+OLD CS1 Posted May 3, 2021 Share Posted May 3, 2021 Another post indicates that checking the value at -31952 (>8330, I believe) will indicate the absence of 32k RAM if the return is 55. However, I have now tested this on real hardware and in Classic99 and I get 255 for 32k RAM present but that changes to a different value once a program is loaded. Classic99 returned 55 then 29 after a program loaded (32k disabled,) while one console returns 63 with no 32k attached. I assume there is an accepted "standard" for detecting 32k from Extended BASIC -- remembering that I can neither LOAD values into 32k space nor CALL INIT without incurring a fatal error. I tried catching a CALL INIT error with ON ERROR, but the RETURN sends execution right back to the bad statement. I also tried some other fancy shenanigans to no avail. 1 ON ERROR 100 :: ON BREAK NEXT 2 CALL INIT 3 PRINT "SUCCESS" 4 STOP 100 CALL ERR(A,B,C,D):: PRINT A;B;C;D :: BREAK 2 :: RETURN Arrrr Extended BASIC... she be a harsh mistress. 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 3, 2021 Share Posted May 3, 2021 (edited) CALL PEEK(-31860,A,B) CALL PEEK(-31868,A,B) Should be 255,231 with memory expansion; 0,0 if no memory CALL INIT CALL LOAD(-31868,0,0,0,0) turns off memory expansion as far as XB is concerned. Programs will run from VDP memory, but you can still load assembly support! (Edit) It is -31868. You really only need to look at the first byte. If A=0 then no memory expansion. Edited May 4, 2021 by senior_falcon 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 3, 2021 Author Share Posted May 3, 2021 @senior_falcon I will give it a try, thank you. This also means I have to release an update to my last game. ::sigh:: 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted May 3, 2021 Share Posted May 3, 2021 This might be of help. CALL LOADS.pdf 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 3, 2021 Author Share Posted May 3, 2021 @atrax27407 Tah. This is where I found the 55 value I was using, but I see I missed other possibilities in it. "-31952,X IF x=55 then memory expansion is off else it is on." 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 3, 2021 Share Posted May 3, 2021 Dumb fingers. It should be CALL PEEK(-31868,A,B) 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 4, 2021 Share Posted May 4, 2021 4 hours ago, atrax27407 said: This might be of help. CALL LOADS.pdf 269.02 kB · 6 downloads Man, where was this document in 1985? 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 4, 2021 Author Share Posted May 4, 2021 1 hour ago, TheBF said: Man, where was this document in 1985? Scattered around various user group newsletters. I recall a few example programs in ours. But it appears the only two PEEKs in the document regarding 32k detection are incorrect. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted May 4, 2021 Share Posted May 4, 2021 I think there was an extensive list in "The Smart Programmer" by Miller's Graphics and a bunch of them appeared in MICROpendium as well. The one I posted is a copy of several lists that were thrown together into a single list. 1 Quote Link to comment Share on other sites More sharing options...
Casey Posted May 4, 2021 Share Posted May 4, 2021 I think this works the way you wanted your example program to work? 1 ON ERROR 100 2 CALL INIT 3 PRINT "SUCCESS" 4 STOP 100 CALL ERR(A,B,C,D)::PRINT A;B;C;D::RETURN NEXT On real hardware, without 32K, this prints the 4 error numbers, then prints "SUCCESS" and stops. With 32K, it only prints SUCCESS. 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 4, 2021 Author Share Posted May 4, 2021 2 hours ago, Casey said: RETURN NEXT Sunnuva gun! I completely forgot about that construct. Yes, that would work as well to set a flag for the 32k present or not (the assumption being that CALL INIT will return a * SYNTAX ERROR.) 3 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted May 4, 2021 Share Posted May 4, 2021 Again: 10 CALL PEEK(-31868,X)::IF X=0 THEN PRINT "NO 32K" ELSE PRINT "32K" This will always work and is about as simple as it can be. 4 Quote Link to comment Share on other sites More sharing options...
