RetroCoder Posted May 25, 2021 Share Posted May 25, 2021 (edited) I started back into 6502 assembler after a good 30+ years and wanted to use the tools I'm familiar with. That is VS Code as the editor. ATasm was the assembler of choice and Altirra the emulator. Now getting back into learning some 6502 had me dumping hex codes on the screen until I found out that Altirra has a nice debugger. Still I had no easy way of finding my code in the disassembly view, so I was padding the points of interest with nops etc. There had to be a better way. I found some topics here talking about debugging options in Altirra but there was no guide or documentation (none that I could find). At least the source code for Altirra is available and after getting it to compile and running, I managed to figure out the file format to get source level debugging to work. I modified ATasm to generate the required symbol and list files so that Altirra could load them. Then I wrote a VSCode extension to bring it all together. Now I can write my asm code, set a breakpoint in VSCode and launch the debugger and have it stop where I want it. The extension is called Atasm Altirra Bridge https://marketplace.visualstudio.com/items?itemName=cerebus.atasm-altirra-bridge Edited May 25, 2021 by RetroCoder added tags 17 2 Quote Link to comment Share on other sites More sharing options...
playermissile Posted May 26, 2021 Share Posted May 26, 2021 This looks great! VSCode is cross-platform, so the syntax highlighting should at least work on other systems. When I get a chance I will try it on linux and see if I can start the atari800 emulator by setting the altirra.path variable to point to atari800. Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted May 26, 2021 Author Share Posted May 26, 2021 28 minutes ago, playermissile said: This looks great! VSCode is cross-platform, so the syntax highlighting should at least work on other systems. When I get a chance I will try it on linux and see if I can start the atari800 emulator by setting the altirra.path variable to point to atari800. The code is available on Github so a pull request would be great. Let get this cross-platform Quote Link to comment Share on other sites More sharing options...
playermissile Posted May 26, 2021 Share Posted May 26, 2021 2 hours ago, RetroCoder said: The code is available on Github so a pull request would be great. Let get this cross-platform I don't know typescript but your code looks clean and easy to follow. Long learning curve ahead from me, but it's possible that I might be able to contribute something eventually. Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted May 26, 2021 Author Share Posted May 26, 2021 I added a Linux version of ATasm 1.11 in version 1.1.0 of the extension. Should at least be able to assemble your code under Linux now. I tried running Altirra under wine under WSL2 on Win10 (hmm a bit much there) and did not get it to work, but it should work running on a Linux machine 1 Quote Link to comment Share on other sites More sharing options...
tsom Posted May 26, 2021 Share Posted May 26, 2021 Thought I'd give it a try on MacOS (yeah, I know Altirra doesn't run under MacOS), and can't get it to compile. I set a custom path for atasm in the settings (in my case '/usr/local/bin/atasm'), but it doesn't want to use that setting, seems fixed to trying to use the Linux path: "atasm-altirra-bridge.assembler.atasmPath": "/usr/local/bin/atasm" Starting build ... -oout/b-ring.xex -lout/b-ring.lab -gout/b-ring.lst "b-ring.asm" /bin/sh: /Users/john/.vscode-exploration/extensions/cerebus.atasm-altirra-bridge-1.1.0/bin/darwin/x64/atasm: No such file or directory Exit code: 127 I wish there was a MacOS version of Altirra, or at least one of the Mac emulators would work (Atari800MacX would be awesome!) Quote Link to comment Share on other sites More sharing options...
invisible kid Posted May 26, 2021 Share Posted May 26, 2021 (edited) I just put a link to my already installed atasm in ~/.vscode/extensions/cerebus.atasm-altirra-bridge-1.0.0/out/bin. That got it going. But since my version of atasm does not support the new debug code(-g switch) I had to change this: "withDebug": false. you should be able to do a ln -s `which atasm` /Users/john/.vscode-exploration/extensions/cerebus.atasm-altirra-bridge-1.1.0/bin/darwin/x64 and then you can change the altirra path to use atari800, now clicking the rocket builds it and pops it up on atari800. Edited May 26, 2021 by invisible kid Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted May 27, 2021 Author Share Posted May 27, 2021 14 hours ago, tsom said: Thought I'd give it a try on MacOS (yeah, I know Altirra doesn't run under MacOS), and can't get it to compile. I set a custom path for atasm in the settings (in my case '/usr/local/bin/atasm'), but it doesn't want to use that setting, seems fixed to trying to use the Linux path: "atasm-altirra-bridge.assembler.atasmPath": "/usr/local/bin/atasm" Starting build ... -oout/b-ring.xex -lout/b-ring.lab -gout/b-ring.lst "b-ring.asm" /bin/sh: /Users/john/.vscode-exploration/extensions/cerebus.atasm-altirra-bridge-1.1.0/bin/darwin/x64/atasm: No such file or directory Exit code: 127 I wish there was a MacOS version of Altirra, or at least one of the Mac emulators would work (Atari800MacX would be awesome!) Thank you for testing the extension on MacOS. I don't have a mac to try it on, but will make a plane to get the latest version of ATasm into the extension. At for it using the linux path, yes that is a bug. I'll fix it and release a new version asap. 1 Quote Link to comment Share on other sites More sharing options...
