypted?/ Has Music in Intro, no Music in gameplay)
Space Ace
Varunas Forces
Non working: Most aren't marked as "not contiguos" although I do not quite understand what it means as most are ripped exactly as the working ones above and in the same folder on the same SD card so no clue what makes the difference....
Battlemorph
BIWN Rev 18 & 23
Blue Lightning
Brain Dead
Dragons Lair
Iron Soldier 2
Myst
Soulstar (encrypted/ it locks on the Game Drive Menu and everything is frozen)
A video of the Jaguar Press conference won't even register that I pressed a button and just freeze everything
Frog Feast ( Stuck freeze on Loading CD Rom popup)
World Tour Racing (Shows Teque Logo and plays music from the intro afterwards only black screen)
Working:
Baldies
Caves of fear
Demolition Man
Primal Rage
Hover Strike
Impulse X
Space Ace
Varunas Forces
Battlemorph
BIWN Rev 18 & 23
Blue Lightning
Brain Dead
Dragons Lair
Iron Soldier 2
Myst
I can help with the non-contiguous bit.  That refers to how the files were written to the SD card.  Contiguous means that they’re written one byte after another all in a row. Non-contiguous means that Windows (or whatever OS you use) fragmented the files when writing them to the SD card.  Normally fragmentation isn’t considered an error as most programs don’t care about jumping around in the storage to the different spots where the data actually exists, but the JagGD is working on very thin margins in terms of speed and can’t tolerate fragmented files. You can’t see fragmentation without special tools and unfortunately you can’t tell your OS not to fragment files when writing.  Your only option for fixing the non-contiguous ones is to reformat your SD card and copy everything back.  When you do that it should copy the files serially and the fresh file system won’t want to fragment your files.  Once you start deleting files from your SD card they will leave gaps and you’re likely to run into fragmentation again so you may have to do this more than once.
What program are people using to rip to .cdi format? Imgburn only does bin/cue for me and cd2jcd refuses to convert any of them. alcohol120% will make .ccd but cd2jcd freezes and force closes anytime I try to convert a .ccd
The only conversions that have worked are .cdi I had bit don't know what program does those. As I want to try American Hero and Robinsons Requiem to make them .cdi and then try cd2jcd to make them into jcd
Thank you for the explanation, very much appreciated. This could very well be with all the copying of stuff I did the last days. I will try that now. There goes the second's night sleep. :-D
I'm having a weird problem where pressing B in the menu on any and all jcd files does nothing. I used the known-good set and converted them with no errors, but they just won't load. Non-CD games load fine. My Jaguar is a pretty early one, I think. My GameDrive has firmware v1.09, menu v1.06, asic v1.06, and stub v1.03.
Oh yeah, my sd card is a SanDisk Ultra 32GB class 10.
Edited by dragonHunter
Forgot to mention sd type...
Did you update the firmware? Seems like you still have the version without CD-Support.
Mine is like this after the update: Firmware V1.10, Menu V1.07, ASIC V1.01, Stub V1.03
So the formatting really did the trick for almost all games and now I see that SainT already mentioned that in his first post and I somehow missed it, duh. But well things look much better now and no prompts about not being contigous anymore...
Working:
American Hero
Battlemorph (Loaded on first try)
Blue Lightning
Baldies
Caves of fear
Demolition Man
Primal Rage
Highlander
Hover Strike
Brain Dead
Dragons Lair
Iron Soldier 2
Myst
Impulse X
Soulstar (Unencrypted?/ Has Music in Intro but no music during gameplay for some reason)
Space Ace
Varunas Forces
Video Jag Press conference 1
Non working:
BIWN Rev 18 (Black screen)
BIWN 23 (Freeze/reaaaally slow loading, almost no progress)
Vid Grid (Black Screen)
Video of the Jaguar Press conference 2 (still freezing/Maybe bad source CD)
World Tour Racing (Shows Teque Logo and plays Intro and Demo mode before going to black screen)
Forgot to try:
Frog Feast
Soulstar (encrypted)
Same here.  CCD just exit without error and no file being created.
20 minutes ago, Zerosquare said:
I wonder if there would be a need for a tool which would copy files to a SD card while making sure they're not fragmented. (The "lazy" way would be generating a fresh FAT32 file system image and writing it to the card.)
The lazy way would be to find all the fragmented sectors and mark in the fat they're full :P
  • Haha 1
