senior_falcon Posted May 16, 2021 Share Posted May 16, 2021 1 hour ago, RXB said: Luckily it only fetches ROW and COLUMN once from Floating Point, and you can speed this up a little bit in GPL by using same routine that fetches in INVERSE. No need for Floating point in these so you can just read the value 2 bytes that would be integer values converted from floating point XML SPEED DATA >00EC says check if number or string value and if string error if number Reveal hidden contents [4286] *********************************************************** [4287] * CALL INVERSE(char#[,...]) [4288] *********************************************************** [4289] BC9A 06,A9,81 INVERS CALL COMB * INVERSE(CHAR#) [4290] BC9D 0F,79 INVAGN XML PGMCHR [4291] BC9F D6,42,EC CEQ ALLZ,@CHAT [4292] BCA2 5C,B6 BR INOALL [4293] BCA4 0F,7E XML SPEED [4294] BCA6 00,EC DATA >00EC [4295] BCA8 BF,4A,00 DST >001E,@FAC * ALL token? BCAB 1E [4296] BCAC E3,4A,00 DSLL 3,@FAC BCAF 03 [4297] BCB0 BF,54,01 DST >01C8,@TEMP1 BCB3 C8 [4298] BCB4 5C,C4 BR INVLP [4299] BCB6 0F,74 INOALL XML PARSE [4300] BCB8 B6 BYTE RPARZ [4301] BCB9 06,BD,75 CALL S1ET9F [4302] BCBC E3,4A,00 DSLL 3,@FAC BCBF 03 [4303] BCC0 BF,54,00 DST >0004,@TEMP1 BCC3 04 [4304] BCC4 85,E3,00 INVLP DINV V@>0300(@FAC) BCC7 4A [4305] BCC8 A3,4A,00 DADD >0002,@FAC BCCB 02 [4306] BCCC 93,54 DDEC @TEMP1 [4307] BCCE 5C,C4 BR INVLP [4308] BCD0 D6,42,B3 INVNOK CEQ COMMAZ,@CHAT [4309] BCD3 7C,9D BS INVAGN [4310] BCD5 4A,96 BR LNKRTN [4311] *********************************************************** [4370] ***************************************** [4371] BD75 0F,7E S1ET9F XML SPEED * CHECK FROM [4372] BD77 02,1E DATA >021E * 30 TO 159 [4373] BD79 00,9F DATA >009F * [4374] BD7B 00 RTN * [4375] ****************************************** I should test this to see if this is true as I have always just taken for granted looking at XB ROMs that it does not do CFI ever. As the VALUE in FAC is not changed using DEBUG in Classic99 you see >10 if do a CALL INVERSE(32) that is not a Floating Point value. Well just check with Debugger and if you put a break point at >12B8 (this is CFI) it never breaks so never used CFI XML in console routine. Thus I should change most RXB routines that do not need Floating Point to this version and that should speed up XB by a marked amount. I stand corrected. The line below is what threw me: HCHAR1 BYTE >08,>E0,>00,>FB * FMT '@VAR0' Display horizo I assumed format fetched VAR0 from XB and did the floating point conversion to it, but it turns out VAR0 is the value at >8300 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 16, 2021 Share Posted May 16, 2021 1 hour ago, senior_falcon said: I stand corrected. The line below is what threw me: HCHAR1 BYTE >08,>E0,>00,>FB * FMT '@VAR0' Display horizo I assumed format fetched VAR0 from XB and did the floating point conversion to it, but it turns out VAR0 is the value at >8300 Actually you have helped me look at the code of XB and realize I can modify all access to Variables and remove FP from them. Example is right now I am working on CALLL PEEK so it will not do Floating Point for address and it should only care about -32767 to 32768. In this case only works with Integer (Hex >0000 to >FFFF) and will do a timed test in 10,000 loops to see how much it is speeded up. 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 16, 2021 Share Posted May 16, 2021 Be sure you don't break things that matter to people. For example, this peeks the DEF table in XB: 5 CALL PEEK(8196,A,B):: L=A*256+B 10 FOR I=16376 TO L STEP -8 20 CALL PEEK(I,A,B,C,D,E,F,G,H):: PRINT CHR$(A);CHR$(B);CHR$(C);CHR$(D);CHR$(E);CHR$(F),G*256+H 30 NEXT I The variable I is the address to peek from. It's hard to see how to do this without using a variable, which are always floating point in XB Quote Link to comment Share on other sites More sharing options...