snicklin Posted May 27, 2021 Share Posted May 27, 2021 This sounds incredible. I have it similar with my daytime job programming, using a debugger with 4D that takes me through each line. Would it be difficult for someone to convert this to MADS? I have a level of debugging with Mads and Altirra but not from vsCode. I won't volunteer, too many projects on the go...! Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted May 27, 2021 Author Share Posted May 27, 2021 Version 1.2.0 of the extension has been released. - Better integration of the ATasm assembler - Fixed a bug that reset the path to be always the Windows path of the atasm - Build Task now also works when 'atasm-build.json' is the currently open file - Added configuration options to allow for another emulator to be used - Set the ownEmulator setting and supply the path and arguments - The extension will not add any parameters. You will need to supply them in the correct format. With this release you can specify a different emulator. The readme had some instructions. Should now be able to run any emulator. You just have to supply the arguments I'll have to find a Mac with a dev environment on it to get atasm v1.11 compiled, then I can have the extension Windows/Linux/MacOS compatible Happy debugging 4 1 Quote Link to comment Share on other sites More sharing options...
tsom Posted May 27, 2021 Share Posted May 27, 2021 3 hours ago, RetroCoder said: Version 1.2.0 of the extension has been released. - Better integration of the ATasm assembler - Fixed a bug that reset the path to be always the Windows path of the atasm - Build Task now also works when 'atasm-build.json' is the currently open file - Added configuration options to allow for another emulator to be used - Set the ownEmulator setting and supply the path and arguments - The extension will not add any parameters. You will need to supply them in the correct format. With this release you can specify a different emulator. The readme had some instructions. Should now be able to run any emulator. You just have to supply the arguments I'll have to find a Mac with a dev environment on it to get atasm v1.11 compiled, then I can have the extension Windows/Linux/MacOS compatible Happy debugging Excellent! I’ll give it a test. As long as it uses the setting and picks up my install of atasm, having it bundled isn’t a huge issue. thanks! Quote Link to comment Share on other sites More sharing options...
tsom Posted May 27, 2021 Share Posted May 27, 2021 (edited) I'm happy to report that I am able to assemble and run a program using this extension on MacOS, using my own install of atasm. (It's only version 1.10, will have to update...) Debugging doesn't work, obviously, due to running in Atari800MacX, which doesn't understand the Altirra debugging stuff. But some success! Actually, I originally had the path to Atari800MacX in the "Altirra: Path" setting and that seemed to work - it added the compiled file as an argument. However, I noticed the new "Own Emulator" flag and path, so I set that up, but while it launches the emulator, it doesn't pass the name of the compiled file. How do I add that as a parameter? Edited May 27, 2021 by tsom Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted February 2, 2022 Author Share Posted February 2, 2022 For those using the VSCode to code their 6502 assembler project there is a bit of news. The atasm-altirra-bridge plugin has been updated to version 1.6 Two important new features: 1. when using ATasm as your assembler you can now specify the -hv command line flag to export all constant, label, macro and include files data. - This can be viewed via the new `Asm Symbol Explorer` view. - Get info on where your symbols are defined, what their memory location/value is etc. 2. If your project uses mads then there is a simple configuration switch that lets you use the mads assembler. - Mads does not support the new `Asm Symbol Explorer` view (ATasm only feature) 6 1 Quote Link to comment Share on other sites More sharing options...
Thelen Posted February 2, 2022 Share Posted February 2, 2022 I didn't know about this, and I'm a vsCode user ? Just downloaded the plugin and hopefully try it this week. Thanks for making this! Quote Link to comment Share on other sites More sharing options...
