Jaguar HSC_SEASON 15_ROUND 2
1 hour ago, Hyper_Eye said:
I just recently picked up a "new" set and I worked on the geometry in the service menu the best I could. Unfortunately it looks like the cone is turned a little so I need to open it up and adjust it from the inside. I haven't gotten around to doing it yet. I noticed this game emphasizes my CRTs flawed geometry because it utilizes space very close to the overscan area.
Here is a side/side picture of both TVs.  Noticeable difference:
Is the one on the left a CRT also? If so this can very likely be corrected in the service menu. Get the 240p test suite for a console you use with that television (I use the Dreamcast version) and look up the service manual for your television model. As bad as my geometry looks in my last pic it looked a lot worse before I adjusted it. By opening up the television I should be able to get it near perfect. My previous CRT was able to be adjusted to a very acceptable geometry just with the service menu.
 That JVC is a fantastic set btw.
Edited by Hyper_Eye
  • 1 month later...