RXB Posted May 16, 2021 Share Posted May 16, 2021 1 hour ago, senior_falcon said: Be sure you don't break things that matter to people. For example, this peeks the DEF table in XB: 5 CALL PEEK(8196,A,B):: L=A*256+B 10 FOR I=16376 TO L STEP -8 20 CALL PEEK(I,A,B,C,D,E,F,G,H):: PRINT CHR$(A);CHR$(B);CHR$(C);CHR$(D);CHR$(E);CHR$(F),G*256+H 30 NEXT I The variable I is the address to peek from. It's hard to see how to do this without using a variable, which are always floating point in XB First off why and where is Floating Point needed here? Also strange result removing Floating Point actually slowed down the results. It took 20 seconds longer with Integer then Floating Point in 10,000 loops? 5 runs same result each time. Cut the amount of code in half, but XML SPEED for some reason has a huge impact on speed of XB even when it is not doing anything useful. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 17, 2021 Share Posted May 17, 2021 1 hour ago, RXB said: First off why and where is Floating Point needed here? To answer your question of "why," to my knowledge, every number in TI BASIC/XB is a floating point number. Whether it is 3 or 3.14159265, it is a floating point number that uses 8 bytes. For your question of "where," the variables A,B,C,D,E,F,G,H,I, and L are all floating point. In theory you could take CALL LOAD(8194,100) and go directly to a 2 byte integer. But with CALL LOAD(X,Y) you have to fetch X and Y from BASIC where they are floating point and need to be converted to integer. Unless RXB has provision for both floating point and integer variables. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 17, 2021 Share Posted May 17, 2021 5 hours ago, senior_falcon said: To answer your question of "why," to my knowledge, every number in TI BASIC/XB is a floating point number. Whether it is 3 or 3.14159265, it is a floating point number that uses 8 bytes. For your question of "where," the variables A,B,C,D,E,F,G,H,I, and L are all floating point. In theory you could take CALL LOAD(8194,100) and go directly to a 2 byte integer. But with CALL LOAD(X,Y) you have to fetch X and Y from BASIC where they are floating point and need to be converted to integer. Unless RXB has provision for both floating point and integer variables. Hmmm PI is a Floating point number as it has a decimal point in it. And yes I can fix this if I added in a token to denote this change. [0332] *********************************************************** [0333] * BASIC TOKEN TABLE [0334] * EQU >80 spare token [0335] 0081 ELSEZ EQU >81 ELSE [0336] 0082 SSEPZ EQU >82 :: [0337] 0083 TREMZ EQU >83 $ [0338] 0084 IFZ EQU >84 IF [0339] 0085 GOZ EQU >85 GO [0340] 0086 GOTOZ EQU >86 GOTO [0341] 0087 GOSUBZ EQU >87 GOSUB [0342] 0088 RETURZ EQU >88 RETURN [0343] 0089 DEFZ EQU >89 DEF [0344] 008A DIMZ EQU >8A DIM [0345] 008B ENDZ EQU >8B END [0346] 008C FORZ EQU >8C FOR [0347] LETZ EQU >8D LET * RXB REMOVED [0348] 008E BREAKZ EQU >8E BREAK [0349] 008F UNBREZ EQU >8F UNBREAK [0350] 0090 TRACEZ EQU >90 TRACE [0351] 0091 UNTRAZ EQU >91 UNTRACE [0352] 0092 INPUTZ EQU >92 INPUT [0353] 0093 DATAZ EQU >93 DATA [0354] 0094 RESTOZ EQU >94 RESTORE [0355] 0095 RANDOZ EQU >95 RANDOMIZE [0356] 0096 NEXTZ EQU >96 NEXT [0357] 0097 READZ EQU >97 READ [0358] 0098 STOPZ EQU >98 STOP [0359] 0099 DELETZ EQU >99 DELETE [0360] 009A REMZ EQU >9A REM [0361] 009B ONZ EQU >9B ON [0362] 009C PRINTZ EQU >9C PRINT [0363] 009D CALLZ EQU >9D CALL [0364] 009E OPTIOZ EQU >9E OPTION [0365] 009F OPENZ EQU >9F OPEN [0366] 00A0 CLOSEZ EQU >A0 CLOSE [0367] 00A1 SUBZ EQU >A1 SUB [0368] 00A2 DISPLZ EQU >A2 DISPLAY [0369] 00A3 IMAGEZ EQU >A3 IMAGE [0370] 00A4 ACCEPZ EQU >A4 ACCEPT [0371] 00A5 ERRORZ EQU >A5 ERROR [0372] 00A6 WARNZ EQU >A6 WARNING [0373] 00A7 SUBXTZ EQU >A7 SUBEXIT [0374] 00A8 SUBNDZ EQU >A8 SUBEND [0375] 