Meadow Glen Posted February 2, 2022 Share Posted February 2, 2022 I see this thread was started in 2021. Anyway, I happen to use Visual Studio Code, a Macbook Air M1, and Altirra. Altirra, I have Parallels installed with Windows Developer preview for Arm, and altirra. Frankly Windows on this setup works so smoothly and fast, that I don't worry about it being developer preview. It's a problem for Parallels since they cannot sell it with the software, but, works like a charm. Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted February 15, 2022 Author Share Posted February 15, 2022 New version of the VSCode plugin has been released. When using ATasm (latest version) the symbol explorer now shows the comments from the assembler source code: i.e. HELLO = 55 ; Give hello a nice value Loop jmp Loop ; Wait until the end of time or power down The symbol explorer (which can now be dragged to a different location, thank to VSCode allowing multiple pannels) will show the ; Give hello a nice value and ; Wait until the end of time ... Just makes for a quicker overview of your code. Also added settings to control single instance of Altirra and which symbols atasm should export to the symbol explorer. If you have plenty of constants defined in your code that section can get very big 2 1 Quote Link to comment Share on other sites More sharing options...
freetz Posted May 11, 2022 Share Posted May 11, 2022 (edited) Thanks a lot for this really cool extension! It works perfectly on my Mac :)! I have been using Eclipse with WUDSN for a long time, but since I use VSCode for all my other coding projects, I'm really happy to be able to move my workflow here. Since a few people here have been looking for a way to get this working on a Mac, here's what I did: - Install Wine.app: -- Install brew (if you haven't done so before): /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)" -- Install wine: brew tap homebrew/cask-versions brew install --cask --no-quarantine wine-stable - Download and extract Altirra from https://www.virtualdub.org/altirra.html - Test if wine works with Altirra from the terminal (adjust paths to your configuration, but make sure you always use the 64 bit versions), ignore the complaints that "Mono" is missing (just hit cancel) and go through the initial configuration: /usr/local/bin/wine64 ~/Downloads/Altirra-4.01/Altirra64.exe - Optionally: Install MADS from https://github.com/tebe6502/Mad-Assembler/releases brew install fpc fpc -Mdelphi -vh -O3 mads.pas cp mads /usr/local/bin - Install the Atasm Altirra Bridge extension in VS Code - Configure the extension to your liking but make sure to configure Atasm-altirra-bridge > Emulator > Altirra: Path to this: /Users/<YOUR USERNAME>/altirra.sh - If you want to use MADS, set the corresponding setting and fill in the full path to the MADS assembler. - Then create altirra.sh with this content (again, adjust paths like above): #!/usr/local/bin/bash /usr/local/bin/wine ~/Downloads/Altirra-4.01/Altirra64.exe $@ and change the permissions to executable: chmod 755 ~/Downloads/Altirra-4.01/altirra.sh Now create/open a assembly file and press SHIFT + COMMAND + P to open the command palette and search for "Atasm: Assemble source code and run in Altirra" and execute this command. Upon first execution, it will create a atasm-build.json file. It looks like this: { "comment": "Altirra configuration file.", "_1": "Which asm file is to be compiled?", "input": "theapp.asm", "_2": "Array of folders that will be searched when files are .include(d)", "includes": [], "_3": "Which folder will all the output files be written to. 'out' by default. Always in the workspace!", "outputFolder": "out", "_4": "Additional atasm parameters:-v -s -u -r -fvalue", "params": "", "_5": "List of symbols to be set via the parameter list", "symbols": [], "_6": "If debug is enabled then symbol table and listings are generated for Altirra debugging", "withDebug": true } - You have to change "input" to the primary file you want to compile and replace "theapp.asm" with it. - You have to change "outputFolder" from "out" to "." Then you can press SHIFT + COMMAND + P again and run "Atasm: Assemble source code and run in Altirra" again and now it should compile, fire up Altirra and run your compiled program in it. Happy coding :)! Edited May 11, 2022 by freetz 4 1 Quote Link to comment Share on other sites More sharing options...
+Torq Posted May 2 Share Posted May 2 Tried this today, since it looks very cool - and I'd much rather use VSC than Eclipse*. Either I'm missing something, or something has changed between the shell, Wine, Altirra or macOS ... as at this point, even launching directly from the command line (no intermediate scripts, nothing else doing the launching/invoking) Altirra absolutely refuses to recognize any path that contains, or resolves to, something starting with "/" (complains about an invalid command line). Of note ... I didn't get as far as running the VSC extension ... as more fundamental things aren't working. Altirra works fine interactively under Wine, after bineg launched from the command line. Works fine from the command line if the binary is in the same folder as Altirra, or in a sub-folder. But no go with anything in any folder under /Users (or anything else with a / at the start, literal or implied) (etc.). Again, I may just be missing something ... and any hints are appreciated, but at this point I think it's either set something up under Windows (which means VMware and Windows 11 for Arm) or deal with Eclipse (my issue isn't with WUDSN ... I think that's great ... within the limits imposed by Eclipse' tedious and/or back-arsewards way of doing things). --- *I'd rather have my teeth drilled, without anesthetic, than deal with Eclipse on a long-term basis. Quote Link to comment Share on other sites More sharing options...
