Peripheral Posted May 31, 2021 Share Posted May 31, 2021 I've been putzing around with disassembly, and found what I think to be an error in the presumed addresses for the EXEC's X_SET_BIT and X_CLR_BIT routines (SETBIT and CLRBIT in YFTE parlance). In some other threads discussing disassembly, and from looking at jzintv's dis1600, it seems the current assumption is effectively this mapping: X_SET_BIT EQU $16DB X_CLR_BIT EQU $16E6 But looking at the disassembly of the EXEC, it appears that the code at $16DB does the CLRBIT operation, and the code at $16E6 does the SETBIT operation. A typical invocation looks like this: MVII #$0003, R0 ; We want to clear bit 3 (which has mask $0008) JSR R5, X_CLR_BIT DECLE $0183 ; Address of DECLE whose 3rd bit we want to clear The code at $16E6 is as follows: L16E6: PSHR R0 ; Preserve R0 PSHR R1 ; Preserve R1 MVI@ R5, R1 ; Load address into R1 (e.g., R1 = $0183) PSHR R5 ; Save return address on stack JSR R5, X_POW2 ; Convert bit number to mask (e.g., R0 = 1 << 3) MOVR R0, R5 ; Make a copy of the mask, R5 = $0008 COMR R0 ; Invert the mask: R0 = $FFF7 AND@ R1, R0 ; Temporarily clear bit 3 of the value at $0183 XORR R5, R0 ; Set bit 3, and also set status word as if "OR" MVO@ R0, R1 ; Store modified value back to $0183 PULR R5 PULR R1 PULR R0 ; To return, avoid MOVR R5, R7 as that would change the status word. ; Setting the status word is part of the semantics of this function. PSHR R5 PULR R7 So it looks like X_CLR_BIT actually does the SETBIT operation. The X_SET_BIT code is similar, but it only does the AND@ operation, and not the XORR, so in effect it is clearing the bit. If @intvnut is listening, perhaps he can verify my analysis, and update dis1600 as appropriate. I googled around to see if this was a known issue, and didn't find anything. So I suspect there aren't any homebrews using these EXEC functions. 2 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted June 1, 2021 Share Posted June 1, 2021 I never found documentation on EXEC entry points, so I never used the EXEC. At the end wasn't so bad, because the EXEC has some known limitations. And from reading the code shown, it appears like it is very inefficient!!! Quote Link to comment Share on other sites More sharing options...
Zendocon Posted June 2, 2021 Share Posted June 2, 2021 12 hours ago, nanochess said: I never found documentation on EXEC entry points, so I never used the EXEC. At the end wasn't so bad, because the EXEC has some known limitations. And from reading the code shown, it appears like it is very inefficient!!! There is a very small list of known entry points here. There really is no point to knowing Exec entry points outside of ROM hacking, because it's just there so early games could fit inside of 4K ROM. 2 Quote Link to comment Share on other sites More sharing options...
