gar0u Posted May 5, 2021 Share Posted May 5, 2021 I searched the forum and Google for an answer but could not find one, so apologies if this is answered elsewhere. I'm about 1/4 of the way through Oscar's "Advanced Game Programming for Intellivision" (which also led me to buy "Programming Games for Intellivision".) I figured I better start at the beginning. I'm learning on OS X and have 'intybasic' installed in /home/[user]/Documents/IntyBASIC-SDK like the instructions say. "intytest sdklogo" works just fine. Trying to get "Hello, world!" to work from page 7 of the first book. The 'intybasic' command (I assume compiling) works just fine, but 'as1600 -o' (I assume linking) throws five errors about undefined symbols (_screen and _color). I assume this is a path problem somewhere? I have 'source $HOME/intybasic_sdk.rc in my ~/.bash_profile file. Appreciate any help or insight. I'm sure it's something simple I'm overlooking... Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 Am I missing GROM.ROM? Quote Link to comment Share on other sites More sharing options...
Kiwi Posted May 5, 2021 Share Posted May 5, 2021 Do you have both the intybasic prologue and epilogue files in the same folder as your project? Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 I tried that and it did not resolve the problem. Thank you though! Quote Link to comment Share on other sites More sharing options...
+nanochess Posted May 5, 2021 Share Posted May 5, 2021 (edited) I don't have tested the SDK on Mac. I prefer to direct everyone to unzip everything in one folder. But the missing symbols indicate that IntyBASIC couldn't find intybasic_prologue.asm and intybasic_epilogue.asm to add to the output assembler file. So the assembler misses the required symbols. Unfortunately I'm not good enough in bash code to help you to find the problem. A clue is that IntyBASIC allows to define the library path as the third argument, if you can find what is being provided you can put the required files in the exact path. For example: intybasic mycode.bas mycode.asm /Users/gar0u/Documents/ Would look for intybasic_prologue.asm and intybasic_epilogue.asm at your Documents folder (supposing gar0u is your username). Edited May 5, 2021 by nanochess 1 Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 Dropping EXEC.bin and GROM.bin in the bin directory with 'as1600' and 'intybasic' didn't help either. Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 Thanks for the quick reply, nanochess! I tried putting both prologue and epilogue files in the same directory as my .asm file and that didn't fix the problem. Nor did using the include switch (-i) with the directory that contains the epilogue and prologue files. I had this working a few months ago when I was working through the PDF of your first book. I'm certain it's a problem with my setup. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted May 5, 2021 Share Posted May 5, 2021 Just now, gar0u said: Thanks for the quick reply, nanochess! I tried putting both prologue and epilogue files in the same directory as my .asm file and that didn't fix the problem. Nor did using the include switch (-i) with the directory that contains the epilogue and prologue files. I had this working a few months ago when I was working through the PDF of your first book. I'm certain it's a problem with my setup. You should look in the shell code for the line running IntyBASIC, it should have a third argument with the folder path to the intybasic_prologue.asm and intybasic_epilogue.asm files. These files are automatically included by IntyBASIC in the generated assembler code along your program. 1 Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 Ok, I got it working! Following the instructions with "IntyBASIC-SDK" in my Documents directory, I had to add the library path as a third argument exactly like nanochess said. 1. intybasic helloWorld.bas helloWorld.asm ~/Documents/IntyBASIC-SDK/lib Then compile like the book says: 2. as1600 -o helloWorld helloWorld.asm Thanks so much for the help. Hopefully this will help others. Doing it this way lets me keep a separate directory under ./Projects and simplifies testing. 1 Quote Link to comment Share on other sites More sharing options...
gar0u Posted May 5, 2021 Author Share Posted May 5, 2021 'grom.bin' and 'exec.bin' need to be copied to ~/Documents/IntyBASIC-SDK/roms directory. 1 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 5, 2021 Share Posted May 5, 2021 1 hour ago, gar0u said: I searched the forum and Google for an answer but could not find one, so apologies if this is answered elsewhere. I'm about 1/4 of the way through Oscar's "Advanced Game Programming for Intellivision" (which also led me to buy "Programming Games for Intellivision".) I figured I better start at the beginning. I'm learning on OS X and have 'intybasic' installed in /home/[user]/Documents/IntyBASIC-SDK like the instructions say. "intytest sdklogo" works just fine. Trying to get "Hello, world!" to work from page 7 of the first book. The 'intybasic' command (I assume compiling) works just fine, but 'as1600 -o' (I assume linking) throws five errors about undefined symbols (_screen and _color). I assume this is a path problem somewhere? I have 'source $HOME/intybasic_sdk.rc in my ~/.bash_profile file. Appreciate any help or insight. I'm sure it's something simple I'm overlooking... Did you follow the installation instructions of the SDK for Mac? After adding the "source" command to the bash profile, you need to open a new terminal window for it to take effect, or execute the command manually in the current terminal window. If you are using the SDK, then you compile using the "intybuild" command, which will do compilation and assemblage in one step. Keep in mind that the SDK is intended to simplify the usage of the tools in a more streamline way, so that you don't have to invoke all the esoteric command lines in the book. Take a look at the documentation that comes with the SDK for more information on the tools available. dZ. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 5, 2021 Share Posted May 5, 2021 (edited) On 5/5/2021 at 7:19 PM, gar0u said: Ok, I got it working! Following the instructions with "IntyBASIC-SDK" in my Documents directory, I had to add the library path as a third argument exactly like nanochess said. 1. intybasic helloWorld.bas helloWorld.asm ~/Documents/IntyBASIC-SDK/lib Then compile like the book says: 2. as1600 -o helloWorld helloWorld.asm Thanks so much for the help. Hopefully this will help others. Doing it this way lets me keep a separate directory under ./Projects and simplifies testing. The SDK should take care of all of that for you. That's what the "intybasic_sdk.rc" file does. Adding it to your bash profile will execute it when you open the terminal window, setting up your environment correctly. But for that to work, you need to make sure that the bash profile is executed (i.e., opening a new terminal window) and that the "rc" file is called with the "source" command, as the instructions say. Once you follow all the set up instructions, then everything works, and the SDK tools will work. Using "intybuild" will compile and assemble your project and "intyrun" and "intydbug" will run it the emulator and debugger, respectively. Note that the SDK tools do more than just calling the compiler. They also facilitate source-level debugging by setting up the debugger with symbol and mapping tables, and other useful features. dZ. Edited May 7, 2021 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 5, 2021 Share Posted May 5, 2021 26 minutes ago, gar0u said: 'grom.bin' and 'exec.bin' need to be copied to ~/Documents/IntyBASIC-SDK/roms directory. The SDK comes with its own copies of those. I am wondering if your SDK installation has been compromised and whether you may want to download it and install it again. Let me know if you need help with it. Also, I'm planning a new release of the SDK this summer, so if you have any suggestions, let me know. Quote Link to comment Share on other sites More sharing options...
Mik's Arcade Posted May 7, 2021 Share Posted May 7, 2021 I'm just here to plug SDK.....it's a fantastic tool. I don't have any suggestions for it at this time. It has really sped things up for me. And welcome to the IntyBasic programming club. I'm a total newb, and not very good at this point....getting there VERY slowly 1 Quote Link to comment Share on other sites More sharing options...
