First Spear Posted June 1, 2021 Share Posted June 1, 2021 I skimmed the text at https://link.springer.com/chapter/10.1007/978-981-15-7533-4_8, abstract: Quote Randomised algorithms use a degree of randomness in their logic. Such algorithms provide a solution which may not always be optimal, but is often produced faster than a brute force process. This paper explores the two classes of randomised algorithms: Las Vegas and Monte Carlo. A Las Vegas algorithm always produces the correct result, but its running time is based on a random value. A Monte Carlo algorithm has a deterministic running time and produces an answer that has a probability of ≥ 1/3 of being correct. By means of this paper, we develop algorithms that predict the winning probabilities of the betting options.... A comparative study for the algorithms has also been done. and I was wondering if Óscar, Joe, Others with SkillsTM could comment on how those could be implemented on an Intellivision, ideally wrapped in an IntyBASIC call? Just some theoretical musing. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted June 1, 2021 Share Posted June 1, 2021 Probably because it is the afternoon, but I cannot "see" a game where an algorithm of this type could be implemented, also I cannot remember a game where a Monte Carlo algorithm is used. Quote Link to comment Share on other sites More sharing options...
+cmadruga Posted June 2, 2021 Share Posted June 2, 2021 (edited) One idea would be to write a game in which a supply chain is represented, and then use Monte Carlo to simulate its performance in face of varying conditions. It would not be the most exciting game, however... (I would dig it, but that's because it's in my line of work :-) Edited June 2, 2021 by cmadruga 3 Quote Link to comment Share on other sites More sharing options...
Zendocon Posted June 2, 2021 Share Posted June 2, 2021 12 hours ago, cmadruga said: One idea would be to write a game in which a supply chain is represented, and then use Monte Carlo to simulate its performance in face of varying conditions. It would not be the most exciting game, however... (I would dig it, but that's because it's in my line of work :-) I remember a learning game on the Apple IIc at school called Appletown. Perhaps a beefed-up variation of Appletown could be built using Monte Carlo. In Discrete Mathematics class, one of my computer projects was to write a Blackjack simulator that played 10,000 games (not nearly enough, I had to argue to the professor) and created a 3D chart showing whether it was better to hit or stand, given the point value of the displayed cards and how many Aces were in play. Included in the simulator was the Dealer's rule to shuffle the deck/s (I forget how many decks were used; might have been 2) when the stack was below the 25% threshold. 2 Quote Link to comment Share on other sites More sharing options...
+cmadruga Posted June 2, 2021 Share Posted June 2, 2021 2 hours ago, Zendocon said: I remember a learning game on the Apple IIc at school called Appletown. Perhaps a beefed-up variation of Appletown could be built using Monte Carlo. Interesting, didn't know that one. Do you have a good link? I couldn't find much content, only Little Computer People references. 2 hours ago, Zendocon said: In Discrete Mathematics class, one of my computer projects was to write a Blackjack simulator that played 10,000 games (not nearly enough, I had to argue to the professor) and created a 3D chart showing whether it was better to hit or stand, given the point value of the displayed cards and how many Aces were in play. Included in the simulator was the Dealer's rule to shuffle the deck/s (I forget how many decks were used; might have been 2) when the stack was below the 25% threshold. I suppose the number of runs needed depends on what you are simulating... To be honest I haven't seen a good rule of thumb for minimum # of runs, have you? The more, the merrier I suppose, but eventually there will be diminishing returns. Of course, given that Monte Carlo is resource intensive, for sure that will limit what can be done in practical terms in a platform like the Intellivision. Quote Link to comment Share on other sites More sharing options...
Zendocon Posted June 2, 2021 Share Posted June 2, 2021 1 minute ago, cmadruga said: Interesting, didn't know that one. Do you have a good link? I couldn't find much content, only Little Computer People references. I couldn't find anything just now. Perhaps it was written by a math teacher and had very limited distribution. It was all text-based and gave you so many tries to figure out what price to set for selling apples to get the maximum profit. Nothing that couldn't be written in ECS BASIC. 2 minutes ago, cmadruga said: I suppose the number of runs needed depends on what you are simulating... To be honest I haven't seen a good rule of thumb for minimum # of runs, have you? The more, the merrier I suppose, but eventually there will be diminishing returns. Of course, given that Monte Carlo is resource intensive, for sure that will limit what can be done in practical terms in a platform like the Intellivision. All I know is that I wanted to simulate a million hands of Blackjack, and the professor insisted I hard-code in a maximum of ten thousand. When he looked at the final output, he pointed to specific cells and told me "that one is wrong, that one is wrong, that one is wrong." That's when I stopped him and argued it would have taken a lot more than ten thousand hands to get accurate results. Just because something isn't practical doesn't mean it shouldn't be done. Things like that are always good to implement out of academic curiosity. I still am waiting to see somebody implement Mandelbrot in Colored Squares Mode, just because. 1 Quote Link to comment Share on other sites More sharing options...
+cmadruga Posted June 2, 2021 Share Posted June 2, 2021 1 minute ago, Zendocon said: I couldn't find anything just now. Perhaps it was written by a math teacher and had very limited distribution. It was all text-based and gave you so many tries to figure out what price to set for selling apples to get the maximum profit. Maybe it was a clone of Lemonade Stand? https://en.wikipedia.org/wiki/Lemonade_Stand Quote Link to comment Share on other sites More sharing options...
Zendocon Posted June 2, 2021 Share Posted June 2, 2021 It was even more simplified than that. All you did was set the price of apples. Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 2, 2021 Share Posted June 2, 2021 I can't confirm nor deny that Cmart's Noodle Stand will contain any form of Monte Carlo simulations or other forms of randomized algorithms. I can't even confirm nor deny that the game will be developed. 1 Quote Link to comment Share on other sites More sharing options...
Kiwi Posted June 2, 2021 Share Posted June 2, 2021 (edited) 8 hours ago, carlsson said: I can't confirm nor deny that Cmart's Noodle Stand will contain any form of Monte Carlo simulations or other forms of randomized algorithms. I can't even confirm nor deny that the game will be developed. I can confirm that I was not able to peek through a window to see what carlsson is developing. Sweden's too far. Edited June 3, 2021 by Kiwi Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted June 4, 2021 Share Posted June 4, 2021 On 6/2/2021 at 9:15 AM, cmadruga said: Maybe it was a clone of Lemonade Stand? https://en.wikipedia.org/wiki/Lemonade_Stand That would probably be an easy-ish game to port from Apple BASIC to IntyBASIC. You _might_ even be able to just use color squares mode. Quote Link to comment Share on other sites More sharing options...
