8BitLP Posted May 6, 2021 Share Posted May 6, 2021 Hello! I recently got my Harmony Card. Now I put some games on it and wanted to try it out. Unfortunately it didn't work, because my TV only supports PAL 50. So I need to change the firmware of the card. I installed all drivers and installed the program I needed but my PC can't find the card. It only appears as a "USB" in the Device Manager with a yellow mark. In the programm i only see "Harmony Card not found". I tested it also with several other USB Cables, but it didn't work. I also tested it on an old Windows XP PC and a MacBook, but both didn't work neither. I really don't know what I can do now, because I need to change the firmware, otherwise I can't use the Harmony Card. Thanks! Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 6, 2021 Share Posted May 6, 2021 This is a common problem. The problem is usually the USB cable, which doesn't support data transfer. Quote Link to comment Share on other sites More sharing options...
8BitLP Posted May 6, 2021 Author Share Posted May 6, 2021 9 minutes ago, Thomas Jentzsch said: This is a common problem. The problem is usually the USB cable, which doesn't support data transfer. Ok, than I only have USB cables that doesn't support data transfer ? Is there one that is proof working? Quote Link to comment Share on other sites More sharing options...
