Re4per Posted May 26, 2021 Share Posted May 26, 2021 (edited) My VCS has only 9.9 gig storage that i can use. It has 32 gigs of internal storage so where is the rest??? Edited May 26, 2021 by Re4per Quote Link to comment Share on other sites More sharing options...
justclaws Posted May 26, 2021 Share Posted May 26, 2021 2 hours ago, Re4per said: My VCS has only 9.9 gig storage that i can use. It has 32 gigs of internal storage so where is the rest??? It sounds as though your system has a corruption to the disk partition table - the layout of the disk. The easiest way would be to just flash the system, according to the Atari support pages. (For link, see the FAQ.) You take a USB stick, run some software from another PC or a Mac to put an image on it, then boot from that. I think I saw 2 other people who had a similar problem, with their original Backers consoles, and that fixed it. (The other fix, if you're technical, is to boot Ubuntu from a USB stick, and fix the partitition table as required.) It's not a hardware fault - not even a software fault - it's a very rare error from when the system was installed. My guess is that during software installation, something glitched, or somebody disconnected the VCS too early at the factory, and so the internal software was not fully "expanded" to the system. Very unlucky but easily fixed. I hope that helps. 1 1 Quote Link to comment Share on other sites More sharing options...
Re4per Posted May 26, 2021 Author Share Posted May 26, 2021 Thank you very much. It worked ☺️?? I am so happy ? 2 Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted June 16, 2021 Share Posted June 16, 2021 (edited) On 5/26/2021 at 4:47 PM, Re4per said: Thank you very much. It worked ☺️?? I am so happy ? How much free space did you have after the flash? Edited June 16, 2021 by Atari Nut Quote Link to comment Share on other sites More sharing options...
justclaws Posted June 17, 2021 Share Posted June 17, 2021 15 hours ago, Atari Nut said: How much free space did you have after the flash? I just checked for you, on my system - 19.7 GB free, 21% used. (So a newly flashed system would likely have 23.5 GB available.) My "System": taking 1.4 GB (including Google Chrome) My "Others": (game saves) taking 3.8 GB. My games are moved onto internal M.2, which is 128GB, 90.3 GB free, 23% used. I also have the games backed-up to a simple USB stick. (Physical media, yeah...) I have all titles except Ato to-date. (Nothing against Ato, but it's $15, also.) Quote Link to comment Share on other sites More sharing options...
Atari Nut Posted June 17, 2021 Share Posted June 17, 2021 Thanks for that info justclaws. 1 Quote Link to comment Share on other sites More sharing options...
