+DjayBee Posted January 23, 2023 Share Posted January 23, 2023 8 minutes ago, 800_Rocks said: LibreOffice Writer unfortunately does not have a 'save to PDF' option. Although this is literally correct, it has an "Export to PDF" function. In German but you certainly will get the idea: 1 Quote Link to comment Share on other sites More sharing options...
800_Rocks Posted January 23, 2023 Share Posted January 23, 2023 2 hours ago, DjayBee said: Although this is literally correct, it has an "Export to PDF" function. Thanks!! I rediscovered that option just minutes ago myself. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted January 23, 2023 Share Posted January 23, 2023 I have this one if someone wants it... it is a cassette for Atari 400/800/1200XL. I also have Math Mileage from CBS. 1 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted January 24, 2023 Share Posted January 24, 2023 Hi bf2k+, Yes!!! That makes the collection complete! :-))) If you can upload the WAV or CAS files, that would be marvelous! :-))) Regarding the manual, it is fully sufficient, if load up just pictures with a smartphone, I can assemble them here to a pdf file. Btw, you are big in: Atari 8-bit BBS, do you have a backup or files from the OSS BBS? Thank you sooooo much in advance. 🙂 Your help is highly appreciated! Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted January 24, 2023 Share Posted January 24, 2023 Well... I don't have a cassette player anymore so no way to dump it. I was really just interested in selling it outright. Make me an offer I can't refuse... No OSS BBS here... sorry. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 24, 2023 Author Share Posted January 24, 2023 See next Post for Issue #31 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 24, 2023 Author Share Posted January 24, 2023 Issue #31 MICRODOS.LST is entered into MICRODOS.BAS from issue #28 for better XL compatibility. BALLDROP.LST is entered into BALLDROP.BAS from issue #22 for better XL compatibility. UNICHECK.BAS creates a file or a cassette version of the program. The CAS and an independently made ATR are included. The assembly listing compiles, but the results lock up the computer. ROTO.ACT loads, compiles and runs inside ACTION, but the saved compiled version I just made does not work. I did find a copy of the ACT file along with a compiled version of the game. The difference is that this version has and include for a runtime package. I am including this version of the ACT file and the OBJ file that was with. I still cannot compile this. LUNAR.BAS locks up if it is run from the ANALOG DISK MENU. If the ANALOG disk AUTORUN.SYS executes, this program will lock up. Run it from some other boot disk, even SDX likes it. LAZER.BAS creates a file or a cassette version. A CAS and an ATR from that CAS are included. The magazine says that the assembly listing is located on "Analog Computing TCS". It is not on the source disks and I was unable to locate it elsewhere. If someone has it, get it to me and I will make an update. Atari Clock: I type in the assembly listing and it compiles, but you have to set some variables in it to make a working copy, I did not do this. I used MAKCLOCK.BAS to get the OBJ file. I copied it to a DOS disk as AUTORUN.SYS and add the SETCLOCK.BAS program on it, ATR included. The clock only appears after you set the clock. Side Note: the assembly listings were nowhere to be found on a previous Analog disks. I typed the missing assembly listings. LAZER has an assembly listing, but is not printed in the magazine, nor do I have it. Analog Computing #31 (1985-06)(Analog Magazine Corp.)(US)[BASIC].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 24, 2023 Author Share Posted January 24, 2023 Anyone have the files for the Printer Driver Program in Issue #32. It is not on the source disks and I cannot locate it. Issue #32 There are 4 listings, three in BASIC and one in assembly. If I cannot find them, I will begin typing them tomorrow, if no one responds. Quote Link to comment Share on other sites More sharing options...