00A9 RUNZ EQU >A9 RUN [0376] 00AA LINPUZ EQU >AA LINPUT [0377] * EQU >AB Zpare token (LIBRARY) [0378] * EQU >AC Zpare token (REAL) [0379] * EQU >AD Zpare token (INTEGER) [0380] * EQU >AE Zpare token (SCRATCH) [0381] * EQU >AF Zpare token [0382] 00B0 THENZ EQU >B0 THEN [0383] 00B1 TOZ EQU >B1 TO [0384] 00B2 STEPZ EQU >B2 STEP [0385] 00B3 COMMAZ EQU >B3 , [0386] 00B4 SEMICZ EQU >B4 ; [0387] 00B5 COLONZ EQU >B5 : [0388] 00B6 RPARZ EQU >B6 ) [0389] 00B7 LPARZ EQU >B7 ( [0390] 00B8 CONCZ EQU >B8 & (CONCATENATE) [0391] * EQU >B9 spare token [0392] 00BA ORZ EQU >BA OR [0393] 00BB ANDZ EQU >BB AND [0394] 00BC XORZ EQU >BC XOR [0395] 00BD NOTZ EQU >BD NOT [0396] 00BE EQUALZ EQU >BE = [0397] 00BF LESSZ EQU >BF < [0398] 00C0 GREATZ EQU >C0 > [0399] 00C1 PLUSZ EQU >C1 + [0400] 00C2 MINUSZ EQU >C2 - [0401] 00C3 MULTZ EQU >C3 * [0402] 00C4 DIVIZ EQU >C4 / [0403] 00C5 CIRCUZ EQU >C5 ^ [0404] * EQU >C6 spare token [0405] 00C7 STRINZ EQU >C7 QUOTED STRING [0406] 00C8 UNQSTZ EQU >C8 UNQUOTED STRING [0407] 00C8 NUMZ EQU >C8 ALSO NUMERICAL STRING [0408] 00C8 NUMCOZ EQU >C8 ALSO UNQUOTED STRING [0409] 00C9 LNZ EQU >C9 LINE NUMBER CONSTANT [0410] * EQU >CA spare token [0411] 00CB ABSZ EQU >CB ABS [0412] 00CC ATNZ EQU >CC ATN [0413] 00CD COSZ EQU >CD COS [0414] 00CE EXPZZ EQU >CE EXP [0415] 00CF INTZ EQU >CF INT [0416] 00D0 LOGZ EQU >D0 LOG [0417] 00D1 SGNZZ EQU >D1 SGN [0418] 00D2 SINZ EQU >D2 SIN [0419] 00D3 SQRZ EQU >D3 SQR [0420] 00D4 TANZ EQU >D4 TAN [0421] 00D5 LENZ EQU >D5 LEN [0422] 00D6 CHRZZ EQU >D6 CHR$ [0423] 00D7 RNDZ EQU >D7 RND [0424] 00D8 SEGZZ EQU >D8 SEG$ [0425] 00D9 POSZ EQU >D9 POS [0426] 00DA VAL EQU >DA VAL [0427] 00DB STRZZ EQU >DB STR$ [0428] 00DC ASCZ EQU >DC ASC [0429] 00DD PIZ EQU >DD PI [0430] 00DE RECZ EQU >DE REC [0431] 00DF MAXZ EQU >DF MAX [0432] 00E0 MINZ EQU >E0 MIN [0433] 00E1 RPTZZ EQU >E1 RPT$ [0434] * EQU >E2 unused [0435] * EQU >E2 unused [0436] * EQU >E3 unused [0437] * EQU >E4 unused [0438] * EQU >E5 unused [0439] * EQU >E6 unused [0440] * EQU >E7 unused [0441] 00E8 NUMERZ EQU >E8 NUMERIC [0442] 00E9 DIGITZ EQU >E9 DIGIT [0443] 00EA UALPHZ EQU >EA UALPHA [0444] 00EB SIZEZ EQU >EB SIZE [0445] 00EC ALLZ EQU >EC ALL [0446] 00ED USINGZ EQU >ED USING [0447] 00EE BEEPZ EQU >EE BEEP [0448] 00EF ERASEZ EQU >EF ERASE [0449] 00F0 ATZ EQU >F0 AT [0450] 00F1 BASEZ EQU >F1 BASE [0451] * EQU >F2 spare token (TEMPORARY) [0452] * EQU >F3 spare token (VARIABLE) [0453] * EQU >F4 spare token (RELATIVE) [0454] * EQU >F5 spare token (INTERNAL) [0455] 00F6 SEQUEZ EQU >F6 SEQUENTIAL [0456] 00F7 OUTPUZ EQU >F7 OUTPUT [0457] 00F8 UPDATZ EQU >F8 UPDATE [0458] 00F9 APPENZ EQU >F9 APPEND [0459] 00FA FIXEDZ EQU >FA FIXED [0460] 00FB PERMAZ EQU >FB PERMANENT [0461] 00FC TABZ EQU >FC TAB [0462] 00FD NUMBEZ EQU >FD # [0463] 00FE VALIDZ EQU >FE VALIDATE [0464] * EQU >FF ILLEGAL VALUE [0465] *************************************************** See there are a whole bunch of tokens that have not been used yet in XB so room for 22 tokens currently unused. The problem starts when you enter a line with a number in it and the program editor itself put token >C8 (Token NUMZ) in front of that number. Idiocy of how it works is >C8 can be a Unquoted String or a Number or Numerical String....see the insane problem? A solution is to fix the XB ROMs and GPL to use >C7 for integer numbers. This would mostly maintain backward compatibility. A really boost to speed in XB would result. Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 17, 2021 Share Posted May 17, 2021 Good luck! 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 17, 2021 Author Share Posted May 17, 2021 CBM BASIC uses the % character to denote integer variables. So, B% is the B-Integer variable, which takes up fewer bytes than a floating point and is quicker to use and manipulate. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 17, 2021 Share Posted May 17, 2021 2 hours ago, OLD CS1 said: CBM BASIC uses the % character to denote integer variables. So, B% is the B-Integer variable, which takes up fewer bytes than a floating point and is quicker to use and manipulate. The game plan would be all Integers could only be two byte values 0 to >FFFF in Hex or in Decimal 0 to 65535 or -32767 to 0 to 32768 I think the last would be best as then you have negative and positive integers this would be 15 bits with a negative / positive bit. % would be a good solution. 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 18, 2021 Share Posted May 18, 2021 Here's something to chew on. Variables must start with an alphabetic character, or @ or _. You could use @ or _ as the first character in a variable name to indicate an integer. For example: CALL HCHAR(@1,@1,@42,@768) When the XB interpreter sees @ as the first character in the variable name it knows that a 2 byte integer is to be used instead of the usual procedure of reading the characters, converting to FP, converting to integers, and using them. Or CALL HCHAR(@ROW,@COL,@CH) Of course, this must be preceded with @ROW=1::@COL=1::@CH=42 so XB knows what the values of the variables are. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 18, 2021 Share Posted May 18, 2021 1 hour ago, senior_falcon said: Here's something to chew on. Variables must start with an alphabetic character, or @ or _. You could use @ or _ as the first character in a variable name to indicate an integer. For example: CALL HCHAR(@1,@1,@42,@768) When the XB interpreter sees @ as the first character in the variable name it knows that a 2 byte integer is to be used instead of the usual procedure of reading the characters, converting to FP, converting to integers, and using them. Or CALL HCHAR(@ROW,@COL,@CH) Of course, this must be preceded with @ROW=1::@COL=1::@CH=42 so XB knows what the values of the variables are. I am forced to be backwards compatible and people have a habit of using @ and _ as variable names. In XB you can use INT(value) but it takes time in ROM to convert from FP to Integer but this runs from INTERPETER. Example is currently if you want a INTEGER you have to use INT(value) and be interpreted takes TIME TO RUN! What I need to do it before the program is saved in Editor is put a token before that so it never needs to be converted. W is common symbol for WHOLE numbers that is also INTEGER numbers so W is possible. N is another common symbol for WHOLE and INTEGER numbers. I personally favor syntax in math for WHOLE numbers {value} as an INTEGER/WHOLE number. { can be a flag to avoid ever needing to look at the number as a FP number so no need to convert wasting time. I could parse the value up to the } and just go to next comma or ) in command with no penalty in speed. There would be a problem in that Variables usually are in FP so have to figure a solution for this. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted July 24, 2021 Author Share Posted July 24, 2021 On 5/17/2021 at 11:47 AM, RXB said: The game plan would be all Integers could only be two byte values 0 to >FFFF in Hex or in Decimal 0 to 65535 or -32767 to 0 to 32768 I think the last would be best as then you have negative and positive integers this would be 15 bits with a negative / positive bit. % would be a good solution. On Page 39 of the "Produce 359 Design Specification" I found this regarding the value stack and integer variables: Quote Also, when an integer variable type is added to a future BASIC the first two bytes of the entry will contain the value and the third byte can be used as an ID to indicate that the FAC/stack entry contains an integer (ID >64 was reserved for this purpose). 4 Quote Link to comment Share on other sites More sharing options...
