kevincondrick@gmail.com Posted May 9, 2021 Share Posted May 9, 2021 (edited) Hi there I had this Sega Genesis Portable from ATGames for a little while now and I just want to play it again. I had an SD card in it and wanted to play a game off of and I can't seem to get it to work. funny thing is that it was just working the other day. Maybe the sdcard reader is bad or something? Also I replaced the card reader and I believe it's in right. Maybe it's it processer or something? Edited May 9, 2021 by kevincondrick@gmail.com Quote Link to comment Share on other sites More sharing options...
nebrazca88 Posted May 13, 2021 Share Posted May 13, 2021 Your post is confusing but test the SD card on a reader or interface you know works to make sure it's not bad. I've had a couple go bad for no known reason. Quote Link to comment Share on other sites More sharing options...
kevincondrick@gmail.com Posted May 13, 2021 Author Share Posted May 13, 2021 Just now, nebrazca88 said: Your post is confusing but test the SD card on a reader or interface you know works to make sure it's not bad. I've had a couple go bad for no known reason. I believe the sd card is good it did work but now it's not working Quote Link to comment Share on other sites More sharing options...
nebrazca88 Posted May 13, 2021 Share Posted May 13, 2021 1 minute ago, kevincondrick@gmail.com said: I believe the sd card is good it did work but now it's not working Do you believe it works or have you tested it and know it works? If you've tested it and you know it works, try another SD card you know is working in the slot. If it doesn't work you can reasonably assume the problem is with the system as long as the SD cards are formatted properly. Quote Link to comment Share on other sites More sharing options...
kevincondrick@gmail.com Posted May 13, 2021 Author Share Posted May 13, 2021 Yah the SD card works I did test it. But it don't seam to read any SD cards. I also thought it might have been a bad card slot so I replaced it as well and still don't work Quote Link to comment Share on other sites More sharing options...
