glurk Posted April 25, 2021 Share Posted April 25, 2021 This is actually a question. Back when I was younger, I used to know a bunch of little 6502 tricks / optimizations, whatever. And I'm trying to remember one. Say I have a bit of code like this: LDX MYINDEX INX CPX #$03 BNE .noreset LDX #$00 .noreset STX MYINDEX So this makes MYINDEX cycle 0,1,2,0,1,2 etc... But it's so ugly with the CPX and the BNE branch. Isn't there a more clean / elegant way to do this that takes the same number of cycles each time? I swear I used to know how to do that. Or I think I did, LOL. Using exclusive or, or rotate, or something. It doesn't even have to use X, it can use the Accumulator instead. But I just can't figure it out... Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 26, 2021 Share Posted April 26, 2021 Basically use a cycle of 0-3 instead of 0-2. there's a number of ways to implement it, such as this if you're going to use myindex in X right away: ldx myindex inx txa and #3 sta myindex or this if you're going to use myindex later: inc myindex lda myindex and #3 sta myindex Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted April 26, 2021 Share Posted April 26, 2021 ldx index lda nextVal,x sta index ... nextval .byte 1,2,0 5 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted April 26, 2021 Share Posted April 26, 2021 lda index cmp #2 adc #1 and #3 sta index 2 Quote Link to comment Share on other sites More sharing options...
glurk Posted April 26, 2021 Author Share Posted April 26, 2021 (edited) 33 minutes ago, Andrew Davie said: lda index cmp #2 adc #1 and #3 sta index Perfect. I thought maybe there was a quicker way than that, but this one is fine. It's for a 3-frame animation. If it was 0,1,2,3 it would be easy, but it's not. I was getting a headache trying to figure this one out, LOL!! Thanks. Edited April 26, 2021 by glurk Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted April 26, 2021 Share Posted April 26, 2021 If it's just about an index for an animation, I would do it the other way round: counting down, so you can spare the compare: ldx counter dex bpl @noreset ldx #$02 @noreset: stx counter All you need is to reverse the order of the animation frames. But Andrew's a bit faster... of course. But mine's one byte shorter. 3 Quote Link to comment Share on other sites More sharing options...