pmgraphics Posted January 24, 2023 Share Posted January 24, 2023 (edited) Issue 31: Lunar seems to have some corruption in the file. I have Lunar on an ATR file from some place else and it loads and runs fine. Issue 31's Lunar crashes and when comparing the two files using Memo Pad, it is missing line 110 and line 105 has a bunch of strange characters with line 110 tacked on the end. Issue 31: (characters here don't match as seen in Memo Pad) 105 F1=F1+0.5:IF F1/C8=INT(F1/C8) THEN FUEL=FUEL-C8:FUEL=FUEL*(FUEL>-C1):POSITION 34,C0:? FUEL;0REM M6¥-¥%?P ¥'‡"P:¥'‡,&6”-”&‡36”-”$+”!6€,?-@4 •G(” :,:?-•n A F:‘,s F:Œ,110 POKE 711,PEEK(C20) 115 IF PEEK(CNSL)<>C7 THEN SOUND C0,C0,C0,C0:GOTO C20 My ATR: 105 F1=F1+0.5:IF F1/C8=INT(F1/C8) THEN FUEL=FUEL-C8:FUEL=FUEL*(FUEL>-C1):POSITION 34,C0:? FUEL;" ":F1=C0 110 POKE 711,PEEK(C20) 115 IF PEEK(CNSL)<>C7 THEN SOUND C0,C0,C0,C0:GOTO C20 FD2.atr Edited January 24, 2023 by pmgraphics spelling Quote Link to comment Share on other sites More sharing options...
luckybuck Posted January 25, 2023 Share Posted January 25, 2023 Normally, I don't preupload, but to help at least a little bit SoulBuster, here is: The complete Antic Deep BlueC: all credits to G. H. from Germany for this collection. Mostly, ANTIC version = APX version minus the info file from APX Deep Blue C-Compiler-AP114-A Deep Blue C-Compiler-AP114-B-Documentation Deep Blue C-Secrets-APO115-A Deep Blue C-Secrets-APO115-B-Documentation - not sure Mathlib for C-AP0132-A - not sure Mathlib for C-AP0132-B-Documentation - not sure The last 3 ones need to be verified again. Hope, we can complete everything regarding C on the Atari. Have fun. Antic-Deep Blue C Compiler.atr Deep Blue C-Compiler-A.atr Antic-Deep Blue C Compiler-AP114 -Manual.atr Deep Blue C-Compiler-AP114-B Documentation.atr Antic-Deep Blue C Secrets-A.atr Deep Blue C-Secrets Dokument A-CRC checked by Andreas.atr Deep Blue C-Secrets-APX-20179.atr Deep Blue C-Secrets Dokument B-DOCs fehlen.atr Deep Blue C-Secrets Dokument B.atx Mathlib for Deep Blue C-APX-20231.atr Mathlib for C-B Documentation AP0132.atr Mathlib for C-B Documentation AP0132.atx 2 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 25, 2023 Author Share Posted January 25, 2023 17 hours ago, pmgraphics said: Issue 31: Lunar seems to have some corruption in the file. I have Lunar on an ATR file from some place else and it loads and runs fine. Issue 31's Lunar crashes and when comparing the two files using Memo Pad, it is missing line 110 and line 105 has a bunch of strange characters with line 110 tacked on the end. Issue 31: (characters here don't match as seen in Memo Pad) 105 F1=F1+0.5:IF F1/C8=INT(F1/C8) THEN FUEL=FUEL-C8:FUEL=FUEL*(FUEL>-C1):POSITION 34,C0:? FUEL;0REM M6¥-¥%?P ¥'‡"P:¥'‡,&6”-”&‡36”-”$+”!6€,?-@4 •G(” :,:?-•n A F:‘,s F:Œ,110 POKE 711,PEEK(C20) 115 IF PEEK(CNSL)<>C7 THEN SOUND C0,C0,C0,C0:GOTO C20 My ATR: 105 F1=F1+0.5:IF F1/C8=INT(F1/C8) THEN FUEL=FUEL-C8:FUEL=FUEL*(FUEL>-C1):POSITION 34,C0:? FUEL;" ":F1=C0 110 POKE 711,PEEK(C20) 115 IF PEEK(CNSL)<>C7 THEN SOUND C0,C0,C0,C0:GOTO C20 FD2.atr 90.02 kB · 1 download I downloaded the file I posted and I do not see the problem. Maybe your copy of the download is corrupt. I did some testing though: lunar.bas does lock up the computer, but it seems only after the AUTORUN.SYS executes on the ANALOG Disk. It even runs under SDX, DOS 1,DOS II and DOS 2.5. No further testing done. 1 Quote Link to comment Share on other sites More sharing options...
