Super Mario Bros 3 final level question
3 hours ago, bradhig1 said:
Bowser's castle has several rooms where you could fight the final battle was someone drunk at Nintendo when they designed that level?   Not mention there are two boss rooms side by side when you do trick to disable Bowser's fireballs.
There are two different paths -- one is more difficult, and the other isn't.  One path also has a power-up right before it, whereas the other one doesn't.  (Granted, you can still switch between the two room options AFTER getting the power-up, but it isn't the easiest thing to do.)
The upper path is technically more difficult -- no power-up before the door, donut blocks above lava, and a smaller section of breakable floor in the final room.
