Diskus 3.9 -
4 minutes ago, kodak80 said:
I note that your SCP dumps are only 2 revolutions.  I would recommend at least 3 revolutions and ideally 5 revolutions as in the past less then 3 have sometimes not been able to work with weak bits etc.
I will adjust
2 hours ago, SoulBuster said:
Teenage Queen - Boots to desktop.  Say disk is damaged. Can anyone fix the SCP?
Side 1 of the disk looks like it is dirty or has mould on the surface.  You can try using isopropyl cleaning alcohol on a cotton wool bud to gently clean the magnetic surface on the top side (with label).
Edited by kodak80
Space Quest - Boots to desktop. Run Sierra.prg
Disk 2 could do with re-dumping and maybe a clean.  The orange bits indicate dirt or bad flux elements.  Re-dumping the disk may work, if not it would need a clean.
The disk itself looks clean.  I did apply Isopropyl to the label side of disk, but it does not appear to have changed anything.
Teenage Queen Direct Link
Okay, I would recommend continuing with other disks and come back to this one later.
What are you using to create SCP dumps?  Greaseweazle or Supercard Pro?  What floppy drive are you using?
Updated Direct Link to Disk 2
SuperCard Pro and A Samsung SFD-321B Rev T1
3 minutes ago, kodak80 said:
Disk 1 looks to be incomplete dump.  There is a good Blood Money SCP dump in the Flux repository you could use to repair this disk with.
What program are you using to dump those images.  Where can I get it.
It is DrCoolZic's AUFIT tool.  Works with SCP and Kryoflux dumps.
https://info-coach.fr/atari/software/pc-projects/Aufit.php
You can also use the HxC Floppy Emulator tool to get a similar disk view.