pmgraphics Posted January 25, 2023 Share Posted January 25, 2023 Thanks for looking into it. I was able to reproduce your testing. Loading lunar.bas from the ANALOG menu crashes, while loading it from the READY prompt, lunar.bas runs fine. Menu lunar.bas READY prompt lunar.bas After the lunar.bas crash, restarting Alttira (warm reset or cold reset) Altirra get's stuck in warp speed. Altirra must be closed and reopened. I tired to type 01 to enter DOS and many zeros spread across the screen. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 25, 2023 Author Share Posted January 25, 2023 The combination of the two programs seems cause big problems. I have made a notation in the post, but changing the disk image, really is not an option since it was the way it was published. 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 25, 2023 Author Share Posted January 25, 2023 Issue #32 ACCESS3.BAS creates an AUTORUN.SYS and I copied it to the Analog disk as ACCESS3.OBJ. The assembly lising compiles into a working ACCESS3.OBJ. Copy ACCESS3.OBJ to a DOS disk and rename AUTORUN.SYS or load using the L command in Atari DOS. It seems to also run under SDX. An ATR with DOS 2.5 is included. TRANSLTR.BAS creates an AUTORUN.SYS file on a DOS disk (be careful as it immediately starts writing to D1:). The 3 assembly listings do compile, but are only there to show what BASIC is doing. Copy to a DOS disk as AUTORUN.SYS. An ATR is included. COSMIC.BAS creates a file or a cassette of Cosmic Defender. The CAS and an ATR from that CAS are included. The Assembly listing compiles into a working game. These files were missing on the source disks. AWPDMAKR.BAS creates an AUTORUN.SYS file on a dos disk for Atari Write Printer Drivers. AWPDCASS.LST is entered into AWPDMAKR.BAS to create a boot cassette. AWPDCHCK.BAS checks that AWPDMAKR.BAS is correct. AWPDRIVR.M65 compiles, but I will not include an OBJ, a CAS or an ATR as you will need to set it to your printer. Side note: I got to use Unicheck from Issue #31 when I typed the BASIC programs of the AtariWriter Printer Driver. I used the ATR I made for that issue. Analog Computing #32 (1985-07)(Analog Magazine Corp.)(US)[BASIC].zip 3 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 26, 2023 Author Share Posted January 26, 2023 On 1/24/2023 at 9:21 PM, luckybuck said: Normally, I don't preupload, but to help at least a little bit SoulBuster, here is: The complete Antic Deep BlueC: all credits to G. H. from Germany for this collection. Mostly, ANTIC version = APX version minus the info file from APX Deep Blue C-Compiler-AP114-A Deep Blue C-Compiler-AP114-B-Documentation Deep Blue C-Secrets-APO115-A Deep Blue C-Secrets-APO115-B-Documentation - not sure Mathlib for C-AP0132-A - not sure Mathlib for C-AP0132-B-Documentation - not sure The last 3 ones need to be verified again. Hope, we can complete everything regarding C on the Atari. Have fun. Antic-Deep Blue C Compiler.atr 90.02 kB · 13 downloads Deep Blue C-Compiler-A.atr 90.02 kB · 12 downloads Antic-Deep Blue C Compiler-AP114 -Manual.atr 90.02 kB · 12 downloads Deep Blue C-Compiler-AP114-B Documentation.atr 90.02 kB · 12 downloads Antic-Deep Blue C Secrets-A.atr 90.02 kB · 12 downloads Deep Blue C-Secrets Dokument A-CRC checked by Andreas.atr 130.02 kB · 14 downloads Deep Blue C-Secrets-APX-20179.atr 130.02 kB · 13 downloads Deep Blue C-Secrets Dokument B-DOCs fehlen.atr 90.02 kB · 12 downloads Deep Blue C-Secrets Dokument B.atx 94.14 kB · 12 downloads Mathlib for Deep Blue C-APX-20231.atr 90.02 kB · 12 downloads Mathlib for C-B Documentation AP0132.atr 90.02 kB · 12 downloads Mathlib for C-B Documentation AP0132.atx 97.86 kB · 14 download I am sure you guys at the preservation site are looking into these? (Farb, DjayBee?) 1 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 26, 2023 Share Posted January 26, 2023 1 hour ago, SoulBuster said: I am sure you guys at the preservation site are looking into these? (Farb, DjayBee?) Yep, I am following this thread. 1 Quote Link to comment Share on other sites More sharing options...