+Torq Posted May 3 Share Posted May 3 Got the extension running with Visual Studio code under Windows 11 Arm 64 in VMware with MADS and Altirra (also ARM64 version). The only thing I don't seem to be able to make work (which I suspect is because it doesn't/can't), is initiating a Run or Debug via the "normal" Run/Debug icon on the sidebar, nor from the Run menu - as those invoke launch settings, which require specifying a debugger (what VSC thinks is a debugger) ... which you can't do in this case (because Altirra isn't one). It does work from the extension's buttons on the Status Bar, and via the command palette, but there doesn't seem to be a way to tell VSC to use Altirra as what VSC thinks is a Debugger. (This is not meant as a complaint; it's great to have ... just a shift in muscle-memory/habit vs. the myriad other languages I used with VSC that work the "normal" way.) Quote Link to comment Share on other sites More sharing options...
freetz Posted May 3 Share Posted May 3 You are right, I had to adjust altirra.sh in the meantime because wine in combination with Altirra would only accept the xex executable without any path. So I had to change altirra.sh to this: #!/bin/bash directory=${3%.xex} cd ~/Documents/PlatformIO/Projects/$directory WINEDEBUG=-all /opt/homebrew/bin/wine64 ~/Downloads/Altirra-4.01/Altirra64.exe $@ Again, adjust the path to Altirra64.exe (and possibly wine64). And yes, what you describe with the debugger is the same for me. Not having to shift muscle-memory would be nice, especially as the icons are small and easy to miss. If anyone knows how to start run/debug by just using one key(-combination), that would be great. 1 1 Quote Link to comment Share on other sites More sharing options...
+Torq Posted May 3 Share Posted May 3 Very clever! Reference Altirra’s binary as an absolute path while making the location of the .xex the CWD … so no path for Altirra to parse. I was about to try sticking Altirra in my PATH and doing something similar … but I have SO much in the PATH already something’s eventually going to give (or conflict). Thanks! Quote Link to comment Share on other sites More sharing options...
freetz Posted May 3 Share Posted May 3 You're welcome. Also note that the WINEDEBUG=-all removes countless warnings relating to graphic output etc. that I decided to remove that. In case you need to debug something, you may want to remove that part of the line. Quote Link to comment Share on other sites More sharing options...
freetz Posted May 3 Share Posted May 3 @RetroCoder: Thanks again for this great plugin, would it be possible to change the behaviour of the "input" attribute in such a way that if it's left empty, then the first .asm file found in the directory will be used? In that case, I would not have to adjust the atasm-build.json file for every folder I work in (which usually just has one .asm file). And to expand on this even further: If there is no atasm-build.json file in a directory, the plugin just uses these default values, so you could completely do without this config. At least for me, I never use any other configuration than the default one above. This would make working with a larger number of already existing projects much easier. Again, thanks for this! Quote Link to comment Share on other sites More sharing options...
+Torq Posted May 3 Share Posted May 3 10 hours ago, freetz said: Also note that the WINEDEBUG=-all removes countless warnings relating to graphic output etc. I got that wedged in pretty early. Right after first launching Altirra with WINE interactively in fact! ... So, I have Altirra working both in Visual Studio Code (via the extension's run/build buttons still) and WUDSN (using a similar script), and was able to clean up the locations of all the tools in the process. Also setup a CrossOver bottle with Altirra and a whole bunch of other Windows-only Tools, and some .ATRs with Atari-native tools, so now I'm all out of excuses and its time to sit down and write some proper 8-bit code. Thanks to both @freetz, @RetroCoder on this side of things, and of course @phaeron, @tebe and @JAC! 2 Quote Link to comment Share on other sites More sharing options...
RetroCoder Posted May 3 Author Share Posted May 3 12 hours ago, freetz said: @RetroCoder: Thanks again for this great plugin, would it be possible to change the behaviour of the "input" attribute in such a way that if it's left empty, then the first .asm file found in the directory will be used? In that case, I would not have to adjust the atasm-build.json file for every folder I work in (which usually just has one .asm file). And to expand on this even further: If there is no atasm-build.json file in a directory, the plugin just uses these default values, so you could completely do without this config. At least for me, I never use any other configuration than the default one above. This would make working with a larger number of already existing projects much easier. Again, thanks for this! Just making sure I understand your request: - When the "atasm-build.json" file is present and the "input" field is empty or missing then search for the first .asm file in the folder and build that. - If the "atasm-build.json" file is missing use some internal default config. I like those ideas. I'll make the generation of the "atasm-build.json" file a configurable option. By default it will generate the config file. If you turn OFF the option then it will NOT auto generate the config file and search for the first .asm file in the folder and build that with DEBUG options. i.e. atasm.exe -oout\rainbow.xex -lout\rainbow.lab -gout\rainbow.lst -hvclm "rainbow.asm" V1.9.0 of the VScode extension will have these implemented 1 Quote Link to comment Share on other sites More sharing options...