Casey Posted August 3, 2021 Share Posted August 3, 2021 On 5/17/2021 at 6:43 AM, OLD CS1 said: CBM BASIC uses the % character to denote integer variables. So, B% is the B-Integer variable, which takes up fewer bytes than a floating point and is quicker to use and manipulate. I think except in the case of arrays like B%(X) - CBM BASIC has to convert the integer back to floating point before it uses it. You can save memory space and execution time if you are processing an integer array, but otherwise I don't think it buys you much. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 3, 2021 Author Share Posted August 3, 2021 52 minutes ago, Casey said: I think except in the case of arrays like B%(X) - CBM BASIC has to convert the integer back to floating point before it uses it. You can save memory space and execution time if you are processing an integer array, but otherwise I don't think it buys you much. The subscript has to be floating point, or the value when stored in an array? I want to check the CBM BASIC ROM book on this one to be certain. I think I can also do some experiments in Vice. Okay, I think see what you are saying here, that to use the variable requires converting to floating point. That would be pretty likely for some purposes. CBM BASIC has a flag for dealing with integer values, but there is no promise that functions like STR$() use the integer value. I would expect bit-wise operations to use the integer value since floating point has to be converted to do so. Quote Link to comment Share on other sites More sharing options...
Tursi Posted August 3, 2021 Share Posted August 3, 2021 Well, Applesoft uses the '%' indicator too, but it definitely doesn't need to convert to floating point for most operations, because it flies when variables are all integer. Quote Link to comment Share on other sites More sharing options...
RXB Posted August 3, 2021 Share Posted August 3, 2021 I have been looking at using the [ character 91 and ] character 93 as the integer only value to sub for Floating Point. This would be added to XB symbol table in GPL and ROMs as currently ( and ) are already in the XB symbol table and mean ORDER OF OPERATIONS. Thus statements like: CALL SPRITE(#2,116,7,14*8,INT(RND*14)*8+100) Would become: CALL SPRITE(#2,[116],[7],[14*8],INT(RND*14)*[8]+[100]) This would slightly speed up XB as those number in [] are never converted from floating point to integer additionally like [14*8] would be faster as no floating point conversion would be needed. I could even change all the ( and ) into statements like: CALL SPRITE(#2,116,7,14*8,INT(RND*14)*8+100) into: CALL SPRITE[#2,116,7,14*8,INT(RND*14)*8+100] the INT(RND*14) would function as normal as INT( to ) would be in Floating Point. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 3, 2021 Author Share Posted August 3, 2021 20 minutes ago, RXB said: I have been looking at using the [ character 91 and ] character 93 as the integer only value to sub for Floating Point. Neat idea. Not sure how many we will run into, but making [ and ] into tokens will break programs which use them as variables. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 3, 2021 Share Posted August 3, 2021 On 5/18/2021 at 3:52 PM, RXB said: I am forced to be backwards compatible and people have a habit of using @ and _ as variable names. In XB you can use INT(value) but it takes time in ROM to convert from FP to Integer but this runs from INTERPETER. Example is currently if you want a INTEGER you have to use INT(value) and be interpreted takes TIME TO RUN! It was always my impression that the primary use of the symbols has been for optimization and space saving, most often employed by programs such as PreScanIt! and the Compact/Smash utilities. Symbols were used to represent commonly-used values and all variable names were shortened to 1 or 2 characters. I used the optimization programs quite often back in the day and readability aside, they made quite a positive impact. Seems like there is quite a lot to work needed to deal with the tokenization, internal XB storage and manipulation, and compatibility. Even the resulting value from your INT(value) example is still represented as floating point internally, is it not? INT(x) does not create an integer type, just a value with 'nothing' after the decimal point. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 4, 2021 Share Posted August 4, 2021 3 hours ago, OLD CS1 said: Neat idea. Not sure how many we will run into, but making [ and ] into tokens will break programs which use them as variables. Yea but easy to fix with any Text editor with find/replace. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 4, 2021 Share Posted August 4, 2021 26 minutes ago, InsaneMultitasker said: It was always my impression that the primary use of the symbols has been for optimization and space saving, most often employed by programs such as PreScanIt! and the Compact/Smash utilities. Symbols were used to represent commonly-used values and all variable names were shortened to 1 or 2 characters. I used the optimization programs quite often back in the day and readability aside, they made quite a positive impact. Seems like there is quite a lot to work needed to deal with the tokenization, internal XB storage and manipulation, and compatibility. Even the resulting value from your INT(value) example is still represented as floating point internally, is it not? INT(x) does not create an integer type, just a value with 'nothing' after the decimal point. Hex values are hex >0000 decimal 0 to hex >7FFF decimal 32767 to hex >8000 decimal -32768 to hex >FFFF decimal -1 INT(value) just converts these to those values in decimal that is the limit of Hexadecimal of TI memory. I would just put into the editor your agility to use [ and ] into programs, and editor would check that syntax. When the program is running in XB it would never have to convert Floating Point into Integer as they would have been saved in Integer in first place. Of course any variable or value outside the [value] would invoke Floating Point automatically. Thus [X=11*7+221] would be integer only. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 4, 2021 Share Posted August 4, 2021 55 minutes ago, RXB said: Hex values are hex >0000 decimal 0 to hex >7FFF decimal 32767 to hex >8000 decimal -32768 to hex >FFFF decimal -1 INT(value) just converts these to those values in decimal that is the limit of Hexadecimal of TI memory. INT is not restricted to the range you specify above and the value is represented in memory as floating point. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 4, 2021 Share Posted August 4, 2021 Interpreters are so handy. This is pretty impressive. The old girl can handle ints upto 2^33! 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted August 4, 2021 Share Posted August 4, 2021 2 hours ago, InsaneMultitasker said: INT is not restricted to the range you specify above and the value is represented in memory as floating point. Not internally I use CFI to just use integers from 32767 to -38768 just like CALL LOAD or CALL PEEK does. RXB has more features like CALL HEX(string variable,numeric variable) or CALL HEX(numeric variable,string variable) It converts either to the other like A$="FFEF" would convert to X=-17 Slowly I have been converting XB to Integer math, but Interger math I use only works in a small range. I really do not see the point of using Floating Point for things like CALL HCHAR or even CALL SPRITE it just slows the programs down. Presently first step is set up Assembly routines to attack the slowest subroutines in XB. Example is DISPLAY AT(row,column):variable is much slower then RXB CALL HPUT(row,colum,variable) which will be written in assembly ROM. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted September 3, 2021 Author Share Posted September 3, 2021 Well, how about that? Dow, John T. "Squeezing the Most Out of TI BASIC." 99'er Home Computer Magazine, November 1983, pg. 22. 3 1 Quote Link to comment Share on other sites More sharing options...
kl99 Posted September 9, 2021 Share Posted September 9, 2021 i didn't follow the conversation. to get automatic measurement, without looking at the clock the right time one could use Classic99 and include saves to two different files, that both files were not existing yet. like this you can use the windows/dos filesystem timestamp for the windows files PRE and POST to figure out the timestamp, it is at least as precise as seconds. 100 OPEN #1:"DSK1.PRE",SEQUENTIAL,INTERNAL,OUTPUT,FIXED 128,PERMANENT 110 CLOSE #1 120 FOR I=1 TO 1000 130 CALL CLEAR 140 NEXT I 150 OPEN #1:"DSK1.POST",SEQUENTIAL,INTERNAL,OUTPUT,FIXED 128,PERMANENT 160 CLOSE #1 an alternate would be to use a clock device and write the time before and after a test to the screen or to a file. 1 Quote Link to comment Share on other sites More sharing options...