pmgraphics Posted January 27, 2023 Share Posted January 27, 2023 On 8/17/2022 at 10:07 AM, SoulBuster said: Analog Issue #5 In this issue, users could not complete several of the programs because of the print out in the magazine. Issue #6 had the corrections. I updated all programs on this disk to include the corrections. The Mailing list program would not even start right and I had to make changes to it that were NOT published, just to make it work at the start of the program. It used a trap statement to test if the file "D:MAILDATA.FIL" existed using OPEN,#2,12,0,"D:MAILDATA.FIL". 12 is used in an open statement for input AND output. When the file was not found during this statement, it created the file and the test for existing passes. This is an error because now the file it created is not formatted correctly for the rest of the program and you get an error later. I changed the open statement to open with OPEN,#2,4,0,"D:MAILDATA.FIL", read. And now the trap statement works as intended. Part of the stopwatch program puts the resulting OBJ code on a cassette, it makes an autoboot cassette. The corresponding .CAS file is included. Analog Computing #05 (1982-01)(Analog Magazine Corp.)(US)[BASIC].zip 35.27 kB · 37 downloads The maillist program would not let you enter anything beyond the CITY: field. After that was fixed there were some formatting and text overlapping issues. Attached is my updated version for anyone wanting to store their phone contacts in this higher technological form maillist.atr 3 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 I 've been quiet the last couple of days. I've been dumping newly acquired software. For the preservationists: Any new posts or posts that I update, the zip-download will include all assets. Pics, dumps, pdfs and anything else that belongs with a dump. In addition, I have changed hardware that I am using Disk Drive: TEAC FD-55GFR. All new (or updated) DISK dumps are on this drive. Any DISK dumps before this post were on a Panasonic JU-475. The Panasonic failed on the disk Slime. I tried Slime again on the new drive and still, all 720 sectors are "unformatted". So I guess the drive just failed and not failed because of the Slime disk. Cartridge: MaxFlash from AtariMax Cassette: Generic Cassette to MP3 Player and record with Audacity Scanner: Canon MF488DW So let the new titles begin!!! 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 AtariWriter Alternate Version AtariWriter (1984)(Atari Inc.)(US)[Cartridge].zip AtariWriter Word Processing Manual Rev B.PDF AtariWriter Quick Reference Rev B.PDF AtariWrite Helpful Hints.PDF 2 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 Delta Drawing Delta Drawing 3.20 (1983)(Spinnaker)(US)[cartridge].zip Delta Drawing 3.20 Manual.PDF Delta Drawing 3.20 Quick Reference.PDF Spinnaker Registration Card.PDF Spinnaker Catalog.PDF 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 The Crypts of Plumbous I was able to make an ATR from the CAS, BONUS. The Crypts of Plumbous (1982)(Cosmi)(US)[disk].zip 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 Atari Speed Reading Atari Speed Reading (1981)(Atari Inc)(US)[cassette].zip The manual is the same as it is here. a 4 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 The Crypts of Plumbous had a problem with the zip and new zip has been uploaded Get it here 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 Analog Database Found this on an unmarked disk. It is non Original Analog Database (19xx)(BBK Enterprises(US)[non-original disk].zip 4 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted January 29, 2023 Author Share Posted January 29, 2023 Family Finances Alternate Family Finances (1982)(Atari)(US)[disk].zip Family Finances Manual.PDF Family Finances Warranty Card.PDF 3 Quote Link to comment Share on other sites More sharing options...
